Cam & porting the head sounds far too expensive at the moment!
Cheers Andrew
Posted 22 July 2009 - 05:18 PM
Posted 22 July 2009 - 05:37 PM
But we can talk about cams, just to put a bee in my bonnet
and so I can understand it all a bit more, what would I benefit from? I guess that if I upgrade the cam, I'd need to upgrade other things to cope?
Posted 22 July 2009 - 05:45 PM
Edited by AndrewJ530, 22 July 2009 - 05:50 PM.
Posted 22 July 2009 - 05:55 PM
Posted 22 July 2009 - 05:56 PM
No bother mate
Porting the head you can do yourself for freeas long as you have a decent drill to do it with that is.
Cheers,
Andrew
Edited by mini_mad69, 22 July 2009 - 06:02 PM.
Posted 22 July 2009 - 06:10 PM
Edited by 1275 SPRITE, 22 July 2009 - 06:13 PM.
Posted 22 July 2009 - 06:22 PM
You shouldn't have to fit drum brake screws, most good duplex sets come with special screws in the kit.
I think £200 for a cam is way over the top, MED sell cam KITS, their "phase 2" kit includes a piper cam of your choice (i'd go for a 276 personally), a new oil pump, new followers AND a vernier adjustable duplex timing set, which is everything that people have mentioned changing and all that lot is £175.
I dont agree that you wont notice the difference unless you port your head, it purely depends on what profile cam you choose.
An £80 dremmel is not needed to port a head, the heads I've ported have been done with flapwheels that can be bought from hardware stores for a few quid and come in different grades.
I ported a 998 head for Dan a while ago, and on a cheap head to experiment I opened it up too much and went through into a pushrod hole, so you have to have a good idea about what your doing.
as long as you have a decent drill to do it with that is. Dremel's cost about £80 if you don't have a drill. But the cam could cost you close to 200 squids for the kit.
Edited by AndrewJ530, 22 July 2009 - 06:24 PM.
Posted 22 July 2009 - 06:44 PM
Edited by 1275 SPRITE, 22 July 2009 - 06:44 PM.
Posted 22 July 2009 - 06:47 PM
Posted 22 July 2009 - 07:29 PM
I never said adding a cam on it's own wouldn't add power
, I just said combined with a head, it would be even better
Posted 22 July 2009 - 07:40 PM
Posted 22 July 2009 - 07:52 PM
Posted 22 July 2009 - 09:25 PM
Agree, but a head could be done at a later date?
Posted 22 July 2009 - 09:47 PM
Posted 23 July 2009 - 12:32 PM
