yep its great when they stand up by themselves.
I Decided It Was Time To Drag The Race Car Out And Update It.
#436
Posted 27 May 2018 - 08:13 PM
#439
Posted 31 May 2018 - 08:25 PM
well as you may have seen i fitted the common a garden spring kit brackets but i was not too sure as they are designed to have the spring mounted between the uprights.
here is what i had on the car before. some very early Proto parts from Huddersfield Mini Spares (as he was back then)
so as you can see the long piece is just a spacer both end pieces fitted to allow clamping forces.
so todays job.
#443
Posted 02 June 2018 - 11:35 PM
had to get the wind machine on today.
sorting out some cables while having a bit of Macgyver on the screen
fitted a remote starting button as some of you might know starting a race engine when you are not sat in the seat can be a bit of a dance.
also finally got around to fitting the switchs i ordered last year from Wired by Wilson. currently it seems i only actually needed one.but i think i will have it sorted tomorrow with a single wipe as well as continuous wipe and park.
just need to apply what i put last time, had issues getting the motor to move this time.
so motor is M8
control relay K30
ignition live BKVT (park function power
BU trigger and continuous running
relay to be replace by switches.
main OFF/ON/ON as i do not want a live up front if not doing anything. (would be cut off by big switch anyway)
First On will activate BKVT wire and also go to a OFF/MOM switch to the BU wire to give a wipe and park.
Second ON will give continuous wipe via the BU and park when turned off one click.
#444
Posted 03 June 2018 - 08:50 PM
main wiper switch top position all off. Mom will move wiper as long as it is held.
main wiper switch center park circuit "live" Mom will make a single wipe and park.
main Wiper switch bottom position wiper will work until center position where it will park.
https://youtu.be/gIPq3_tG77c
#449
Posted 17 June 2018 - 10:31 PM
#450
Posted 17 June 2018 - 11:36 PM
What are they for?
sorry you will have to wait till next weekend for that.
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 roundnose |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 roundnose |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 roundnose |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 roundnose |
Projects →
Mini Saloons →
1968 Mk2 Cooper BuildStarted by Minime998 , 15 Sep 2021 roundnose |
