9973 replies to this topic
#3781 Rocket.
Rocket.
  • 1,444 posts
Posted 20 April 2014 - 06:59 PM
Was going to go for a drive but it rained so I polished it
What polish did you use?
Auto glym super resin polish
#3782 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 27 April 2014 - 09:13 AM
New carb gaskets, drilled airbox and fitted K&N element filter. All ready for rolling road. Also fitted metro anti-run on valve, and tapped the metro distributor body as the thread for the cap had failed.
Also watched it suffer in the rain.
#3783 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 27 April 2014 - 09:29 AM
yesterday I went and picked up a front subframe with suspension and brakes etc still attached so I stripped that down.
#3784 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 27 April 2014 - 06:29 PM
Took it out for a run, same as yesterday. Bliss! Proper driving! :D
Really need to get on the wash and sealer side of things, it's properly unshiney after 5 months in the shed!
#3785 RooBoonix
RooBoonix
  • 1,225 posts
Posted 27 April 2014 - 06:53 PM
Over the past week:
Installed black fillets in the fornt and rear window seals.
Put 2 new boot cables in.
New shiny mountney steering wheel.
Fitted an accelerator pedal rubber.
Found out a vacuum hose wasn't connected so got that re done.
Went out today to find my indicators have packed up (hazards work but when using indicators the flasher ticks randomly and the lights don't flash)
Fitted a proper radiator bracket.
Time to try and sort my indicators out!
oh, and also when I was out today, had my first ever "under the bonnet" moment when the car idled really badly. Felt good to be in the land of the Mini :D
Cam.
#3786 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 27 April 2014 - 07:00 PM
looked at it outside getting wet.
#3787 Minigirl
Minigirl
    With Steve
  • 1,109 posts
Posted 27 April 2014 - 07:02 PM
:( poor bob he wanted his new parts but the rain did not allow  :shades:
#3788 alex-95
alex-95
  • 6,078 posts
Posted 27 April 2014 - 09:15 PM
Started washing it, I got as far as getting the hose out and spraying it, then decided I'd better sort out the leaks, so did that and found my advance pipe had fallen off and the right angle pece broke so had to fix that. then I packed up :lol:
#3789 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 27 April 2014 - 09:47 PM
Drove it
#3790 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,021 posts
Posted 27 April 2014 - 10:28 PM
Opened the bonnet, looked around, closed the bonnet. Over two years with no progress  :(
#3791 zinzan
zinzan
  • Just Joined
  • 373 posts
  • Local Club: me and my imaginary friend
Posted 28 April 2014 - 02:36 AM
Found rust!  Bonnet edge lip held on with two itty bitty bits of actual steel and mostly about a pound of bondo.  Not exactly the bare metal result I was hoping for...
#3792 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 28 April 2014 - 05:58 AM
Re mounted the spotlights as fed up with the ******* gear bought from MITP last year. Will put the bumper back on this week so its ready to use if the weather is dry.
#3793 meathead
meathead
  • Validating
  • 31 posts
Posted 28 April 2014 - 07:13 PM
New cv joint. Upper and lower ball joint. Wheel bearing on drivers side.
Then a half hour of zipping about to celebrate getting it finished.
#3794 RooBoonix
RooBoonix
  • 1,225 posts
Posted 28 April 2014 - 08:03 PM
Got my indicators working! Wooooo.
Was a dodgy connection on the relay in the engine bay :)
#3795 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 28 April 2014 - 08:46 PM
Pulled in to services with water leaking from the radiator, topped it up again and then went and bought a new one to fit. Then realising it was ****, gave up, never buying an alloy rad again...
8 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
    Bing (2)
