& cheers about the valve caps
My Mini ;) The First Chapter.
#1141
Posted 07 May 2009 - 08:46 PM
#1142
Posted 07 May 2009 - 08:57 PM
nice dump valve
Good Work, keep it up!
#1143
Posted 08 May 2009 - 08:10 AM
#1144
Posted 08 May 2009 - 01:53 PM
What you on about James? 208hp turbo? dump valve?
That was the car in the vid, a 208hp mini with a dump valve, and he is turboing his mini and has a dump valve too, I think that is what he is getting at
#1145
Posted 09 May 2009 - 05:20 PM
Nice to see you getting on with it all! I'll rebuild my one, one day. Need to sort a job out, and get a runaround car for when that happens.
#1146
Posted 09 May 2009 - 05:30 PM
Payday this coming Friday! boy o boy I can't wait
#1147
Posted 10 May 2009 - 07:11 PM
Then spent the afternoon trying to get the bloody hub off.. but alas, no luck. Also decided that once the front subby is split from the engine I'm going to gather lots of bits I need cleaning and get them sandblasted, then I know they are 100% clean & rust free, ready to paint up.
Having trouble removing that nut and also the nuts holding the rear subby mounts on, have a look under Technical & Problems for the thread
So after that I decided to clean up the Clutch Servo, still needs more work but it's a big improvement!
#1148
Posted 13 May 2009 - 06:49 PM
#1149
Posted 13 May 2009 - 08:56 PM
#1150
Posted 13 May 2009 - 09:11 PM
Day off college tomorrow so I'll crack on with splitting the engine from the subby, will be a big update tomorrow providing I crack on, also payday on Friday which I've been desperately waiting for.
#1151
Posted 14 May 2009 - 03:15 PM
Things actually went according to plan today and I didn't encounter any hiccups!
Started off by angle grinding the swivel pin in the hub off, both sides top & bottom will be replaced in due time so it wasn't a problem.
Then I levered the driveshafts off using all sorts of tools, eventually they both slid out & poured oil all over the floor (which I forgot to remember would happen
I undid the lower engine mounts and with the help of a bloke doing some work on the road outside
Tilted the engine up to drain the oil, couldn't use the sump plug because the thread is stripped
Decided that the garage where I'd worked needed mopping out and cleaning, well I got carried away and did the whole thing
Payday tomorrow
#1152
Posted 14 May 2009 - 04:01 PM
good work ive had many debates with my mate tom and hes made me not bother with flip front so im probs gonna drop my engine this month and strip the engine, stubby and all the inner wings and make it all spot on so should be fun lol
good luck with the engine build
#1153
Posted 14 May 2009 - 04:16 PM
Won't be rebuilding the engine just yet, I'm just stripping down the ancillaries & painting up the block. Once she's back on the road I'll buy another 998 and rebuild that
I'm thinking a BMC green with black rocker cover and colour coded bits.
Oh and what is best to de-grease and clean the thing? Dad says petrol but that sounds a bit messy, ideally I'd want something that sort of foams up and clings on? less mess that way.
#1154
Posted 14 May 2009 - 04:22 PM
I've heard that that gunk stuff is pretty good for cleaning blocks up. Especially out of the engine bay lol.
Colour scheme sounds good, is that the old cooper scheme?
#1155
