#16
Posted 05 May 2012 - 05:43 PM
Might sell the 100+ alloys, anyone know what they are worth?
#17
Posted 06 May 2012 - 09:35 PM
- choke cable
- cd player wiring
- shock absorbers subject to weather
#18
Posted 07 May 2012 - 02:19 PM
Everything wired up directly to switched live, scotch locked into ignition wires.
So new blade fuse box installed for accessories....
top blade now perm live 10amp to radio/cd player
second one 10amp switched live to radio/cd player
third one 15amp switched live to fuel pump circuit
forth one 15amp switched live to dual 12v cig lighter sockets.
Sony headunit installed, cage doesnt fit the dash very well and I hate noises, so touch wood its gunna be secure and not sweak/rattle.
Speaker wires re-run to 6x9s that were allready in the parcel shelf.
then gave it a quick wash
Oh and replaced the choke cable, that was the first job, wasnt too bad....had worse ones.
Jordie
#19
Posted 07 May 2012 - 07:18 PM
#20
Posted 07 May 2012 - 07:26 PM
for me they ruin the car :/
#21
Posted 07 May 2012 - 07:28 PM
Im thinking about fitting a back bumper tho....
#22
Posted 07 May 2012 - 07:36 PM
thought about it, but the wings have been drilled about 1inch higher than the standard lip, so id be left with several holes in each wing/quarter.
awww noooo,
the bumper should be easy enough with some brackets :)
#23
Posted 07 May 2012 - 07:40 PM
Not sure on the arches, depends what I can do with the holes left. Sportspack copies would probally cover em, but i dont really want sportpack.
#24
Posted 08 May 2012 - 09:31 PM
I think refitting the bumper would improve the rear. Have you thought about wide group 2 arches? Are you taking this to the MetroCentre meet tomorrow night (wed 09/05) Jordie?
Alex.
Edited by Pedal Pusher, 08 May 2012 - 09:31 PM.
#25
Posted 09 May 2012 - 05:23 AM
U coming to NERC open day on sunday?
#26
Posted 09 May 2012 - 06:36 PM
Opened it up, full of water.
Replaced with a good working one, added a little grease to mechanism and working again but no "fast" speed, guess its an older wiper motor. but better than non.
Jordie
#27
Posted 09 May 2012 - 08:03 PM
#28
Posted 09 May 2012 - 09:30 PM
im usually down the NERC wednesdays as thats the night I work on my project, so probally not.
Yeah, nearly forgot about this show! I'll bring the supercharged Mini and 'longtimenomini' might be attending with his Clubman estate. Keep 2 spaces for us!
No doubt i'll see you walking around policing the field in a high vis jacket!
I'll do some obligatory tyre kickin' on this Mini!
Alex.
Edited by Pedal Pusher, 09 May 2012 - 09:30 PM.
#29
Posted 10 May 2012 - 05:28 AM
I wont be doing no high vis policing, just gunna take a chair and enjoy seeing some old cars.
#30
Posted 12 May 2012 - 05:38 PM
Washed car afterwards, found water dripping from heater hose inside. Looks like its coming in bonnet, on bulkhead and down the NS heater pipe. This is because previous owner cut away the "rain channel" at the top corners of the bonnet to fit bonnet locking pins as the bonnet is "lift off". I may have to knock something up to remake the channel.
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
