1979 Mini Ebony With Sc Injection
roundnose
56 replies to this topic
#1 fokko
fokko
  • 195 posts
  • Local Club: Mini Seven Club Nederland
Posted 27 November 2019 - 09:53 PM
Hi,
I have been into Mini's since 1999 and I have owned 3 of them, until in the beginning of this year (Feb. 2019)... At that time I owned a 1983 1000 HLE which I have owned for almost 20 years and it was quite nice, but it had quite some bodywork issues (and an accident damage history), which I didn't want to attack. Here it is:
Attached File  hle.jpg   94.38K   4 downloads
I was in search of a better bodyshell with less work (to make it to showroom condition) and preferably 40 years old, or older. After a while I found a semi-barnfind. A Mini Ebony built in 1979 which hadn't been touched for more than a decade. It sat in a real barn under a pair of sheets. I made an appointment with the owner who was in a hurry to sell it, because the barn was going to be sold. The Ebony had some minor repairs to the bodywork, but was structurally sound and looked like a very good basis to build up a new Mini. This is it:
Attached File  ebony01.png   493.78K   4 downloads
I figured I could sell the standard running gear it came with and move all my fancy running gear from my HLE over to this one. After that I would sell the HLE, to have some funds to get the Ebony completely restored.
This is what happened since Feb 2019: I bought the Ebony and pulled out the running gear (engine, fuel tank etc) and interior, bought some stuff like a standard exhaust, new clutch, waterpump etc. I built up the HLE with this stuff and I bought some additional wheels (Exactons with Yokohama A008 tyres). Put the Exactons with the Falken tyres I had on the HLE and put my GB 10x6's and Yokohama tyres aside for the Ebony. Mid-October I sold the HLE to a happy new owner with a new MOT.
Attached File  hlesale.jpg   86.58K   9 downloads
Finally it was time to make a start with the Ebony. The specs are/will be as follows (still subject to change;)):
  • Color will probably be a RAL color called Dove Blue (saw this Mini Miglia of Mr. Porter and liked it a lot), still doubting about a different roof color, black or white
    Attached File  portermiglia.jpg   128.14K   6 downloads
  • GB 10x6's with Yokohama A008 tyres
  • MPI interior, probably re-upholstered
  • Newton Commercial new carpet set
  • Burr-walnut 6 clock dash (including oil pressure, oil temp and volts or clock)
  • My current MED 1330 A+ engine
  • CalverST CST2001 cylinder head
  • CalverST 1.4:1 rockers
  • CalverST RE13OT camshaft
  • Specialist Components 5-port EFI kit
    Attached File  sckit.jpg   43.01K   12 downloads
  • Maniflow medium bore LCB
  • Single box side exit Maniflow carbontec silencer (had this for ages, is pretty rare now and sounds awesome!)
  • Standard A+ gearbox
  • Fully adjustable suspension
    • Adjustable bottom arms
    • Adjustable tie-rods
    • Genuine hi-lo's
    • Adjustable rear camber/toe brackets
  • New rubber suspension cones
  • All new subframe/suspension rubbers
  • MPI Injection tank with new pump/filter
  • (Brackets for) rear seatbelts, so I can take my kids around as well
  • Lots more, but the list is getting too long
The "shed" I'm working in is the garage attached to our house. It is heated and isolated, so it's a great place to work, even during winter time. I have 8 led bars attached to the ceiling which give a huge amount of light. This picture was taken a while ago, it's a bit more organized now...;
Attached File  shed.jpg   35.97K   16 downloads
I will try to post frequently on updates, but I also have a daughter of 2 years old and the second one is on the way... So I need to find time...
#2 fokko
fokko
  • 195 posts
Posted 01 December 2019 - 02:07 PM
OK, so a new update on what happened the past month or so. First I would like to mention that I'm planning to do a "dry-build" first, to make sure everything works. Then I'll take it apart again and will have it prepared and painted. That will also be the time I'll refurbish all parts. Chassis parts will be black mostly and I'll be buying a zinc plating kit to treat all bolts and nuts. I already have a media blast cabinet and a parts washer to be able to prepare the parts.
This is my current engine; a MED prepared 1330cc A+:
Attached File  20191020_112500687_iOS.jpg   83.92K   3 downloads
I had to remove the current head (MG Metro, leaded), to do some measurements. After I removed the head, I inspected it and found out some of the valves were quite recessed in their seat, even though I have been using lead substitute;
Attached File  20191110_203950550_iOS.jpg   70.34K   2 downloads
Attached File  20191110_204001151_iOS.jpg   64.98K   2 downloads
Also, after removal of some of the valves, I discovered a crack (which they seem to be able to fix when putting in hardened seats) between inlet and exhaust valve.
Attached File  20191114_192850937_iOS.jpg   56.75K   4 downloads
As I'm buying a new (modified) cylinderhead, I needed to know the current piston-to-deck height, so the chamber size could be matched. It appeared the piston currently is 0.51mm below deck, which is too much. I decided having the block machined down to 0.25mm piston-to-deck height so there is still room, if there is a need at some point. In the picture I marked the space with a red line;
Attached File  20191020_112950610_iOS.jpg   49.92K   3 downloads
One of the shiny new bits I wanted to try and fit was the ignition blanking plate, too bad it didn't fit out of the box. But I made a good arrangement with the manufacturer...
Attached File  20191114_195102183_iOS.jpg   53.21K   5 downloads
After an exchange head was sent to the supplier of the new head, I started with the dismantling of the standard suspension, which went pretty well;
Attached File  20191114_211416681_iOS.jpg   43.91K   3 downloads
When taking out the upper suspension arm, I discovered the pin was badly worn, probably due to insufficient grease somewhere in the past. Luckily I have a replacement in stock :);
Attached File  20191125_212458523_iOS.jpg   44.94K   3 downloads
I mounted my adjustable bottom arm with offset rubbers and an adjustable tie-rod with rubber/polyflex combo bushes. I had a set of Boge shock absorbers, so I put those on for the time being. Not sure if these are ideal in my situation. I also installed a new rebound buffer and bump stop;
Attached File  20191123_150119284_iOS.jpg   66.39K   1 downloads
I also put the new suspension cone in place (somewhat), including the Hi-lo. Then it was time to take a look at the steering rack. It looks like the arm is somewhat worn. With a bit of encouragement, they will fall down. I need to take a look if I can still adjust this one or if I need to fit a new steering rack. I happen to have one lying around;
Attached File  20191125_214401034_iOS.jpg   40.14K   1 downloads
Next time, some more pictures on the upper suspension arm rebuild and hopefully some progress on the steering rack.
#3 fokko
fokko
  • 195 posts
Posted 05 December 2019 - 09:21 PM
I figured I was going to replace the steering rack anyway, so I pulled out the steering column (sheer bolt didn't break off! :thumbsup:).
Attached File  20191203_205105847_iOS.jpg   65.14K   3 downloads
The u-bolt nuts came off pretty easily;
Attached File  20191203_210629070_iOS.jpg   93.81K   5 downloads
Attached File  20191203_210637281_iOS.jpg   79.3K   3 downloads
Put the jack stands on a terrible position in order to be able to lower the subframe to be able to remove the steering rack.
Attached File  20191203_212621821_iOS.jpg   61.74K   1 downloads
Then I received a very cool package...
Attached File  20191204_174744122_iOS.jpg   86.59K   3 downloads
Containing the new 1.4:1 solid steel rocker arms, steel posts and thick wall rocker shaft;
Attached File  20191204_175253008_iOS.jpg   77.78K   4 downloads
An RE13OT camshaft;
Attached File  20191204_175815750_iOS.jpg   59.28K   2 downloads
And a modified head;
Attached File  20191204_180213097_iOS.jpg   92.14K   1 downloads
With quite some port work done;
Attached File  20191204_180331379_iOS.jpg   38.77K   2 downloads
And chambers of the right size;
Attached File  20191204_180450299_iOS.jpg   80.76K   3 downloads
Put all of the nice new toys on the shelf and continued with the undercarriage. I bought a new tool to pull the CV joints and it works like a charm! Better than hammering the joints away from the shaft. The shafts that came with the Mini were the thicker ones which I can use with the disc brake CV joints;
Attached File  20191205_154955391_iOS.jpg   78.31K   7 downloads
And the new joint getting in place;
Attached File  20191205_160938794_iOS.jpg   56.45K   3 downloads
#4 fokko
fokko
  • 195 posts
Posted 22 December 2019 - 05:01 PM
Small update again, did some more on the front suspension. Determined that it would be better to completely refurbish the parts that have bearings in them, like the top arm and the swivel hub. So I'm going to order some Bilt Hamber Epoxy Mastic and Electrox to treat them after removing rust using either Deox-C or my blast cabinet. Too bad I was too late for the top arm...
Painted the CV-joint and mounted the rubber gaiter;
Attached File  20191213_203152759_iOS.jpg   40.89K   1 downloads
Top arm more or less complete;
Attached File  20191214_145158309_iOS.jpg   54.12K   1 downloads
Mounted in the subframe;
Attached File  20191214_155303270_iOS.jpg   54.02K   1 downloads
Side view;
Attached File  20191214_155309875_iOS.jpg   47.75K   1 downloads
Then I needed to remove the steering arm and joints from the old hub to use them on the new one, but removing them seemed not very easy;
Attached File  20191221_133210392_iOS.jpg   67.41K   1 downloads
Removed lower joint which is not in a reusable state;
Attached File  20191221_133213952_iOS.jpg   66.04K   2 downloads
Top one is, this picture is after cleaning it in the parts washer;
Attached File  20191221_133225716_iOS.jpg   59.17K   2 downloads
Steering arm before cleaning;
Attached File  20191221_134847740_iOS.jpg   78.31K   1 downloads
After cleaning, but the bolts didn't come loose, so I had to remove the brake drum and backplate (not enough room for a socket);
Attached File  20191221_135245228_iOS.jpg   76.27K   1 downloads
Took off drum & hub (hub was corroded to the bearing inner race);
Attached File  20191221_140546536_iOS.jpg   63.5K   1 downloads
What remained;
Attached File  20191221_140555608_iOS.jpg   53.92K   1 downloads
Backplate came off pretty easily;
Attached File  20191221_141446478_iOS.jpg   41.77K   1 downloads
Then the bolts came loose;
Attached File  20191221_141808599_iOS.jpg   38.3K   3 downloads
And then there was the steering arm;
Attached File  20191221_142846882_iOS.jpg   59.57K   4 downloads
#5 fokko
fokko
  • 195 posts
Posted 28 December 2019 - 10:53 PM
A short update. I figured I'd do some "maintenance" on my blast cabinet, as it contained a lot of dust of previous blast sessions;
Attached File  20191228_193508658_iOS.jpg   49.29K   3 downloads
So I removed the old blast media;
Attached File  20191228_194444046_iOS.jpg   61.87K   5 downloads
And added some new;
Attached File  20191228_195300497_iOS.jpg   59.25K   2 downloads
After that I started on the right-hand steering arm. Before;
Attached File  20191228_195333346_iOS.jpg   41.93K   1 downloads
After;
Attached File  20191228_201103307_iOS.jpg   54.61K   1 downloads
And the right-hand hub, before;
Attached File  20191228_201825430_iOS.jpg   41.96K   2 downloads
Attached File  20191228_201840520_iOS.jpg   49.37K   1 downloads
Prepped the steering arm surface before;
Attached File  20191228_201938547_iOS.jpg   67.45K   1 downloads
After;
Attached File  20191228_202356822_iOS.jpg   64.91K   2 downloads
Started taping off the flattened parts;
Attached File  20191228_203448975_iOS.jpg   55.62K   2 downloads
Attached File  20191228_205113987_iOS.jpg   70.25K   2 downloads
Then I needed to block the bearing surfaces from being attacked by blast media. I had some Brake Cleaner bottles lying around. Apparently the caps of those bottles snugly fit the bearing area. So I cut some height off of them and put them in place;
Attached File  20191228_205123778_iOS.jpg   56.66K   3 downloads
Halfway;
Attached File  20191228_210053765_iOS.jpg   68.87K   1 downloads
Attached File  20191228_210103223_iOS.jpg   67.82K   1 downloads
Finished;
Attached File  20191228_213342797_iOS.jpg   71.89K   1 downloads
I currently have an Air Compressor which is pretty loud (115 dB) and only has a 24 litre tank. It's the type of compressor you would buy at the DIY store. It is not made for this kind of use; it doesn't deliver enough air to continuously blast. After about 10 seconds of blasting, it already needs to run to add additional pressure. I'm now considering buying a new one with a 70 litre tank and an engine that delivers 250-300 lt/minute at a low noise level (about 53-60 dB)...
#6 Daz1968
Daz1968
  • 2,058 posts
Posted 29 December 2019 - 01:37 PM
For info I have a similar cabinet and use a 3hp Clarke belt driven compressor with 100 litre tank, it just about keeps up with smallest nozzle,
#7 fokko
fokko
  • 195 posts
Posted 30 December 2019 - 09:11 AM
Thanks! I can see that my blast cabinet uses 250 litre per minute at 6 bar. Apparently the max working pressure is between 2.5 and 5.5 bar. I use it at max compressor pressure, which starts at 10 bar  :errr: , so maybe I should turn down the pressure... Your compressor seems to do 14 CFM max (396 litres per minute) which is the gross volume. The one I'm looking at does 375 litres gross volume, and 260 litres net volume. It means that the compressor will run pretty frequently and indeed, can just keep up with the usage. But I don't care as long as it doesn't make the huge amount of noise my current compressor makes :lol: .
#8 Daz1968
Daz1968
  • 2,058 posts
Posted 30 December 2019 - 09:59 AM
As long as it’s belt drive rather than direct it will be quieter, hydrovane is best but expensive, I couldn’t warrant the expense for how much it’s used
#9 fokko
fokko
  • 195 posts
Posted 30 December 2019 - 02:44 PM
I'm actually looking at a membrane-driven compressor, they seem to be very quiet. You can find it here: https://www.hbm-mach...oise-compressor
 (site is in Dutch, but I guess you'll understand the specs anyway).
#10 ajperry
ajperry
  • 316 posts
  • Local Club: Thames Valley Mini Club
Posted 01 January 2020 - 09:43 AM
You’re inspiring me to get my own compressor and blast cabinet!
Like the plans, will keep watching.
Happy New Year!
Alex
#11 no66
no66
  • 156 posts
  • Local Club: NMCC (Norsk Mini Cooper Club)
Posted 01 January 2020 - 10:18 AM
Following this, good job!
#12 fokko
fokko
  • 195 posts
Posted 04 January 2020 - 03:03 PM
Happy New Year!
Alex
Thanks Alex! I'm happy to hear my post inspires others ?. Happy new year to you too!
Thanks no66!
Another small update, didn't put much time in it... I'm waiting for some Bilthamber stuff (Electrox and Epoxy Mastic), but in the meanwhile I figured I could put the stuff I blasted in a bath of Deox-C to remove the last bits of rust.
Before;
Attached File  20200102_204911812_iOS.jpg   165.57K   2 downloads
Detail (the bolts were the best I had);
Attached File  20200102_204918277_iOS.jpg   119.46K   1 downloads
The stuff I used;
Attached File  20200102_205007008_iOS.jpg   64.36K   1 downloads
Put it into the bath;
Attached File  20200102_205231764_iOS.jpg   50.45K   2 downloads
About 24hrs later;
Attached File  20200104_141729862_iOS.jpg   61.18K   1 downloads
As you can see, the hub was not fully submerged;
Attached File  20200104_141734332_iOS.jpg   51.42K   2 downloads
I brushed the parts to remove rust particles and put them back in for another soak;
Attached File  20200104_143304717_iOS.jpg   53.78K   3 downloads
The bath always leaves a dark grey finish which can be partly brushed off, but not completely. Apparently this is enough preparation for the first coat of Electrox. Hopefully the new stuff arrives this week...
#13 carlosgt
carlosgt
  • Just Joined
  • 26 posts
Posted 09 January 2020 - 03:18 PM
Following this build! good luck on your project  :D
#14 fokko
fokko
  • 195 posts
Posted 09 January 2020 - 07:45 PM
Thanks, much appreciated!
Another small update. Expecting the Bilt Hamber stuff (Electrox and Epoxy Mastic in the upcoming weeks, as the latter is out of stock and planned for production). In the meanwhile I figured I'd take a look at the brake master cylinder. The old one is not in a usable state anymore, so I have a new one which needs to be put in place. First I removed the clevis pin at the top of the pedal which was quite a hassle because of corrosion;
Attached File  20200104_210753893_iOS.jpg   38.37K   2 downloads
After soaking the nuts and pipe fixings in WD40, I started dismantling the current setup, first the pipes connected to the master cylinder;
Attached File  20200104_211058825_iOS.jpg   39.67K   2 downloads
Then at the limited valve side;
Attached File  20200104_211509952_iOS.jpg   69.13K   2 downloads
Then I figured I had to remove the clutch master cylinder in order to easily reach for the rearward nut;
Attached File  20200104_212933348_iOS.jpg   59.53K   3 downloads
After the master cylinder came out, it was obvious that something was missing (the retaining clip);
Attached File  20200104_213214677_iOS.jpg   35.49K   4 downloads
The pin was still in the car;
Attached File  20200104_213228861_iOS.jpg   45.22K   3 downloads
When it came out, it looked like something homemade :-O;
Attached File  20200104_213304203_iOS.jpg   34.84K   2 downloads
New master cylinder;
Attached File  20200104_213859086_iOS.jpg   26.05K   2 downloads
When mounted, I discovered that the lower fixing was of the wrong size and actually the front/rear is swapped according to the Minispares website...;
Attached File  20200104_220131361_iOS.jpg   61.46K   2 downloads
So now I need to get some additional parts; I want the original preformed brake pipes for LHD with the correct size nuts and I need a new gasket for the master cylinders. Saturday I'll visit one of the biggest Mini shops here in NL, they have a lot of stock, so hopefully they have it in stock, fingers crossed...
#15 ClassicBRG
ClassicBRG
  • 78 posts
Posted 11 January 2020 - 04:26 PM
Nice job, good to see another Dutch Mini over here!
    Bing (1)
