So when ill get the change ill add the last patch to the rear arch then ill move round to doing the two small patches on the N/S/R but im sure when i remove the bin the small patch will end up being bigger that i expect.
So these are the two rot bits in the rear door frame bottom corners the O/S has be bodged with filler at some point so ill need to dig that out when i get the time then ill have to try and think up a way to repair them. Does anyone know if you can buy repair panels for the frame corners? as it would save a hell of alot of messing about....
Also i managed to get the sodding tiny bolts of the bottom of the O/S rear quarter window frame so i got the frame off but unfortunately there was rot there some already visible holes
So i should be able to get it back down on to the rear wheels very soon, then i can start attacking the front. luckily for me the front doesnt seem anywhere near as bad then ill just have to sort the rear window lip and i can start to prep it.
Then hopefully by then i would have found myself a donor car that i can use for the engine.
It all sounds so easy lol.
