Penny The Pickup
#346
Posted 30 March 2014 - 06:34 AM
Head
12G940 Cast
Inlet 35.7
Exhaust 31
Fully ported and flowed
Bronze valve guides
Eibach Double valve springs
Concept valves
19cc combustion chambers !
Fueling
facet fast road electric fuel pump
Twin HS2 Carbs m1 needles
Engine Block
Surfaced, Pocketed, Chemically Cleaned,
+020 Powertune Pistons
A+ Crank Balanced/Polished/Wedged &Cross Drilled
A+ Rods Lightened /Balanced
270 Piper Cam - Same duration as the 276 but more lift
High Flow Oil Pump,
Oil Cooler,
3.7KG flywheel and Backplate assembly+( from my mates Mini Se7en),
race clutch,
Vandervell bearings,
duplex timing chain,
centre main strap,
#347
Posted 15 April 2014 - 09:08 PM
was in this months mini mag however spelt my name wrong,
back to the bodyshop the next couple of weeks as I have the miniworld photoshoot and also the London 2 brighton show and shine, so need the car looking 100% not far off a few more things to do
mouschace ends
clean tardis ,clean, claybar, clean polish, polish, seal, wax , wax ,wax degrease and clean engine
clean the inside,
sort out alignment for the bonnet
looking forwards to going out and finding some smooth driving roads with out think omg my car Is giung to get shaken apart !!!!
hope you are all well
Robbie
#348
Posted 17 April 2014 - 11:37 PM
a fantastic build mate !! I'm looking for a pickup my self now
#349
Posted 24 April 2014 - 08:43 PM
I have a swiftune alloy foot rest,
do I put it in ? or will it spoil the car, I really like the idea of it and like the look, but will people think it looks odd if it goes in ?
opinions people
#350
Posted 25 April 2014 - 05:45 AM
Put it in, it's your mini do as you want!
#351
Posted 19 May 2014 - 06:57 PM
#352
Posted 26 May 2014 - 07:55 PM
I have had a mental couple of weeks ! And been mega busy researching the next part of the project,
But first, previously I stated that I had to bring the pickup back to the body shop, this was too have the roof re flatted back and polished as it looked like only one half of the roof had been finished, also, they had to do some more work on the drivers door as a crack appeared, so it was into the body shop and aye the music for a week.
So about 2 weeks ago we had the photoshoot so the magazine people came over, setup took photos, all was going beautifully! Engine was gleaming, bodywork was sexily silky smooth, and was picture perfect, until they were photographing the interior I heard 'bang' and thought to myself, bird must had dropped something not to worry, and then it happened again and at that the door dropped !
The studs on the lower hindge had snapped ! So this was another job to add for London to Brighton!
Preparation for London to Brighton,
Repair refit door,
Clean polish car,
Replace rear bumpers,
Tidy up engine bay
So repairing the doors, firstly I had been told that the cast hindges were very fragile ! So I was really looking forward to attacking them, I tired mole grips, spanners, soaking in wd40, all with no avail and slowly rounding off the remaining part of the bolt that had sheared, so I had a idea to cut 2 flats using a dremel and again get a pair of miles on it, which failed so I though I would try the most unlikely of tools an adjustable spanner and by Jove it worked !!! So it was all sorted and refitted, which again was a pain, in doing this I drained the oil catch tank and drained over 2 pints worth of oily water, not good, check the engine and it's fine no water contamination, so next going to work on a one way valve for it,
Cleaning the car ( now this bit I enjoy)
Below is what I do and what I use
Rinse
Wash using 2 bucket method with AG body shampoo
Rinse
Then started the decontamination process
I clay bared the entire car
Then applied tardis on the spots that required the removal, front slam panel was very bad,
Then used iron x to remove any iron deposits on the paint work,
From this point I they used a snow foam to rinse and soak all extra bits off, then rinse using water and pat dry not wiping the paint otherwise this will leave swirl marks,
Next stage was protection,
Using Autoglym Super Resin Polish I applied a coat allowed to go off then buff off ins straight lines to get a awesome effect, I repeat this 2 times, once this is done its time to get out the BIG guns
Autoglym HD Wax, 1 light coat, allow to cue for 10-15 mins the buff off !
Final stage was to use extra gloss protection which is a sealant for the paint and protects the wax that little bit more,
Wheels, was a wheels of, use bilberry acid and wheel sealant, jobs a good'n !
Glass use super resin polish
And bright work the AG metal polish.
Then that is the car pretty much clean,
Only had to replace the rear 2 quarter bumpers
An the engine bay polish up carbs and touch up any damaged paint I.e on radiator alternator etc
#353
Posted 26 May 2014 - 08:05 PM
#354
Posted 26 May 2014 - 08:10 PM
#355
Posted 26 May 2014 - 08:39 PM
Tardis being applied
Beading after cleaning progress
Nearly ready for a convoy with Alex
Cold in the morning with the pickup at crystal palace !
Being woken up at 4.45 by people revving ! But more importantly
ALAN ....... Alan .......... No it's Alan STEVE ! Steve Steve !
Leaving the palace for a bimble down to Brighton
Arriving in Brighton
Tough competition!!!
Returning home from a good day
#356
Posted 26 May 2014 - 08:43 PM
#357
Posted 26 May 2014 - 09:02 PM
You mean modded 44? If so a modified hif44 carb for more power
#358
Posted 26 May 2014 - 09:41 PM
oooo !!! that's what you meant. I have just purchased twin H4's which will be able to be used in the next engine too !!!!
1293 appendix k engine, om nom nom but with a twist !
#359
Posted 15 June 2014 - 03:44 PM
lovely job of that!!
#360
Posted 25 July 2014 - 09:04 PM
Ladies and gentlemen it has been quite a while since I last posted on this thread but to give you an update, what has been happening with us lately,
finally managed to get all 3 of the minis in the family together for the first time since we had the gathering in the garden and the pickup was ploncked in a field all those years ago,
on the way home from go karting this same night driving relatively sensible unfortunately the cabin filled up with steam after a load bang, the rad was singing so I killed the ignition and the kill switch and the engine continued to run for a few seconds and looked at the temp gauge and was up to 120/130 degrees safe to say that I left it off for a little while, and Dominic came to the rescue, the problem..... a snapped alternator belt , I left the car over night and went down in the morning and sorted it out, a 10 minute job which I was happy about, gave the car a blast on the way home just to check all was well.
so a couple of weeks on from this, I have brought some H4 twins ! and in the process of working out if to put them on the 1014cc for a better HP figure, however I do like the drivability that the HS2's have, so I am planning on keeping these for my big bore project, another carb that I am eager to get hold of is a hif44 and a manifold to suit as I am told my engine would perform better with the hif44 rather than the hs2's and also save on fuel and better start up characteristics,
we also went to 'Minis on the Rec' and came back with a prize, I won the show and shine for best commercial,
Me with my cleaning tool box !!!! polishing away !
getting ready for santa pod now and I am taking penny up the strip looking forward to it ![]()
