1979 Mini Ebony With Sc Injection
roundnose
56 replies to this topic
#31 fokko
fokko
  • 195 posts
  • Local Club: Mini Seven Club Nederland
Posted 06 July 2020 - 06:39 AM
Great looking project and a great looking work space you have [...]
Thanks for the kind words! Yes, the workspace is great, although a pain to keep clean ;-). It took me several iterations to get a workspace like this, but it is certainly a very nice place to be!
Yes, I will keep trying the welding, but I'm already sure that I will ask somebody else to do the actual restoration work. It's just not my kind of job. I like to do the mechanical stuff and refurbishing of old parts.
#32 fokko
fokko
  • 195 posts
Posted 17 July 2020 - 08:24 PM
Got some goodies to continue the work:
* Top arm rebuild kit
* Copper rings for oil pressure relief valve cap
* Bottom arm to tie rod bolts
* Clutch slave cylinder repair kit
* Gaskets for clutch/brake master cylinders
* Braided hose for hard line to clutch slave cylinder
* New clutch master cylinder
* Blind bearing puller set (the one I had only contained a slide hammer to pull, but wasn't up to the job)
* Stack oil temp gauge (was not in stock when I ordered my other gauges)
Attached File  20200702_120524291_iOS.jpg   68.17K   0 downloads
Attached File  20200711_122548358_iOS.jpg   71.32K   2 downloads
Attached File  20200711_122644863_iOS.jpg   59.65K   0 downloads
Then I continued taking the front suspension apart:
Attached File  20200702_120734785_iOS.jpg   50.12K   0 downloads
After some fiddling, I got the suspension strut ball & cup out (I put the ball in the drill and forced it out while rotating, couldn't find another way...) and the rear bearing. The front one didn't come out using my "old" puller (it's only a few months old):
Attached File  20200704_152253195_iOS.jpg   71.31K   1 downloads
I tried heating the arm & pulling, I tried WD40, nothing worked...
Attached File  20200704_152258723_iOS.jpg   41.51K   0 downloads
But then I used my new puller, although there was not a lot of "meat" to put the legs on....
Attached File  20200711_123445420_iOS.jpg   37.99K   0 downloads
Finally there was some movement!
Attached File  20200711_123450948_iOS.jpg   34.17K   1 downloads
Although it almost broke while pulling it out...
Attached File  20200711_123711296_iOS.jpg   29.91K   0 downloads
After degreasing I put it in a Deox-C bath for a while:
Attached File  20200705_190043768_iOS.jpg   38.41K   0 downloads
Came out like this:
Attached File  20200708_202246877_iOS.jpg   32.31K   0 downloads
Attached File  20200708_202254602_iOS.jpg   32.35K   0 downloads
Cleaned it up a bit more and degreased it using Brake Cleaner:
Attached File  20200715_201244584_iOS.jpg   48.63K   0 downloads
First layer of Electrox:
Attached File  20200715_201453981_iOS.jpg   43.96K   0 downloads
Took out the suspension cone and compared it to the new one...
Attached File  20200705_091941661_iOS.jpg   44.75K   0 downloads
Mounted the new bump stop:
Attached File  20200705_190028754_iOS.jpg   71.26K   1 downloads
And did something else; bought a Luisi steering wheel on Facebook, which arrived like this:
Attached File  P7170047.JPG   40.58K   2 downloads
Attached File  P7170052.JPG   31.23K   1 downloads
Attached File  P7170054.JPG   31.61K   0 downloads
And after some work, turned into this:
Attached File  P7170057.JPG   36.19K   1 downloads
Attached File  P7170056.JPG   34.22K   1 downloads
Attached File  P7170055.JPG   30.23K   1 downloads
Used Meguiars Leather Cleaner & Leather Conditioner using several brushes and microfibre towels & put some correct bolts in place. After closer inspection it appears not to be leather but rather some rubber like stuff.
Maybe I keep it, maybe I'll have it recovered in leather, maybe I'll sell it and keep my leather Mountney steering wheel. What do you guys think?
#33 fokko
fokko
  • 195 posts
Posted 22 July 2020 - 03:37 PM
Finally put my engine on a stand. Took some time to get all of the spacing right, but it now fits using the oil filter housing bolt holes and the alternator bracket bolt holes;
Attached File  20200718_184144194_iOS.jpg   42.2K   2 downloads
Attached File  20200718_184152219_iOS.jpg   79.77K   2 downloads
Attached File  20200718_184218150_iOS.jpg   74.79K   1 downloads
Attached File  20200718_184221937_iOS.jpg   72.82K   1 downloads
Attached File  20200718_184228081_iOS.jpg   64.24K   2 downloads
Then I continued the rebuild of the left hand driveshaft. I figured I would need to completely refurbish them now as opposed to just make them work, because otherwise I'd need to take them apart again for paint etc. As you might have read in my initial post, I first want to do a "dry build" to make sure all holes are in the right places and everything works and fits, before I take it apart to have the bodywork restored and painted and build everything up again. That means that while the bodywork is out for repairs and paint, it gives me time to refurbish all parts. Anyway, this is how it went;
Attached File  20200720_201431106_iOS.jpg   47.81K   1 downloads
Attached File  20200720_201437333_iOS.jpg   51.48K   1 downloads
Attached File  20200720_201443790_iOS.jpg   59.02K   0 downloads
Used the CV puller to disconnect it from the shaft in a controlled way;
Attached File  20200720_201810881_iOS.jpg   58.89K   1 downloads
Attached File  20200720_202712305_iOS.jpg   55.74K   2 downloads
Then the other side, which was a bit of a hassle;
Attached File  20200720_203329285_iOS.jpg   69.63K   1 downloads
Cleaned it and removed the cap to be able to use a puller:
Attached File  20200720_204416763_iOS.jpg   44.46K   0 downloads
Attached File  20200720_204534570_iOS.jpg   57.55K   0 downloads
Heated it, but didn't work, then used a bigger puller which did the trick;
Attached File  20200720_211324426_iOS.jpg   77.13K   1 downloads
After some action with the drill and wire brush, it left me with this;
Attached File  20200720_213050880_iOS.jpg   55.67K   2 downloads
Attached File  20200720_213102073_iOS.jpg   80.64K   1 downloads
Attached File  20200720_213108365_iOS.jpg   60.63K   0 downloads
Not too bad I would say, although there is some rust pitting.
#34 fokko
fokko
  • 195 posts
Posted 19 March 2021 - 03:21 PM
Ooops! It's more than half a year ago since my last post... Time for an update. I must say I have not been doing a lot to my Mini, but the last few weeks, I found my motivation again and started working on it...
Finished one of the driveshafts:
Attached File  IMG_4800.jpg   52.04K   3 downloads
Got a nice package from Minispares (the tool on the side is not from Minispares, it's a tool to remove the retaining pin from the gear linkage coupling):
Attached File  IMG_5151.jpg   63.6K   3 downloads
Using a clearcoat that can be sprayed directly on bare metal to protect parts from rusting, without changing the appearance:
Attached File  IMG_5182.jpg   32.96K   1 downloads
Used it on the CV jointL
Attached File  IMG_5211.jpg   31.61K   1 downloads
Finished unit (stupid mistake, because now I cannot insert it into the subframe hole...):
Attached File  IMG_5247.jpg   34.47K   1 downloads
New rebound buffer:
Attached File  IMG_5186.jpg   37.97K   0 downloads
Track rod bushings:
Attached File  IMG_5208.jpg   65.12K   0 downloads
Front lower arm complete:
Attached File  IMG_5209.jpg   63.35K   0 downloads
Upper arm and hub ready to assemble:
Attached File  IMG_6291.jpg   46.21K   1 downloads
Attached File  IMG_6292.jpg   44.27K   2 downloads
New front subframe rear rubber mountings:
Attached File  IMG_6310.jpg   45.88K   1 downloads
Attached File  IMG_6311.jpg   45.81K   0 downloads
Used Mokespider's approach to install the Timken front wheel bearings:
Attached File  IMG_6331.jpg   72.68K   0 downloads
Attached File  IMG_6390.jpg   59.51K   0 downloads
Reinstalled the subframe so I can move the Mini in order to remove the rear subframe in order to put the fuel lines in place:
Attached File  IMG_6319.jpg   82.08K   0 downloads
Used a different approach now the frontend is so light:
Attached File  IMG_6321.jpg   65.8K   0 downloads
Installed hubs & discs:
Attached File  IMG_6397.jpg   55.73K   0 downloads
Attached File  IMG_6398.jpg   53.19K   0 downloads
Replaced the brake bias valve:
Attached File  IMG_6333.jpg   79.64K   0 downloads
Attached File  IMG_6334.jpg   42.65K   0 downloads
Attached File  IMG_6335.jpg   56.3K   0 downloads
Cleaned, sprayed (zinc primer, gloss black topcoat) and reinstalled the heater hose/engine steady bracket (I now use glass beads in my blast cabinet, which is a bit less aggresive when cleaning these kind of items):
Attached File  IMG_6349.jpg   61.98K   0 downloads
Attached File  IMG_6350.jpg   57.19K   0 downloads
Attached File  IMG_6351.jpg   56.94K   0 downloads
Attached File  IMG_6353.jpg   57.45K   0 downloads
Attached File  IMG_6354.jpg   37.54K   0 downloads
Attached File  IMG_6402.jpg   82.17K   0 downloads
I hope to be able to post a bit more frequently the upcoming time!
#35 johnR
johnR
  • 2,322 posts
Posted 19 March 2021 - 11:13 PM
Some very nice parts prep going on here - keep it up, Summer is coming!
#36 fokko
fokko
  • 195 posts
Posted 20 April 2021 - 01:36 PM
This is a photo-heavy update which I will split up in multiple posts. Cracked on and got some results. Hope you like them.
Heater unit was looking sorry, so took it apart, cleaned it and replaced the matrix because I suspect the previous owner has used anti-leak stuff in the cooling system... Also replaced all of the foam and sprayed the flap. As the old heater matrix had some spacer brackets, I had to fabricate something to achieve the same and not have a rattling heater matrix in the heater unit. I used Innox FC-Foam, which is normally used in flight cases. Pretty expensive stuff, but it works great and it is easy to cut with a sharp knife. Of course, after the dry-build, I will address the rust on the control unit.
#37 fokko
fokko
  • 195 posts
Posted 20 April 2021 - 01:51 PM
Then I mounted the left-hand hub. I had already partly refurbished this driveshaft, but I figured I'd do it the same way as the right-hand side, including spray painting the shaft (I know I swapped driveshaft sides by accident, will fix this later).
Messed up the seal a bit, but I think it will be OK...
Hub in place;
How it started;
Removing heavy grease/wax deposits;
Shaft cleaned;
Rust pitting;
Other side is better;
Gave it a coat of satin black;
Looks like someone cut it, not straight...
CV joint back in place;
Love these ultra-flat "tie wraps";
Wheels on;
And now the entire car is on axle stands, ready to remove the rear subframe in order to mount the fuel lines;
#38 fokko
fokko
  • 195 posts
Posted 20 April 2021 - 02:58 PM
Then it was time to lower the rear subframe and get my nice goodies mounted. It was relatively easy to remove, probably because the previous owner already removed it as part of their "rebuild". I found some odd things though, like locknuts put on the wrong way round and metric bolts/nuts...
Time to lower it!
Damper is badly corroded and there is even a hole in it...
Longer studs in for spacered drum;
Hmm, what to do with it? Clean or replace?
In the end I replaced it, as corrosion is so bad...
Behind the brake backplate, corrosion was so bad, I was able to break off a rather large chip by using an old screwdriver and hammer;
Completely cleaned it and sprayed it with zinc spray;
Shaft is worn, but is good enough to put back. Let's see what the MOT guy thinks in a few years time when it's ready :-)
No, these are not new nuts, but cleaned. They came out great!
#39 fokko
fokko
  • 195 posts
Just clears the radius arm;
Finished!
Still need a blanking plug for this, I see Minispares stock them;
Badly corroded subframe bolt;
And the next one to do, this is for next time...
Edited by fokko, 20 April 2021 - 06:01 PM.
#40 Tones61
Tones61
  • 441 posts
Posted 21 April 2021 - 04:22 PM
Do the nuts and bolts that hold on rear backplates go the other way? / the brake springs may rub on them else? :-)
#41 Maccmike8
Maccmike8
  • 1,101 posts
Posted 21 April 2021 - 06:21 PM
You bring bits back to life nicely  :proud:
#42 fokko
fokko
  • 195 posts
Posted 22 April 2021 - 08:32 PM
Thanks, you have a very good point! I put them back the way they used to be, assuming it had never been taken apart, but apparently I was wrong. I will definitely fix this 👍.
Thanks!
#43 Cooper Mac
Cooper Mac
  • 222 posts
Posted 23 April 2021 - 08:11 AM
Thanks, you have a very good point! I put them back the way they used to be, assuming it had never been taken apart, but apparently I was wrong. I will definitely fix this .
Thanks!
The nuts and screw holding on my back plates had the nuts on the inside (within the drum) and I refittted them like that when I rebuilt them.
I think the springs I had were handed, so they should fit without touching the end of the screws. Once I rebuilt them, there is more than enough clearance between the spring and the screw, so I'd just check the springs if I was you!
#44 GraemeC
GraemeC
  • 7,472 posts
Posted 23 April 2021 - 10:11 AM
As long as the springs don't catch on the nuts or on the hub then they'll be fine.
However I think you have the shoes in the wrong orientation - the leading/trailing edges are wrong.
#45 fokko
fokko
  • 195 posts
Posted 23 April 2021 - 11:03 AM
I checked the Haynes manual and there it appears the nuts should be on the outside. So in my case, they are the wrong way round.
Thanks for your thoughts. How can you see they are wrong? These new shoes are not very clearly sided, whereas the old ones were; you can tell by looking at the area that the friction material doesn't cover, which should be the leading side.
