Got both the sidelight/ indicator units wired in, although only the drivers side is working at the mo, and the headlights don't work at the mo either, but i think it is down to bad earths so will pull it apart next week and find out what's going on. Also fitted the indicator tell-tale buy the dash and that works
Then moved on to the inside. Fired up the welder and put some decent welds onto the gear linkage bracket (was only tacked in place), then swapped over the nova seats back to the buckets (haven't got the time at the mo to build the brackets required so they will go in at a later date) and bolted up the harnesses again.
Then it was on with cleaning and painting the front floors (after 24 years, the original paint was a little bit scruffy and surface rust was showing through in a couple of places), bulkhead box and gear linkage bracket. There will be carpet in the front, but it keeps the rust at bay and neatens it up a bit.
Then on with the fun bit, finally fitted the door cards. Have to hand it to Rusty, they are spot on.
So, a few more jobs ticked off of the list, but quite a few more to go
