9973 replies to this topic
#5326 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
  • Local Club: Birmingham Mini Owners
Posted 03 November 2015 - 03:39 PM
Finished putting me stainless RC40 exhaust on today. Bit of a struggle as the otherwise beautiful looking LCB left the rest of the system pointing every which way but the right one, got it there in the end. Fitting kit bobbins had no nuts and nor did I so rather than buy some I ran a tap through some 8mm ones and converted them to UNF, worked a treat. Here`s the view followers will see:-
Attached File  exhaust.jpg   53.98K   4 downloads
#5327 David128
David128
  • 644 posts
Posted 03 November 2015 - 03:58 PM
Fitted new festoon Lamps in interior and number plate lights.. LED Festoons lovely.
#5328 petey81
petey81
  • 1,354 posts
Posted 03 November 2015 - 06:11 PM
I did yes
Do you happen to have 3 clocks you want to get rid of?
I have the 2 clock one
#5329 petey81
petey81
  • 1,354 posts
Posted 03 November 2015 - 06:12 PM
Started the centre speedo conversion.
Only the speedo cable and dash liner to fit. Completed bravely without a wiring diagram.
I was dreading rust but all sound.
I have been considering this conversion is it a particularly straight forward conversion. I have a 3 clock mini. Have seen minispares do a loom conversion for this and I will probs also wire in a tacho in front of the steering wheel. Is there anything else I would need to consider. And had anyone else used the loom from minispares ... Sorry to hijack thread.
Hi most of the wires are the same or just follow the loom on the centre clock as its very clear.
#5330 petey81
petey81
  • 1,354 posts
Posted 03 November 2015 - 06:14 PM
Did you change from the speedo in front of your steering wheel to a central speedo???
I did yes
Have you got any pictures??? Before and after maybe hmmmmm. Interested to see
Hi i didn't take any pictures but i will with it in place at the weekend as already screwed in.
#5331 Chris.Williams
Chris.Williams
  • 679 posts
Posted 03 November 2015 - 06:51 PM
I did yes
Excellent that will be great to see
#5332 Big Sam
Big Sam
  • 853 posts
Posted 03 November 2015 - 06:52 PM
Took some of the scrap metal to the tip!
#5333 Rocket.
Rocket.
  • 1,444 posts
Posted 03 November 2015 - 08:36 PM
Ordered a new loom
#5334 Chris.Williams
Chris.Williams
  • 679 posts
Posted 04 November 2015 - 10:55 AM
Fitted my metro motor today. Changed my driveshafts for pots instead of hardys and swapped over my CV joints. Found I have a broken stud for my engine stabiliser. Shopping time.
#5335 David128
David128
  • 644 posts
Posted 04 November 2015 - 11:14 AM
Today fitting new speakers into Dash connecting Radio correctly, connecting oil pressure and vacuum gauges.Still got to do the drive shaft inboard gaiters.
#5336 briancaveman2003
briancaveman2003
  • 197 posts
Posted 04 November 2015 - 01:01 PM
fitted some clear back lights 20151023_135523_zpstbqskbyt.jpg 20151023_135633_zpspc8ih57h.jpg
#5337 briancaveman2003
briancaveman2003
  • 197 posts
Posted 04 November 2015 - 01:04 PM
fitted rear clear lens
Edited by briancaveman2003, 04 November 2015 - 01:13 PM.
#5338 briancaveman2003
briancaveman2003
  • 197 posts
Posted 04 November 2015 - 01:07 PM
fitted rear lenses and hopefully fit my 4  8-1/2 inch spots tomorrow   20151014_162555_zpsvqhxpivh.jpg
Edited by briancaveman2003, 04 November 2015 - 01:09 PM.
#5339 bob540
bob540
  • 357 posts
Posted 04 November 2015 - 01:10 PM
Brought it for its NCT, failed on rusted sills, knew they needed doing mind, can't put them off any longer now. I can feel my wallet getting lighter as I type :(
#5340 joshw
joshw
  • 154 posts
Posted 04 November 2015 - 01:21 PM
Just got back from minispares with:
Timken front bearings
Ball joints
Heavy duty tie bars
Adjustable lower arms
And a few other bit and pieces
Today hasn't been kind on the wallet
    Bing (1)
