Penny The Pickup
#76
Posted 11 June 2010 - 09:38 AM
Pick-up's looking good so far - love the colour scheme!
There's some floor fitting advice in my build thread over at minipickup.org
http://www.minipicku.......4&start=120
#77
#78
Posted 13 June 2010 - 11:31 PM
Hey Rob,
with reqards to the link ....... by the way looks ace! did the tub hole / drainage you make for the load bay go throught a hold in the sil ? because looking at my sills i have a hole where a drainage hole could potentionally go.
upon looking at the gear linkage i have decided to do put in a kad high level geat linkage kit, which will loock great but i will need to change my quick shift for a blue one as red and blue dont tend to go so i need to order those
and yes ben i thinking now colour co-ordination mite have been too ambitious (what this i hear your selling Kermit ?), but i will solder on, what her ready for the next L2B at the latest, it would be nice to get it ready for brooklands and take her up the test hill
Having to buy things like ,engine bits......£400, interior......£300-400...... paintwork......£300, body work wheels etc list goes on
will update in a couple of days when fitting the rear bed
NITE TMF
#79
Posted 14 June 2010 - 08:47 AM
Yeah, as standard the pick-up had drain tubes that went through the sills. The M-machine floor doesn't have them though so I had to make some up. While I was at it I made them out of larger diameter pipe to make them a little more efficient.
#80
Posted 16 June 2010 - 05:52 PM
tell me if im wrong or right i want to get the whole thing done tonight..
Robbie
#81
Posted 17 June 2010 - 02:13 PM
pistures will be uploaded tonight
is it bad im excited to cut my mini up
Robbie
#82
Posted 17 June 2010 - 09:16 PM
meaning that i will have to remove the rear bulk head to attach. upon looking at this the bottom of the bulk head is rotten and will need to be repaired. as a new rear bulkhead for a pickup is nearly £300!
this job seems to be a prettty major job and is turning into a nightmare! is there anyone who has fixed a bed without removing the rear panels please contact me so i can possibly have you over to help
cant really say how gutted i am about it all
- cut out rear bed and leave in braces.
- remove the rear bulkhead.
- repair rust along the entire bottom of the rear bulkhead.
- repair rust on the inners of the doors.
- weld on new bed
- weld in drainage holes& pipes
- weld in the repaired bulkhead
Also does anyone actually know if pickup bed have 2 skins or just the one ?????
#83
Posted 18 June 2010 - 04:53 PM
#84
Posted 19 June 2010 - 01:21 PM
Did you get the link to the harness fixing?
#85
Posted 20 June 2010 - 09:00 AM
#86
Posted 20 June 2010 - 01:18 PM
the florr is too big going into the cabin, where you have the gutter thing on the inside of the cab theskins come to there, so i need to cut out the bulk head and then put skins in ...... all rather complicated, didnt realsie it was going to be this big of a job ......i will take some photos when next have time have work today and i dont want to go !
The gutter thing on the inside of the cab is the rear floor pan. As standard that's how long it is - it goes all the way into the cab. The rear bulk head is spotwelded to it on the inside of the cab.
#87
Posted 20 June 2010 - 02:43 PM
Just read through your thread, good work coming on
well. Hope you get the bulkhead/floor issue worked out.
Here's a link to the yellow hoses you asked about.
http://www.siliconho...p;catalog=MS202
Use the drop down box for the colour you want.
I found them a very good company to deal with.
Hope that helps.
John
#88
Posted 20 June 2010 - 11:39 PM
about the deck skins/load bed i no they are the lip on the inside of the cabin, but these mini machine ones dont come with a bend for the internal lip.. are we supposed to put it in or not ? im hoping this weekend i can get it done as i have it off
cheers guys will put a proper reply when im not half asleep
#89
Posted 21 June 2010 - 08:44 AM
thankyou for the links and info.
..... yes teapot i did get the link
. again thankyou for that sorry have had a couple of busy days so needed to catch up, silicone hose....AWSOME !
When I ordered mine I ordered the complete floor, with the cross members and rear valance as well. This also came with the bend for the internal lip as a separate piece which you weld on afterwards.
Not easy to describe in words how I actually did mine but I did was I cut the rear floor away just behind the rear bulkhead as close as possible then ground down the bit of floor that was left so that it was totally flush with the bulk head. So imagine now all I've got is the complete bulk head and the bit of floor that protrudes into the cab along with the lip to make it into a gutter. I then put the new rear floor in place but slid the front end of it underneath the piece of the old floor that was left. When it was all in the correct position I spot welded all the way along joining the old floor to the new.
I did it this way because I wanted to keep the original gutter/lip you're talking about. Also, this way makes that whole area a lot stiffer.
If you don't want to do it this way I still have the original lip piece that you weld onto the front edge of the floor which you're quite welcome to have.
Edited by minipick-up, 21 June 2010 - 09:02 AM.
#90
Posted 21 June 2010 - 07:55 PM
but im to confused what to do at them moment.
