1984 Austin Mini Mayfair Dubbe Project Bertie
#136
Posted 24 June 2009 - 04:45 PM
#137
Posted 24 June 2009 - 06:08 PM
#138
Posted 24 June 2009 - 06:12 PM
i have passengers fair often as a student so yeh i need both comfort and practicallity
#139
Posted 24 June 2009 - 08:30 PM
Work is looking as good as ever sean, still cant belive your allowed withing a mile of a welder.
#140
Posted 25 June 2009 - 02:33 PM
so yeah seems like the mini is staying spent alot of time over the last few weeks thinking and umming and arring and to be honest the 1275 pulls like a train, handles awesome and i can forget how cool the mini looks so yeh hes staying and ive started the interior revamp
so here some pics of todays attack
so thats the wing neatened up and im happy with how it looks for now
and for a few week i noticed the engine was alot noiser and came to find the manifold had split clean in tooo so i welded it up
also had a problem with the slave cylinder bolt decided to go south so had to repair that and did so with a new unc bolt and alot of washers
whilst i was doing this i welded in the patch on the rear seat bin and then painted the interior black to match the carpets
and i have ordered new cone washers and hub nuts to remove the lil bit of play in the wheels and part of my dash board plans arrived
in short making a 18mm thick mdf dash with my bro the carpenter / builder, my brother thats a painter will be doing a custom paint job for me and ill make sure it looks good fitted
so yeh shall be fun few weeks new engine mounts, mot, tax and interior spice up
Think you should put that welder down and stop with the pigeon poo as that wing looked better before.
Are you useing a gasless mig welder if you are i think you should pratice on some metal some more before you attack your mini with it.
#141
Posted 25 June 2009 - 02:47 PM
#142
Posted 25 June 2009 - 07:29 PM
Tutorials here are really helpful to get you started mig welding.
Do you have enough gas flow?What gas are you using?
Edited by rosco454, 25 June 2009 - 07:30 PM.
#143
Posted 25 June 2009 - 08:53 PM
#144
Posted 25 June 2009 - 09:25 PM
michael
#145
Posted 26 June 2009 - 12:27 AM
#146
Posted 26 June 2009 - 08:23 AM
Was your front panel coming away from the wing edge?
It would be better to clamp the two panels back together from behind and plug weld them back together - this way it you don't have to attempt to seam weld it up (i guess that's what you were trying to do) from the outside. some people even Mig up the edge of the lips (steady hand required!) This way you can put a skim of filler on the exterior, profile it and then run a bead of seam sealer,... should at least look how it did when it came of the line then...
Or were you Trying to fill the panel gaps with weld to smooth them off? A bit like lead loading i guess.
You don't need anyone telling you that you've made a mess of that, i'm sure you know already - I'd Grind it all out and practice welding on some metal - try to simulate the join you want to achieve - The weld you'e done there on the front looks like it hasn't penetrated the panel at all and is just sitting on top....
good luck
#147
Posted 29 June 2009 - 07:02 PM
I went over the welds so i know they've penetrated further back, as i checked as i went along.
It does indeed look rought (as a badgers backside). but once I've done a skim of filler and some paint ( the right colour) will look good !!
I know im not great at welding, but u should have seen the welding i did inside
Ive never been taught anything on cars as my Dad passed away when i was 10.
So everything that I have learnt about cars or how to fix them has made me feel closer to him, as he really into cars Mercs to be precise. The 190 cosworth was the best I can remember when i was 7 that car did 160mph easy. We had planned to restore a mini when i was 16, but him passing away meant this never happend.
I started with cars when I was 18 and have learnt the majority of what i know on fiesta's and did alot of work on my old saxo.
But due to stigma attached to both them cars i sold them and finally got the mini i awlays wanted
Todays been fairly busy, I went to Mini Techinques and got my lower dash rail
So i drove very causiously in 3rd to the garage that i knew of in Longridge and borrowed a jack and axel stand. Fitted a temporary split pin to get me to Woodfeild garage, where i used to work to fix it properly. So got that finished and thanks to the guys at Shell longridge Mot station all top blokes.
Got there jacked up my car, removed the split pin which was easier said then done. Fitted the new roll pin and wired it so it doesnt drop out.
Then decided since Lancashire windscreens wanted £35 to fit my new seal, That I would have a go myself. I must report was Easy
Well i took my time had it out in 2 mins and then treated the metal to protect from rust, Refitted the seal and windscreen. 40 mins later done
Cleaned up checked for leaks and drove home another Great day Ups and Downs Smiles and Frowns moto of the day
Tomorow top arms out to fit the new donuts
#148
Posted 29 June 2009 - 08:33 PM
#149
Posted 29 June 2009 - 08:37 PM
Lol shouldn't be tooo bad gonna attempt it at Alan's and then i can have all the tools to hand and if i go insane he can have a look im hoping should be easy enough just take my time
Im' gonna try without the cone compressor as i havent got one, but if need me im sure we can make one at Alan's. He has every tool under the sun except a 34mm socket i think Rodger the dodger ate that one
#150
Posted 30 June 2009 - 02:49 PM
thanks
greg
