Well i made some good progress this evening
Started out my welding the final patch in the drivers side footwell, i then tacked the outer sill in place. Im using over sills, but i have cut the bottoms off so the vents can still breath, but they are still wider than standard.
I then got underneath and seam welded the metal between the vents, i know this isnt how its done as standard, but i dont have a spot welder so good/strong enough for me.
Then i cleaned up the remains from the rear bin and found a 5p size hole at the top of the heelboard/boot floor, but i have ignored this for the moment, so i cut out all the rot in the rear flook, more than i thought actually:
Then made up a patch and welded in place:
Then i remembered that when i gut out the old inner sill from the river side i forgot to weld a seatbelt bolt back in place, so i gut a bolt out a car that is being broken (not a mini) and welded that into the inner sill.
Then i moved onto the passenger side door step and cut the rot out of that:
I as going to patch it up as one patch, but i couldnt get it to shape right due to the inner lip having to be cut lower than the flat of the step, to make sure all the rot was gone, so i repaired using two patches, then cleaned up and you cant even notice its been repaired:
Then i moved onto the front passenger foot well, got poking again with the screwdriver and the "metal" just kept falling through as did the filler
so i got the grinder out and cut a nice hole:
At this point i ran out of steel, so i just cut the a-panel off, still needs more cutting off.
I then started chatting to a guy from one of the units next to mine and he's currently re-building a small motorhome, and he said that if he fills/sands all the body down ready for paint can i put it in primer for him, and if i will he will give me a Ford KA and two massive sheets of brand new steel
So now tomorrow ill be getting the KA collected and will be able to finish the main part of the welding hopefully, and then thursday after work ill be spending a couple of hours just slapping some primer on this motor home, i think i got lucky with that deal lol.
The welding list left is:
Make up some patches and weld up the small hole at the top of the heelboard
Make up some patches and weld up the passenger side front floor pan
Make up a top front coil over mount and weld in place on the inner wings
Weld the a-panels on
Any modifications/brace bars i need to make to the front subframe
So now iv got to finish the floor pan and heel board, then ill got round and clean up all the welds, then rust protect/seam seal, then i think im going to stone chip the inside and out.
I worked it out that so far i have welded in 29 different repair patches
only two or three to go though
Edited by Tomf, 07 July 2009 - 10:01 PM.
