Clubby Estate - The Rot Box
138 replies to this topic
#76 Jackman
Jackman
  • 4,053 posts
Posted 28 February 2009 - 04:55 PM
We have an update ;) (Click on images for full size)
My MPI pullies arrived :)
Also did a bit of bodywork. Got the front end back together and started to line all the panels up. Still need alot of work to get them to fit correctly.
Also painted and patched the hole i had. Just need to get some filler on there when its sorted and it should be ok.
If the weather is still nice tomorrow there should be another update :yinyang:
#77 Jackman
Jackman
  • 4,053 posts
Posted 01 March 2009 - 04:37 PM
Another update.
Door and doorstep off
Lining the new panel up.
Welding inner panel on and running out of gas again!
Cut correctly and primed for welding.
I need a bigger gas bottle :shifty:
#78 Bec
Bec
  • 5,900 posts
Posted 01 March 2009 - 05:46 PM
Wow Chris you have been busy this weekend, cracking work!
The panels look to be lining up a whole lot better than they were last time I saw them, are they the same ones?
#79 Jackman
Jackman
  • 4,053 posts
Posted 01 March 2009 - 05:48 PM
Yeah they are the same ones. Just been cutting and moving them to get them fiting better. Once the door steps are done i can get the inner wings on :shifty: Then i get the fun job of trying to line up the wings and things but i will get there eventually ;D
#80 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 02 March 2009 - 09:47 AM
Looks great, Chris - I'm very impressed! :) Think you're doing a cracking job! :closed:
#81 Jackman
Jackman
  • 4,053 posts
Posted 07 March 2009 - 05:14 PM
Thanks Bean :)
Did a bit more today, re-welded that plate on and tacked it into position on the car, spent the rest of the time sorting out the inner wing and getting that lined up correctly... im nearly there now on the drivers side.
Ill be back out there tomorrow all being well and i will get it lined up fully and then start to weld it into position so i can start on the passenger side.
#82 Jackman
Jackman
  • 4,053 posts
Posted 08 March 2009 - 03:39 PM
Todays and yesterdays work.
Working with gas and a proper regulator that doesnt leak my welds are getting there but not going well with the welder... it has a mind of its own... well either that or the weld 2 primer isnt working right.
Re-welded the panel correctly and cleaned up.
Tacked the panel into the car
Put inner wing back in to make sure everything lined up correctly.
Bad piccy but bulkehad lining upto inner wing.
Paint taken off and then sprayed with weld 2 primer
Punched plug weld holes.
Two plugs done, messy but took
Panel welded in, again messy but took
Nice weld... didnt take to the other panel.
Tacked welded in.
Ive given up for the day because of the welder problems, think the weld 2 primer isnt working right >_<
Either way its progress.
#83 SamOzzie
SamOzzie
  • 247 posts
  • Local Club: Woodside Mini Club
Posted 08 March 2009 - 09:45 PM
Looking good mate
and why dont you try just sading a bit of the primer off along the edges of the panels then see if the weld comes out smoother?
that stuff never really works amazingly to be honest, welding on two raw bits of metal is the best :crazy:
#84 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 08 March 2009 - 10:38 PM
I admire the determination you have Chris >_<
#85 Jackman
Jackman
  • 4,053 posts
Posted 09 March 2009 - 08:20 AM
Looking good mate
that stuff never really works amazingly to be honest, welding on two raw bits of metal is the best ^_^
Thats the plan, going to sand down the primer back to bare metal... ive been doing good welds on bare metal before now but was told to use zinc primer by someone... wish i hadnt now.
I think ill just add a bit more seam sealer instead around the areas so it doesnt get water in there.
Determination.... i think im a bit mad.
#86 Git
Git
  • 1,269 posts
  • Local Club: Humanity
Posted 09 March 2009 - 08:31 AM
Genius/madness.... all the same really..... good luck Mr Jackman....
#87 wilp99
wilp99
  • 114 posts
  • Local Club: AME & MINIRYDES
Posted 09 March 2009 - 10:34 PM
make sure you take the black paint off the panels before you weld to it. better yet, run a sanding disk over everything your gonna weld. both sides of the holes for plugs, and the mating surface. ive used weld thru primer for my entire build and havent had a problem yet. it doesent help the quality of the welds (doesent hurt either) but it does stay after being welded keeping some of those mating parts that i cant paint covered in something. good luck with the rest of the build, stay at it and youll be done in no time. heres a link to all of our pics, im sure ive spamed it on your thread before, but it helps keep me motivated to keep going.... somehow. http://s94.photobuck...ellwil/clubman/
#88 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 09 March 2009 - 11:16 PM
LOL good progress i love welding when i can leave it and walk away
#89 Jackman
Jackman
  • 4,053 posts
Posted 04 April 2009 - 03:28 PM
We have an update, a few things for the engine arrived.
Baffle Tray
Piston Liners. The use for these will come clear when the engine is built.
Also welded the drivers side inner wing on, the first go today the welds didnt penatrate enough and when i put a bit of weight on them they split but did it with some force, tried again with more power and it did the job.
Plug Welds
Dont look too bad.
Grinded and painted, a few need filling where the plug isnt full. I will do that tomorrow, done enough for today.
If the weather is nice tomorrow i shall continue.
#90 tedmcedd
tedmcedd
  • 2,751 posts
Posted 04 April 2009 - 04:31 PM
cool cool!! getting there!! aparently there is going to be another bean run! lol!! i'd better start planning!!!!
