9973 replies to this topic
#5311 Rocket.
Rocket.
  • 1,444 posts
Posted 01 November 2015 - 08:42 PM
Put the rocker cover back on
#5312 Zach P-D
Zach P-D
  • 444 posts
Posted 01 November 2015 - 09:07 PM
went to source some squeaking, noticed an engine mount bolt missing. hopefully squeak is gone and and engine is now more secured.
#5313 b_sdaddy
b_sdaddy
  • 643 posts
Posted 01 November 2015 - 09:27 PM
replaced both of the rear rubber brake hoses - perished & leaking!
#5314 spiguy
spiguy
  • 1,537 posts
Posted 01 November 2015 - 10:52 PM
Just drove it, for the second unseasonably dry and sunny day in a row. Nice to get some more time out in it before it is put to bed for the winter. Got a thumbs up from a guy in an old triumph stag, and some waves from some fairly drunk guys coming out the pub!
#5315 Chris.Williams
Chris.Williams
  • 679 posts
Posted 02 November 2015 - 06:53 PM
Removed the inner pot joints to replace the hub seals before fitting the engine back in the car. Still need to do the gear selector shaft seal as well......ho hum it never ends.
#5316 fenghuang
fenghuang
  • 796 posts
Posted 02 November 2015 - 09:19 PM
Paid someone else to do stuff I can't do, and tell me I needed to do stuff I couldn't figure out myself ... and then paid them to do that as well.
Also felt I got decent value for money. Which was a pleasant change.
#5317 lawrence
lawrence
  • 1,341 posts
Posted 02 November 2015 - 10:36 PM
Ordered a new to to me alternator to replace my unreliable one without a tensioner. Also bought some second hand shocks to replace my knackered gaz ones that may have not been working! Shall wait and see!
#5318 petey81
petey81
  • 1,354 posts
Posted 02 November 2015 - 10:49 PM
Started the centre speedo conversion.
Only the speedo cable and dash liner to fit. Completed bravely without a wiring diagram.
I was dreading rust but all sound.
#5319 Chris.Williams
Chris.Williams
  • 679 posts
Posted 02 November 2015 - 11:54 PM
Did you change from the speedo in front of your steering wheel to a central speedo???
#5320 petey81
petey81
  • 1,354 posts
Posted 02 November 2015 - 11:59 PM
I did yes
#5321 fenghuang
fenghuang
  • 796 posts
Posted 03 November 2015 - 08:21 AM
I did yes
Do you happen to have 3 clocks you want to get rid of?
#5322 mini-auto
mini-auto
  • Just Joined
  • 102 posts
Posted 03 November 2015 - 09:25 AM
Today the revering lights on my blue auto are going to work.
Yesterday i found no continuity in the G/BR wire from the switch to the back end, no continuity in the G wire from the heated rear window, though the heated rear window switch does have power. The reverse light switch itself works (checked with multimeter & the reverse lights themselves work when I put power to them via a connector in the boot.
So I suspect connectors in both G/BR & G wires.
#5323 Chris.Williams
Chris.Williams
  • 679 posts
Posted 03 November 2015 - 09:27 AM
I did yes
Have you got any pictures??? Before and after maybe hmmmmm. Interested to see
#5324 moolieferret
moolieferret
  • 43 posts
Posted 03 November 2015 - 09:54 AM
Ran out of Petrol  grrrrrrr  dodgy fuel sender unit ,
#5325 Eds.mini.lulu
Eds.mini.lulu
  • Just Joined
  • 137 posts
Posted 03 November 2015 - 12:16 PM
I have been considering this conversion is it a particularly straight forward conversion. I have a 3 clock mini. Have seen minispares do a loom conversion for this and I will probs also wire in a tacho in front of the steering wheel. Is there anything else I would need to consider. And had anyone else used the loom from minispares ... Sorry to hijack thread.
    Bing (1)
