#9736
Posted 12 May 2025 - 05:55 PM
#9737
Posted 13 May 2025 - 03:58 PM
Fitted a new mpi carpet set and booked it in for some body/paintwork above rear valance.
#9738
Posted 16 May 2025 - 03:11 PM
Prepped it for paintwork in two weeks.
#9739
Posted 20 May 2025 - 12:30 PM
More fettling on the new carpet - drivers side corner. Also, fitted the new battery.
#9740
Posted 27 May 2025 - 01:33 PM
Changed my leaking heater matrix for a new brass/copper one, hoovered the front carpet and stuck it down properly with some tape.
#9741
Posted 27 May 2025 - 05:00 PM
#9742
Posted 28 May 2025 - 11:38 PM
Finally put one of mine in one of my sheds after a car shuffle!
#9743
Posted 31 May 2025 - 02:34 PM
Low noise HIF44 air intake is done. 1380 with MG Metro Intake manifold was noisy with the K&N cone and also had limited height so could not get a std filter box on.
Posted 31 May 2025 - 03:42 PM
Finally fitted and wired in the centre console. It was a tight fit but looks great.
20250531_120447.jpg 45.99K
26 downloads
20250531_120359.jpg 75.54K
18 downloads
Think I am pretty much finished on the interior now!
#9746
Posted 02 June 2025 - 03:58 PM
Fitted new rear bumper and attached new pop rivet to left arch (where one came loose).
Annoyingly, after a run to fuel up, the car cut out. Glad it happened on my drive! Turns out the connection to the starter motor is f*****! Took the grille, sides, and hose off, ready for tomorrow where I'll add a new connection. I had this issue before and made a temp fix. This time it will be permanent fix.
Edited by RichMPiBlue, 02 June 2025 - 04:08 PM.
#9747
Posted 03 June 2025 - 01:56 PM
Fitted a block connector to the starter motor, now that darn connector issue should be fixed for good! I then rewired the spots and cleaned up the grille while it was off (adding new screws once back on to attach). Some fettling to do to the alignment of grille/sides, no rush though.
Edited by RichMPiBlue, 03 June 2025 - 03:40 PM.
#9748
Posted 03 June 2025 - 02:32 PM
Are they live wires into an uninsulated chop block!!!
If so it looks like a disaster waiting to happen. Hopefully I'm wrong.
#9750
Posted 03 June 2025 - 04:09 PM
That looks great, I might do that myself at some point. Could you give me the link for the centre console and additional USB bits etc?
