Took it out for a burn again
Filled up with fuel and discovered the neck of the fuel tank leaks
Drove back to the shed, drained the tank and affected a repair. Try it again tomorrow.
#3796
Posted 28 April 2014 - 10:54 PM
#3797
Posted 29 April 2014 - 11:56 AM
Edited by megamini_jb, 29 April 2014 - 11:57 AM.
#3798
Posted 30 April 2014 - 07:56 PM
Got my hazard light switch to illuminate/flash.
Checked and adjusted the valve clearances.
Fixed the vacuum pipes (hopefully)
Started her up, she ran sweet, went to turn her off and she was a bit too eager to stay running and had to be stalled or a wire taken off the ignition coil!
Woo, another thing to investigate hehe ![]()
The life of a Mini owner....
#3799
Posted 30 April 2014 - 07:59 PM
#3800
Posted 30 April 2014 - 08:30 PM
Added red oxide primer to the body around the engine bay with brush,then flatted it all back.Took the rocker cover off to strip and repaint or polish,and noticed to my amazement the the 9/16 nuts on the rockers were a few threads up from being tight,loose as feck.
Surely they are not run loose after a engine rebuild,for a certain amount of time??,previous owner rebuild!!
#3801
Posted 30 April 2014 - 09:27 PM
Edited by IainStallard, 30 April 2014 - 09:44 PM.
#3802
Posted 30 April 2014 - 09:29 PM
#3803
Posted 30 April 2014 - 10:24 PM
#3804
Posted 30 April 2014 - 10:54 PM
I think getting the rubber gaiter round the neck of the fuel tank on an estate must be about the biggest ******* of a job on a mini!
2 hours faffing and it's 'nearly' on.
Got the camber and cater angles 'in the ballpark' until I get to my mate's lovely flat power-screeded garage floor to finalise ![]()
#3805
Posted 01 May 2014 - 03:06 PM
Fitted sparkly new water pump, changed oil & filter, took out battered old radiator.
#3807
Posted 02 May 2014 - 01:18 AM
Drove it to work! First time in 5 months
Handling much improved, steering lightened loads, lovely 'plush' ride, apart from a few teething niggles all is good ![]()
#3808
Posted 02 May 2014 - 05:17 PM
Nothing - got man flu ![]()
#3809
Posted 02 May 2014 - 07:34 PM
Edited by Smackfiend, 02 May 2014 - 07:35 PM.
#3810
Posted 02 May 2014 - 07:56 PM
5 user(s) are reading this topic
Bing (2)
