9973 replies to this topic
#4081 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 29 June 2014 - 04:54 PM
Fitted HiLows and a few bits and bobs. Looks sweet now!
#4082 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 29 June 2014 - 05:16 PM
Removed the rear subframe from Ron. Only one snapped bolt which was later removed. Stripped down the subframe and cleaned up the components, ready to fit to the new subframe. Also repaired a section of the heel board. Finally I swept up a few kilos of crusty subframe from the floor.
#4083 a_woolhouse
a_woolhouse
  • 993 posts
Posted 29 June 2014 - 05:33 PM
Took it to the south staffs hotrod, custom, retro show :D
#4084 rodandtom
rodandtom
  • 998 posts
Posted 29 June 2014 - 10:39 PM
Fitted inner and outer cv joints to both drive shafts. Just waiting for the tool to do up the strap around the gaitor to arrive and I will fit them then.
Had a go at fitting the radius arms and the new trumpets and comes but failed dismally at that.
Rod
#4085 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 29 June 2014 - 10:42 PM
Fixed grille slats
#4086 Udo
Udo
  • 1,670 posts
Posted 29 June 2014 - 10:44 PM
Bought a new (well second hand to me) wheels
#4087 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 29 June 2014 - 11:31 PM
Fitted my split rims to my red mini. Need to sort out some arches now though and adjust the ride a bit lower.
Done more cutting on project and making panel order in the morning to make a start on the welding
Edited by megamini_jb, 29 June 2014 - 11:33 PM.
#4088 Minimadgaz1964
Minimadgaz1964
  • 194 posts
  • Local Club: Crewes Missiles, Minifinity
Posted 30 June 2014 - 05:07 AM
Took mine to the Burnley Motor Show, nice turn out of cars there and it stayed dry
#4089 ribz0
ribz0
  • 188 posts
Posted 30 June 2014 - 10:03 AM
Fitted some new seat belts, changed the oil and swore at it..... Grrr.....
#4090 Chunk
Chunk
  • 31 posts
Posted 30 June 2014 - 12:39 PM
Fitted new steering rack (pig of a job), new steering column bushes, new ball joints over the weekend. New Engine mount tonight and new brakes when they arrive ready for the MOT in a couple of weeks.
That should keep it on the road for a while yet.
#4091 rodandtom
rodandtom
  • 998 posts
Posted 30 June 2014 - 06:26 PM
Fitted one radius arm fine, the other has a problem with the rubber around the knuckle so I am going to need a new one :-(
Also built up and fitted drive shafts and put front disks on.
Rod
#4092 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 30 June 2014 - 06:29 PM
Changed the HG AGAIN this afternoon. Hopefully this one wont leak. And painted the new rear spacered drums as well.
#4093 silve1999
silve1999
  • 1,146 posts
Posted 30 June 2014 - 07:05 PM
Put bat in and started her up for he first time in about a month
#4094 Richie83
Richie83
  • 1,495 posts
Posted 30 June 2014 - 07:14 PM
Greased up the rear nipples, but ran out of grease!
#4095 will_
will_
  • 201 posts
Posted 30 June 2014 - 07:41 PM
Started to access the o/s door step & hinge panel. Both shot so started to strip back :/
    Bing (1)
