Start From Scratch
roundnose
103 replies to this topic
#16 davefitz
davefitz
  • 80 posts
Posted 01 June 2016 - 07:11 PM
The 'I over did it' subframe:
#17 davefitz
davefitz
  • 80 posts
Posted 01 June 2016 - 07:13 PM
Not sure what to do with this subframe yet, think I'll have to weld up the holes:
http://www.theminifo...tening-too-far/
#18 davefitz
davefitz
  • 80 posts
Posted 01 June 2016 - 07:16 PM
Me dash,
Covered it in flooring underlay foam from DIY
Then black leather/vinyl same as new interior:
#19 davefitz
davefitz
  • 80 posts
Posted 01 June 2016 - 07:21 PM
Plumbing diagram:
#20 davefitz
davefitz
  • 80 posts
Posted 01 June 2016 - 07:27 PM
I used to have the servo only assisting the front with a tandem master cylinder setup which worked great and there was still lots of breaks at the rear but im told that it should go to both front and rear and then use the bias valve just on the rear split. this is the setup I am going for now:
Image care of this tasty build
http://www.turbomini...p=vt&tid=381837
#21 davefitz
davefitz
  • 80 posts
Posted 01 June 2016 - 07:47 PM
I finished the dash during the winter but some of the vinyl is lifting already so will have re-stick it when the time comes to put it in. I used some cheapo spray adhesive and should have used evostick I think? it might have reacted with the foam underlay.
The naff ignition start button is getting replaced with something more tasteful, maybe a little black switched panel in keeping with works mini style.
#22 davefitz
davefitz
  • 80 posts
Posted 01 June 2016 - 07:57 PM
I love all the old works style so want to incorporate it in a small panel somehow, maybe like this:
Screen%20shot%202016-06-01%20at%2020.55.
#23 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 01 June 2016 - 10:14 PM
The glue on the dash:
When you re glue it get high temp spray adhesive. Else when the inside of the car gets hot in the summer it will lift/sag etc.
Trim fix is very good.
http://www.ebay.co.u...HIAAOSw7ThUic0W
#24 Rocket.
Rocket.
  • 1,444 posts
Posted 01 June 2016 - 10:28 PM
Nice project !
#25 james_k
james_k
  • 15 posts
Posted 02 June 2016 - 08:05 AM
Loving the amount of pictures you're posting. Gives me real inspiration to crack on with mine. Can I ask as well, did you already know how to weld as some of them are pretty good!
#26 davefitz
davefitz
  • 80 posts
Posted 02 June 2016 - 02:27 PM
Thanks Rocket, James_k years ago i did a 3 week course in basic welding so just trying to remember the skills,
This site has been great help also:
http://www.mig-welding.co.uk/forum/
thanks for your comments,
Dave
#27 CowmanCal
CowmanCal
    Starting My Mini Up
  • 1 posts
Posted 10 July 2016 - 06:49 PM
Onto the roll over Jig rotisserie I made thanks to plans on TMF! :)
And we're off!
#28 g111mds
g111mds
  • 432 posts
Posted 10 July 2016 - 07:40 PM
Nice project, and great progress!!!
#29 davefitz
davefitz
  • 80 posts
Posted 24 September 2016 - 03:00 PM
Hi all,
Good news is that I managed to get a good few days of stunning weather last week for blasting. Andrew behind Dennings Cars in Tallaght took the job on and cant believe what an amazing job he did. Andrew - 085 811 9733
#30 davefitz
davefitz
  • 80 posts
Posted 24 September 2016 - 03:11 PM
And then straight into Liam Denning and on with the Rustbuster Epoxy Mastic and the Custom Epoxy 421. Products went on like dream apparently, Epoxy Mastic takes a good bit of time compared to the 421. It can be thinned up to 15% for spraying and used a 1.8 tip. More pics of finish to follow. The Mastic is a much better finish than I thought it would be as I thought it would be rougher. It has hardened like rock!
