Project Badger!!
#31
Posted 08 January 2006 - 08:29 PM
#32
Posted 08 January 2006 - 08:30 PM
#33
Posted 08 January 2006 - 08:32 PM
#34
Posted 05 March 2006 - 02:26 PM
here is the old subby and the snow that is "stopping" me putting the new one on!!
#35
Posted 11 March 2006 - 08:24 PM
Put the subframe on during the week and finished off the suspension and stuff today
connected up the handbrake and the brake pipes.
I still need to sort out the bleeding of the brakes.
other thihgs still to do:
link up the rubber dust covers into the plastic radius arm thingymabob
fit new front subframe rear mounts.
bleed brakes
check for more rust
front passemger side ball joints
get a tune up
and then hopefully
MOT
AND then hopefully buy a mini shorty to do up!!!!!!!!!
#36
Posted 26 March 2006 - 08:25 PM
Also have cleaned up the surface rust on the new sills i did as i hadn't painted them (oops). Hammerited them and then lots of gooey underseal got slapped on.
gonna take the front wheels off and clean and underseal the front wing flitch panel area
#37
Posted 26 March 2006 - 08:50 PM
also i found out why the drivers window hasnt been working to well. the runner that the glass sits in has gone very rusty and was catching.
can i get this on its own or do i need a whole regulator?
#38
Posted 26 March 2006 - 09:02 PM
Rubber Insert
DOOR GLASS RAIL SUPPORT O/S/F & N/S/R
DOOR GLASS RAIL SUPPORT N/S/F & O/S/R
Hope that helps you.
Jackman
#39
Posted 26 March 2006 - 10:08 PM
#40
Posted 06 April 2006 - 06:01 PM
#41
Posted 06 April 2006 - 06:37 PM
#42
Posted 09 April 2006 - 11:04 AM
also gave it a wash. even though i have changed the window and door seals i still seem to be leaking water at a few points.
just need to put the new front windscreen in and i might just book it in for the dreaded MOT!!!!!!!!
minor wiring fault with the front nearside headlight to sort aswell!!
speaker pods have had a couple of layers of glass on them now and are ready for covering and fitting.
#43
Posted 09 April 2006 - 12:01 PM
i'm guessing the slight leak might be the missing front screen
#44
Posted 09 April 2006 - 12:05 PM
#45
Posted 19 April 2006 - 08:36 PM
