Getting The Rose Family Mini Back On The Road! (After 5 Years)
roundnose
297 replies to this topic
#46 imack
imack
  • 2,382 posts
Posted 21 June 2019 - 08:37 AM
Don't know if mpi's are like earlier cars where the head lamp harnesses joint to the main harness behind the grille by the bonnet latch. These are bullet connectors on earlier cars, unplug and pull the buckets complete with harnesses through the inner wing/front panel hole, then remove the harnesses from the headlamp buckets.
#47 Ben Rose
Ben Rose
  • 210 posts
Posted 21 June 2019 - 09:18 AM
Thanks for your ideas however I think the MPI must be different. I have the buckets off with a small section of the loom still attached.
It must be a late MPI thing I guess as there is a multiplug connector just within the wing which you disconnect and it allows the bucket to come off but you still have a short piece of wire attached.
So I either have to disconnect the grey multiplug or the indicator bulb end.
I think I may just have to heat the solder up to release the bulb connector, UNLESS someone knows how to get the wire out of the multiplug end.
The black connector which goes on the headlight just has spade connectors which I can slide out with the help of a small flat blade screwdriver. Cant see that on the grey end.
48101677688_409473bb03_k.jpg[url=https://flic.kr/p/2g...20190620_201410[/ur]
#48 cooperd70
cooperd70
  • 793 posts
Posted 21 June 2019 - 10:05 AM
Whatever you do drill the rivets out of the VIN plate and transfer. That also goes for the metal plate on the inside of the wing that you highlighted in one of the other pics. This has the paint and trim codes for the car on it.
With the detailed pics you are posting this is going to be a great build thread to inspire others ?
Keep up the good work Ben.
Edited by cooperd70, 21 June 2019 - 10:06 AM.
#49 Ben Rose
Ben Rose
  • 210 posts
Posted 21 June 2019 - 10:09 AM
Thank you -  :thumbsup:
#50 panky
panky
  • 1,853 posts
Posted 21 June 2019 - 12:37 PM
There's also the  VIN stamped in the rain channel on the scuttle. If you are replacing the panel then you could cut the section out of the old one and weld it into the new. Bit of a faff but could be done for completeness.
#51 Ben Rose
Ben Rose
  • 210 posts
Posted 21 June 2019 - 01:11 PM
Great advice.  The scuttle is more rust than metal so I just hope it still exists.  I'll have a look for it tonight.
#52 cooperd70
cooperd70
  • 793 posts
Posted 21 June 2019 - 01:52 PM
Don't quote me, but I thought that there was only one VIN plate on a mini. Yours (MPI) should be in the rain gutter of the scuttle panel (as per later cars), but looks to have been relocated to where its normally found on earlier cars. Mines a 1990 and is found on the left-hand side of the slam panel where yours currently is. Perhaps it has already had the scuttle replaced by a previous owner and was relocated then.
#53 Ben Rose
Ben Rose
  • 210 posts
Posted 21 June 2019 - 02:28 PM
The plot thickens!  I am 99% sure the scuttle has never been touched.  I will take a look tonight on the scuttle for any signs of VIN.
#54 panky
panky
  • 1,853 posts
Posted 21 June 2019 - 03:12 PM
My '91 Cooper has the plate on the inner wing and the stamping in the rain channel, both showing the VIN
The number stamped in the rain channel is about a third of the was across from the drivers side.
Edited by panky, 21 June 2019 - 03:15 PM.
#55 cooperd70
cooperd70
  • 793 posts
Posted 21 June 2019 - 03:26 PM
Like I said....don't quote me ? Never having owned a later car didn't realise that the plate was in both locations ??
Edited by cooperd70, 21 June 2019 - 03:27 PM.
#56 panky
panky
  • 1,853 posts
Posted 21 June 2019 - 03:35 PM
Like I said....don't quote me Never having owned a later car didn't realise that the plate was in both locations
Quoted you  ;D
#57 Ben Rose
Ben Rose
  • 210 posts
Posted 21 June 2019 - 06:14 PM
So I have a w reg mpi. There is a rover black and white plate on drivers side inner wing, a riveted plate on the front panel near the bonnet catch and lastly a number stamped into the rain Gutter in the scuttle as panky said.
#58 cooperd70
cooperd70
  • 793 posts
Posted 21 June 2019 - 11:03 PM
#59 Ben Rose
Ben Rose
  • 210 posts
Posted 25 June 2019 - 07:47 AM
Did a few more bits last night.  Blew up the tyres too so it will be easier pushing it in and out of the garage when I come to remove the doors.
Front Fog and Main Beam connectors before Removal.
48122404781_b6896253a0_c.jpgIMG_20190624_195512
48122348966_d561e40135_c.jpgIMG_20190624_195516
48122385378_af0ac69c8b_c.jpgIMG_20190624_195529
48122385263_361585c163_c.jpgIMG_20190624_195536
Wing Mirror Removal. (More rusty screw heads)
48122384598_d3d3fa0a55_c.jpgIMG_20190624_195836
Front Fog and Main Beam fuse box removal. I am trying to photograph as much as possible as I don't know when I will be reconnecting this stuff again.
48122384153_1b24d3fd49_c.jpgIMG_20190624_202939
48122346211_8c2f9b52d8_c.jpgIMG_20190624_203112
48122382648_8348e98b6d_c.jpgIMG_20190624_203354
48122344976_80de905652_c.jpgIMG_20190624_203358
Me trying to label connectors on the wiring loom. I think I will have to improve my labeling method.
48122441457_ab8152726d_c.jpgIMG_20190624_203723
48122382198_f137d69d8f_c.jpgIMG_20190624_203727
48122443207_c3c9e4008b_c.jpgIMG_20190624_202949
48122346901_705df1d7fd_c.jpgIMG_20190624_202947
48122383918_7244bb5292_c.jpgIMG_20190624_202944
#60 Ben Rose
Ben Rose
  • 210 posts
Posted 25 June 2019 - 08:28 AM
VIN Number locations on MPI Mini
Stamped number directly into rain channel on scuttle.
48125197311_03c4f63a34_b.jpgIMG_20190621_190804
Rover ID Plate riveted into drivers side inner wing.
48125226673_33f0974cca_b.jpgIMG_20190621_190757
Number riveted onto small plate on top of Front Panel.
48125197501_d9d84f617e_b.jpgIMG_20190621_190744
