how much is the blockwork going to cost?
About £250'ish, didn't ask for price, as the work needs to be done, so I will pay it
Also forgot to say, the valve size the pockets will be able to take will be...31mm
Posted 19 June 2009 - 06:56 PM
Posted 19 June 2009 - 09:38 PM
i've got a engine hoist, and a good lifting brkt.
Thats great, would I be able to borrow it when the time comes please?
Posted 19 June 2009 - 09:42 PM
just give me a bell Dan
Posted 20 June 2009 - 05:40 PM
Posted 20 June 2009 - 05:56 PM
MED didn't take the pistons, so I can fit them to the con rods sometime
Posted 20 June 2009 - 06:02 PM
Why didn't he take the pistons?
Posted 20 June 2009 - 06:34 PM
Posted 20 June 2009 - 06:37 PM
Oh right, at least it gives you something to do while the block is being done.
Posted 20 June 2009 - 06:46 PM
Yes it will
, I think tomorrow I will give myself the task of cleaning and sorting all the bits we took off the engine when we broke it down
, that should be fun
Posted 20 June 2009 - 06:53 PM
Yes, that will be fun, good luck
I bet there isn't much stuff really is there, as most of it is either at MED or my college lol.
Posted 20 June 2009 - 07:36 PM
do you know if Welhams do crank work? as MED are quite busy.
Posted 21 June 2009 - 11:43 AM
Not too sure, I think they can do regrinds and supply the new big ends and mains to the correct size.
Dont know about the gearboxThe gears and shafts are still in, I think its just the casing was stripped down and all the diff housing removed etc.
Did you find out about the S/C pulley? and the 4 pots?
Posted 21 June 2009 - 06:10 PM
The gearboxes are stripped and then dipped in a solvent cleaning agent which removes road grim and oil staining. The cases are then checked for wear on the idler bearing face, threads are checked for integrity, including the sump plug, and finally checked for cracks.
The gearbox internals are also dipped, and subsequently checked for chips, wear and bearing surface integrity. Those which are showing signs of age are binned. Differentials and synchro's are also split to their component parts, allowing a complete inspection of all parts.
1st motion single roller bearing
1st motion spigot bearing
3rd motion double roller bearing
3rd motion nose bearing
Idler bearing
Layshaft & Bearings, a competition high grade steel shaft is used
4 x baulkrings
Molybdenum competition diff pin
2 x planet gears & bronze thrusts
2 x output shaft mica washers
2 x Steel bound diff bearings
6 x Synchro springs and balls
Central oil pickup replacing the standard oil strainer
New seals and gaskets throughout plus primary seal
All gaskets required to refit gearbox to engine
Posted 21 June 2009 - 06:43 PM
Posted 21 June 2009 - 08:36 PM
Yeah, I think the rebuild would be better too! As you said though, hopefully the price should be dropped with a few exchange boxes and a cash sale maybe?
