"fast Road" Daily Driver
660 replies to this topic
#376 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 26 July 2009 - 10:29 PM
LOL, its 10mm OD, which is around 8mm internal.
I didn't realise you could get pipe benders that small
#377 camp freddy
camp freddy
  • 3,696 posts
Posted 26 July 2009 - 10:45 PM
i'll bring one tomorrow... pop round around 7-8 pm
if you arn't busy.... or txt me..
Edited by camp freddy, 26 July 2009 - 10:46 PM.
#378 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 26 July 2009 - 10:54 PM
That would be brilliant, thanks Carl :ermm:
I should be able to do it all in one night.
#379 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 28 July 2009 - 09:03 PM
Went to the mini today to make a start on the fuel pipes, but it was too dark to see, so I had to leave those for another day. I ended up sanding down the fibreglass bonnet ready for primer. Most of the marks on it were actually dirt and came off, there are just a few little marks but I think they will not be visable once filler primed.
#380 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 28 July 2009 - 09:05 PM
Sounds good mate, not long now, IMM is in 9 days (So I heard) doesn't look like we are going to make it as planned :P .
#381 ianpettifer
ianpettifer
  • 769 posts
Posted 28 July 2009 - 09:06 PM
as borat once said
NICE!!!!!!!!!!!!!!!!!
#382 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 28 July 2009 - 09:10 PM
Sounds good mate, not long now, IMM is in 9 days (So I heard) doesn't look like we are going to make it as planned :teehee: .
I heard that too, I didn't realise it was so soon. I was aiming for MITP, but heard that was the week after IMM :P
Yours could easily be on the road providing your engine bits are ready at the end of the week. Just whack a 998 head on, standard dizzy and your LCB, and you are ready to go. Run it in like that, then put the 1275 head on, the charger and the Megajolt on after
#383 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 28 July 2009 - 09:12 PM
thanks Ian :P
#384 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 28 July 2009 - 09:13 PM
What?! Can't believe we are missing out on this year :genius: , I could do that, but I don't want to, rang MED today and they said it should all be ready for friday :teehee: .
#385 ianpettifer
ianpettifer
  • 769 posts
Posted 28 July 2009 - 09:17 PM
whats gona be the spec for the engine then?
sorry if its been posted buts its along thread loooooool
#386 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 28 July 2009 - 09:18 PM
I thought you were going to run it in without the charger on?
I'm still going to go to the shows, there is no point missing out because they aren't ready.
Good news with the engine, see, yours could easily be done :P
#387 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 28 July 2009 - 09:20 PM
I might, but I'd rather have the 1275 head on from the start. Yer I suppose we could make a dew without the minis.
#388 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 28 July 2009 - 09:24 PM
Rough spec
1293cc
omega 10cc pistons
standard rods
MED hardened crank
MED "T3" turbo cam
Piper vernier duplex pulleys
Vandervell bearings
standard box with S/C drops and X pin diff
"Turbo Phil" Fast Road / Trackday Turbo head with 28cc chambers and 36in / 29ex (i think) valves.
1.5:1 roller rockers
T2 turbo using mirage manifolds
adjustable bleed valve
renault 21 turbo intercooler
hif44 turbo carb
I think thats most of it lol :P
#389 ianpettifer
ianpettifer
  • 769 posts
Posted 28 July 2009 - 09:33 PM
nice 1
just a quick newbie turbo question lol
How do you go abouts fitting a return fuel line, as in from where to where?
cheers
#390 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 28 July 2009 - 09:42 PM
It is one of the pipes from the metro turbo fuel pressure regulator that you have to fit and it goes back to the tank. You will have to modify the standard tank to allow a fuel return, or do as I've done and fit an spi or mpi tank which already has a fuel return on it :P
