Rings gap-checked and fitted, pistons fitted, big ends torqued and I’ve started assembling the top end, not a bad afternoon’s work
Edited by Bobbins, 14 July 2025 - 11:25 AM.
Posted 13 July 2025 - 09:38 PM
Posted 14 July 2025 - 02:37 PM
Posted 14 July 2025 - 03:06 PM
Very nice! Looks like you've optimised you're rocker geometry too.
Annoyingly the tolerance / movement in the stud holes will allow the spacer plates to kiss the valve springs slightly if they're not pushed rearwards when doing the final clamping down. Not something I'm happy with so I've ground a small amount off the front of each plate, a shame when they're so beautifully made!
Edited by Bobbins, 21 July 2025 - 01:31 PM.
Posted 25 July 2025 - 07:56 PM
Posted 26 July 2025 - 07:34 AM
Edited by petey81, 26 July 2025 - 07:36 AM.
Posted 27 July 2025 - 03:54 PM
Posted 27 July 2025 - 04:43 PM
Posted 28 July 2025 - 10:00 AM
Oulton Park Gold Cup weekend and bumping into Bill Sollis has enthused me to revisit his excellent rebuild video and attempt my gearbox rebuild myself … what could possibly go wrong!
Edited by Bobbins, 28 July 2025 - 10:33 AM.
Posted 28 July 2025 - 12:39 PM
I had a dig around the scrap bin and found a couple of 1/2" hex bar off cuts, not in the greatest condition but they did the job, no doubt you can work out what they are for and which position they go.
Shooter
What are they for?
Posted 28 July 2025 - 07:18 PM
What are they for?I had a dig around the scrap bin and found a couple of 1/2" hex bar off cuts, not in the greatest condition but they did the job, no doubt you can work out what they are for and which position they go.
Shooter
Posted 07 August 2025 - 10:12 AM
Posted 09 August 2025 - 01:23 AM
The last 2 months my Mini has been off the road.
Week 0 Decided I was fed up with right rear tyre rubbing on wheel arch when going over a dip in the road. Decided to put cones back in and remove coil over shocks. ordered red dot cones, 4 news hilos, the rear suspension bars and new spax krypton shocks all round from Mini Spares.
Week 1 Nowt waiting for parts to arrive.
Week 2 went to fit rear cones and shocks found out I forgot to order new knuckles as the originals had been removed. fitted rear shocks.
Week 3 decided to lift the front and get warped disc turned. Noticed big puddle of brake fluid, left caliper leaking like a sieve. Ordered Calipers, pads and Discs from Mini Sport.
Week 4 the week from Hell. Fitted rear cones bars and knuckles all done in less than an hour. Started on the left front, removed old knuckle ,hilo and cone. Installed new cone then spent 2 hours trying to get the knuckle back in. read and re read my Haynes manual watched 3 youtube videos, it all seemed so easy. The I saw the little rubber cushion under the conrol arm not mentioned in Haynes or the videos, well once this was removed knuckle just popped in like flynn. Total time over 4 hours and temp was 37C. Installed right side next day in 2 hours. installed front shocks.
Week 5 Went to install front brakes, caliper didn't fit disc is too far out from swivel hub. Called Mini Sport and talked to Mick, turns out I had Metro drive flanges not Mini ones. ordered new Drive flanges.
Week 6 nowt waiting for parts.
Week 7 Fitted new drive flanges, calipers now fit Thanks Mick for all your help. Installed the rest of the braking system, bled it with the help of Er indoors. Adjusted the hilos and took it for a test drive, runs and handles great and stops on a sixpence.
Just need to readjust the left front hilo and all will be well. Now I can enjoy driving it again with no rubbing.
Posted 09 August 2025 - 06:22 PM
Replaced fuel hose from regulator to carb. Charged battery. Jump started after being sat for 18 months.
Still need to change clutch slave cylinder and considering deleting the brake servo.
Posted 09 August 2025 - 06:44 PM
Posted 09 August 2025 - 08:17 PM
