My Mini ;) The First Chapter.
#1321
Posted 21 July 2009 - 09:25 PM
Why are you splitting the two anyway?
#1322
Posted 21 July 2009 - 09:43 PM
I need to get the sump plug helicoiled so my logic was that if I split the two, a) it'd be so much easier in getting the gearbox to the garage & b) i can flush out any debris from the gearbox and generally make sure everything is nice and tidy.
Thanks again for the flywheel puller James!
#1323
Posted 21 July 2009 - 09:46 PM
#1324
Posted 21 July 2009 - 09:53 PM
#1325
Posted 21 July 2009 - 10:09 PM
What ever you do, do not jam anything between the two mating faces of the gearbox and block as you could damage them meaning oil leaks. I think there is a way of levering using the engine mounts on the gearbox. You could try putting the engine upside down so it is gearbox up and tap around the edges with a rubber mallet to try and break the seal.
Edited by GreaseMonkey, 21 July 2009 - 10:09 PM.
#1326
Posted 22 July 2009 - 12:07 AM
As said don't try leavering the engine off the box using the mating surfaces as they will leak oil.
Another thing I do is hang the engine about 5-10mm off the deck, and then tap the gearbox off with somthing like carpet or cardboard for it to land on.
Ben
#1327
Posted 22 July 2009 - 02:12 PM
They aren't perfectly clean and degreased, but I don't want them that way.. it's a rally styled car so a bit of tidy oil here and there is more than welcome
They've been left out to dry, will make sure they are both dried out throughly.
I've come to a halt, minispares emailed me and told me the cone compressor was out of stock.. so I told them to cancel the order and I'll put a new one through with some other bits when I get back.. clutch, oil pump & other assorted bits that I've since discovered I need to buy since breaking the engine a bit more.. little things like new bolts & gaskets.
Don't think there is going to be any more process until I come back from Centre parcs on the 31st, then I get paid again on the 7th
Pictures!
#1328
Posted 22 July 2009 - 03:17 PM
#1329
Posted 22 July 2009 - 03:26 PM
#1330
Posted 22 July 2009 - 04:17 PM
Ben
#1331
Posted 22 July 2009 - 04:34 PM
Oh god yes, I'm so tempted to go all out and spend a good few months wages on making her a feisty little 998cc, but I'm afraid I can't at the moment.. I'd much rather spend that money on getting her on the road quicker!
But we can talk about cams, just to put a bee in my bonnet
#1332
Posted 22 July 2009 - 04:42 PM
always things worth doing cam followers, timing chain, oil pump but again down to budget and what ur after 1.3 ratio rockers are good on 998's
#1333
Posted 22 July 2009 - 05:01 PM
other than some stiffer springs not really
1.3 rockers wont make much difference on a 998 like luke's spec. Infact they probably wouldn't make that much difference on a 1275 but that's not the question in hand. Followers, pump and duplex are a good upgrade. Not neccesarily needed but worth doing if you've got the engine apart.
Edited by AndrewJ530, 22 July 2009 - 05:02 PM.
#1334
Posted 22 July 2009 - 05:08 PM
& cam followers? I presume they just need replacing for the sake of wear?
#1335
Posted 22 July 2009 - 05:15 PM
Yeh, it's just for wear on the followers.
If you are going to go to the trouble of putting a cam in then you mayswell port your head. Wont see too much of a difference with just the cam and without the head to match. Vizard has all the info on head porting.
