My Mini ;) The First Chapter.
1498 replies to this topic
#1126 analogue_radio
analogue_radio
  • 4,897 posts
Posted 03 May 2009 - 12:43 PM
Time for a good update! Steve & his son came over early afternoon to pick the wheels up, really nice lads, suggested that he should start his own project thread here ;)
& before I start, apologies for the large amount of pictures! trigger happy again.
Kicking off with some parcels that arrived yesterday, one was a full set of nuts/bolts & washers for the rear subby which I picked up from ebay. The other was a box containing a brand new radiator, Dads mate whose doing the Band of Brothers ride with him gave it to me :dontgetit: not sure if I'll use it as it's a standard Rover mini radiator, as apposed to my almost new Uprated 2 core Minispares rad.
Then I set about removing the shock mounts to see what they were hiding behind them, not pretty >_<
& wire brushed down to remove all the rot.. gaping hole!
Then I pulled off the bit of mesh/putty that was at the top of the inner wing..
Not much left!
Steering rack out, which made accessing the clevis pin easier..
Brake servo off and out, sheered a few bolts in the process..
Bit of rust.. you'll see how that ends up later, no points for guessing :P :X
Engine steady with earth strap out.
Clutch reservoir out, clevis pin wasn't that hard to remove which was a nice surprise :)
& the rusty patch behind poked with a screwdriver..
Edited by theIMAGE, 03 May 2009 - 12:45 PM.
#1127 dezshearer
dezshearer
  • 441 posts
  • Local Club: mini-chat.co.uk
Posted 03 May 2009 - 01:19 PM
Ah, all fixable! You'll need new shock mounts tho! I've never seen the mounts that bad!
Word of warning with that bolt kit for the rear subby, make sure the bolts are the right thread! I bought a kit like that from ebay, dunno who the supplier was, but they wern't. They sent me metric bolts.
The correct thread is 5/16" Thread with a 1/2" Head (that's for the subframe to heelboard, 4 long bolts going into the rear of the sill/rearbin area)
The other bolts all have nuts, so you can use metric here if you wish. (The four bolts in the boot floor)
#1128 analogue_radio
analogue_radio
  • 4,897 posts
Posted 03 May 2009 - 01:24 PM
Yup she'll be treated to new shock mounts >_< more expense though!
This was the kit I ordered, doesn't specify whether they are metric or not though..
Ebay link.
#1129 dezshearer
dezshearer
  • 441 posts
Posted 03 May 2009 - 01:49 PM
These are genuine UNF replacement bolts and not metric equivlents that dont fit properley
That's a good sign.
Before you put them in, i'd recommend you go to your local hardware store, and buy a 5/16 UNF tap (thread size) to clean out all the *melon* from the threads in the heelboard.
If you can get your hands on an unf tap +die set, you'll find rebuilding this car muuuuch easier.
#1130 analogue_radio
analogue_radio
  • 4,897 posts
Posted 03 May 2009 - 02:12 PM
I skimmed through that 5 times to check before saying it didn't state about being metric >_<
I'll pop into Gearbox soon and ask about either the 5/16 UNF tap or the tap +die set, cheers Dez!
Also a little thought (things like this keep me going because I can look forward to what is in store :X) 1.5 negative camber arms on the front to improve handling & make her sit really nice.
#1131 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 03 May 2009 - 04:02 PM
great work good update
#1132 scrumpymini
scrumpymini
  • 380 posts
  • Local Club: NSMOC
Posted 03 May 2009 - 05:13 PM
Hey good work, I can beat whats hiding under clutch/brake reservoirs, have a laugh at this.
Mine had a piece of metal bent in place to hide it !
#1133 analogue_radio
analogue_radio
  • 4,897 posts
Posted 03 May 2009 - 05:24 PM
Ohh wow never seen that before >_<
#1134 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 03 May 2009 - 08:56 PM
You're making me feel really lucky about how my bulkhead has come out but I think I'll wire wheel the lot before I get too giddy haha.
As per shock mounts. I've got a spare set kicking around here and I've also a pair of 1.5 negative camber arms I might want rid of. Drop me a PM if you're interested.
#1135 analogue_radio
analogue_radio
  • 4,897 posts
Posted 03 May 2009 - 09:01 PM
Are they the lowered type shock mounts? been looking at a set of Minispares & they are an inch longer to cope with the extra strain.
#1136 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 03 May 2009 - 10:45 PM
They're not I'm affraid.
No worries if you don't want them :(.
#1137 daveeeeee
daveeeeee
  • 684 posts
Posted 03 May 2009 - 11:13 PM
Keep it up dude!
Moss do UNF tap sets if you need em, dont know about dies =)
#1138 analogue_radio
analogue_radio
  • 4,897 posts
Posted 06 May 2009 - 08:27 PM
Got a tad bored tonight & with some inspiration from this video, video link.
I've decided I might make myself a new dashboard, if you remember I had one custom made by Bert with some speaker holes which were reinforced to take the weight, well I would much prefer a flat single sheet of thin MDF painted in black or covered in black faux suede, middle hole cut for the large MK1 speedo & evenly spaced holes cut either side for the smaller 52mm gauges.
I attempted a shoddy mock up from cardboard just to get a general shape, as you can see it's a mile off from how Nics looks in the video above, but it was just a quick idea.
& I also taped in the MK1 conversion plates and fixed the lights in, just for my own enjoyment, looks good huh? :(
#1139 analogue_radio
analogue_radio
  • 4,897 posts
Posted 07 May 2009 - 04:16 PM
Tiny update, day off college so I did both sketchbook work & mini work :wub: didn't get far though as I got stuck :gimme:|
Valve caps turned up, nice dub style :teehee:
Nearside hub off.
Hub on it's own.
Bottom of the farside off.
Couldn't get the top off :wub:
#1140 dezshearer
dezshearer
  • 441 posts
Posted 07 May 2009 - 08:39 PM
Get the correct imperial spanner on there, and give it a few taps with a big hammer, might break the rust.
Nice valve caps by the way!!
