plus if you swpeak nicely to Brumski he might get you a map that is ok for initial driving and setup
Roofless... would be happy to fire the map I have over to you for YOUR use only, bearing in mind this thing has cost me the best part of £260 already and it's only mapped to 5K rpm and the cold start is way off... so still more work/money to go but need to run it in first.
In fact, I have MAJOR problems when it first went in... the map supplied by Exon was soooooo out and dumping that much fuel in there it was choking the engine... in fact Pip suggested that the amount of fuel could have been washing the bores of oil and lead to damage.
If the ECU used on the dyno was not the one supplied to you but rather a test unit of Exon's then there's every possibility you had the same map as the one I got that Paul loaded onto the ECU whilst I was there.
threads on efiminis are great reading and the videos of brumski's are awesome.
Thanks matey - it's been an uphill struggle and I've missed every date I wanted it for but hey ho... Still got one or two problems to overcome but hitting them one by one. At least it goes though... and with some luck it'll be on the Wirral to Llandudno run and Bingley Hall in January.
I've sent you a PM for discussion matey...
Carl.
