Ed's Mk1 Morris Cooper
#136
Posted 20 February 2009 - 06:22 PM
Your project is great! An inspiration for me to go out and buy more tools and restore mine myself. Keep up the great work!
#137
Posted 24 February 2009 - 09:16 PM
I didn't get any work done on the Mini over the weekend so it's been a whole week since I've done anything. This evening I finished the grinding as shown below. The quality of finish is ok but you can see and feel the repair slightly, which means its slightly off the standard I'm looking for as a skim of filler will be required in this area.
I also managed to start on the other side. On this side I'm going back to my method of weld a bit... grind a bit.... weld a bit... grind a bit. Instead of weld the whole lot... then grind the whole lot. Its a method that takes longer but I always end up with a high quality finish as my grinding can be more accurate. I think I've got to work using this method for the whole of my project now.
Edited by edi57, 24 February 2009 - 09:17 PM.
#138
Posted 24 February 2009 - 09:24 PM
#139
Posted 24 February 2009 - 09:33 PM
I think it's been almost one year exactly since the shell was stripped. It's been kept in our dry (but not heated) garage the whole time but still it has got surface rust where moisture can collect.
It doesn't really bother me if rust does form because the shell will be dipped again (then e-coated) when I have finished my work.
Where did you get it stripped, also how much did it cost? I have just got a shell and I need it stripped.
#140
Posted 24 February 2009 - 09:41 PM
The shell was acid dipped by Surface Processing in Dudley. More details about the acid dip are here. It's not cheap, but if you're looking to do a restoration to the highest standard then I would highly recommend it.
#141
Posted 24 February 2009 - 11:44 PM
You have a cracking project going there !! Im learning lots just watching your pictures. Cant wait to see whats next.
AWESOME WELDING
Will
#142
Posted 25 February 2009 - 07:08 AM
Thanks for that, I thought it had to be SPL.
Cheers, and great project!
#143
Posted 25 February 2009 - 09:25 AM
That copper seems to work great as a heatsink, great idea.
#144
Posted 25 February 2009 - 11:12 AM
Anyway enough with the nice comments, POST MORE UPDATED DAMMIT!
#145
Posted 25 February 2009 - 05:35 PM
I SECOND THAT !! !! !!
Edited by AuDix, 25 February 2009 - 05:37 PM.
#146
Posted 25 February 2009 - 05:40 PM
#147
Posted 25 February 2009 - 05:46 PM
#148
Posted 25 February 2009 - 07:07 PM
#149
Posted 13 March 2009 - 06:32 PM
#150
Posted 19 March 2009 - 09:45 PM
Sorry for depriving you all of updates.
I have been working on the Mini regularly, but not spending enough time on it just due to so many other things going on around me.. as always seems to be the case!
Also buying this didn't help either....
After borrowing Petes' unicycle over Christmas and finding out how fun it is I decided to get one of my own.
Anyway, I got the other side all welded up and ground back as you can see here...
So, all I had left to do after that was fully spot weld all of the seams. I thought this was going to be the easy bit as I have a proper spot weld. BUT, as the vertical seams require so many spot welds it's been taking absolutely ages and really boring me loads. The spot welder can do about 3 spot welds before it heats up too much. I then have to let it cool because otherwise the soft copper electrodes go even softer and they wear away too quickly.
Anyway, I finished all of the spots on the left hand seam on Sunday and I have been doing a few spots per day on the right hand seam this week. The right hand seam only requires about 6 more spots now. So basically consider the rear panel done!
If I'm lucky I'll have some free time on Sunday to spend working on the Mini. So work will start on a new panel!
