I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
878 replies to this topic
#706 nicklouse
  • 17,945 posts
Posted 15 March 2020 - 11:04 PM
oh and i fitted the new steering rack and front subframe rear mounts.
no pics.
#707 imack
imack
  • 1,873 posts
Posted 16 March 2020 - 06:09 AM
i did not take this picture for any reason but looking at it now that might just be a crack
needs a closer look.
That does look like a crack.
I found a similar crack in my Longman GT15 head when I rebuilt the engine a few years ago.
Edited by imack, 16 March 2020 - 06:25 AM.
#708 nicklouse
  • 17,945 posts
Posted 16 March 2020 - 11:32 PM
had another look before work.
it sounds like it should be sortable now unlike 20 years ago.
#709 imack
imack
  • 1,873 posts
Posted 17 March 2020 - 06:00 AM
I'd be interested to find out if yours is salvagable, I was told mine wasn't, but yours does appear to have a little more meat between the seats than mine.
#710 nicklouse
  • 17,945 posts
Posted 21 March 2020 - 07:11 PM
well while the engine situation is in limbo lets get on with the other things.
done
#711 nicklouse
  • 17,945 posts
Posted 22 March 2020 - 06:52 PM
just need to finish the welding when it is not on the tralier
#712 sonscar
sonscar
  • 2,724 posts
Posted 22 March 2020 - 09:40 PM
Nice car.Are you worried about flex.I would possibly have liked some triangulation,but I am not able to "feel" the install in with.Liking your work.Steve..
#713 nicklouse
  • 17,945 posts
Posted 22 March 2020 - 10:07 PM
nah. not going anywhere it is CDS tube 38mm and a good wall thickness. way way stiffer than the OE stuff and what i had before. (read roll cage tube that i had left over).
#714 nicklouse
  • 17,945 posts
Posted 30 March 2020 - 07:33 PM
well the head will live another day. as will the cam now to get some parts ordered so the build can get done.
#715 nicklouse
  • 17,945 posts
Posted 01 April 2020 - 12:33 AM
next job the red thing
#716 nicklouse
  • 17,945 posts
Posted 02 April 2020 - 08:42 PM
not much happened today, routed the new pull cables for the red thing then i had a delivery was surprised at how big it was.
should have read the specs better. just read 25 pieces not the sizes
and some stubbies as they were cheap
then i started on the gearbox build but did not get to far as there is no info as to where this washer/spacer fits. there is a 50/50 chance of it going in the right place but i am not taking the risk.
then i spwnt a few hours looking for the steering wheel nut. it is somewhere safe but not where i have looked or it has been thrown out.....
#717 nicklouse
  • 17,945 posts
Posted 03 April 2020 - 06:06 PM
box together just waiting on a few bits to finish it off.
the pinion support housing points to note.
the bottom right  mounting to the support has a different thread than the original so needs a replacement stud/bolt original casting was UNC and the support is UNF
also will not work with a lower steady.
#718 imack
imack
  • 1,873 posts
Posted 03 April 2020 - 07:20 PM
Looks great, where did the washer/shim fit?
#719 nicklouse
  • 17,945 posts
Posted 03 April 2020 - 07:37 PM
Right side of reverse  Gear when diff is in front of you.
#720 nicklouse
  • 17,945 posts
Posted 05 April 2020 - 08:38 PM
why did i put splitpins back into brake and clutch pins......
still not got round to doing the Fire suppression system as i need to make sure the new brake routing works with all.
fitted the catch tank as well.
