Mini Virgin Rebuild Of 83 Mayfair.
1006 replies to this topic
#301 Carlos W
Carlos W
  • 10,115 posts
Posted 17 November 2011 - 07:49 PM
I fancy a go at this electolytic rust removal on the radius arms etc!
#302 minifcd
minifcd
  • 246 posts
Posted 17 November 2011 - 07:56 PM
I like your "science project" Graham! I have tried electrolysis on some small parts and it works well, but for the majority I now use malt vinegar, Morrisons own brew! Works a treat! You can get it in large bottles for next to nothing. I use it neat but for larger parts I dilute it 50/50 with water, throw your parts in and leave for a week. When you take them out they're covered in crud but it washes off with a hose pipe to reveal clean metal underneath. May need to repeat for heavy rust and dry well after wash to prevent flash rust, but it requires very little labour with no increase in your electricity bill!
#303 grahama
grahama
  • 2,442 posts
Posted 17 November 2011 - 09:27 PM
I have used vinegar too, but left my wheel nuts in for 3 months doh, came out round lol !!! Does the same job though. Haven't used molases yet in the mix because washing soda is only 90p per bag and lasts for ages !!
#304 minimuk
minimuk
  • 1,947 posts
Posted 20 November 2011 - 06:09 PM
I will have a go with your cristalls,....... takes cleaning small parts to a new level..... :proud:
#305 grahama
grahama
  • 2,442 posts
Posted 24 November 2011 - 03:42 PM
Hi all,
Been a little lazy recently but done a couple of things including rust removal and waxoiling. Before shots are of rust on the next end to do as forgot to do before pics, but the rust is the same.
Before Posted Image
after Posted Image
before Posted Image
after Posted Image
before Posted Image
after Posted Image
Not too bad and the other end is in as I type. When all done I will wire brush to remove all other crap, kurust and paint after a little patch.
Then I decided to get some waxoiling done in the sill and valance closer sections. Got some clear stuff, a 5 litre sprayer and a piece of tube I had over and made a high pressure sprayer. Not perfect but did the job fine.
Got spraying away, in the box sections that I have at the moment including the cross member in the cab. Think I over did it a little though !!
Still, all cleaned up and better protected than before, ready for the big chill if it is comming this year lol
Stink of waxoil now, another telling off from Jan, doh !!
Graham
Edited by grahama, 24 November 2011 - 03:46 PM.
#306 minimuk
minimuk
  • 1,947 posts
Posted 25 November 2011 - 10:40 PM
Excellent work there Graham,......waxoiling yamyam,... got to be done,..... glad you had a good go at it, saves to do jobs again next year, your rust removal looks great, I am still waiting for my charger,....
#307 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 26 November 2011 - 04:06 PM
Hello Graham, as a Chemistry teacher I am absolutely fascinated by your electrolytic rust removal!! It does make logical sense. Cathodic protection which is often used to protect bridges, piers, overland pipes, etc. from rusting, is protected in a similar way. A current is passed into the steel object and stops the iron from losing electrons and hence oxidizing, or rusting! That is why all cars should have a negative earth! Trust good old British cars to have gone for a positive earth in the older days. You will have seen from your sacrificial electrode why positive earthing is not good! I should give it a go but I just get stuck in with the wire cup brush on the grinder, such is my impatience!!
As always Graham you impress!!
My best wishes to you
Hugh
#308 087dave
087dave
  • 952 posts
Posted 26 November 2011 - 04:11 PM
Not forgetting ships hulls use cathodic protection as well with great results
Well done on the project graham keep it up!
#309 grahama
grahama
  • 2,442 posts
Posted 26 November 2011 - 06:56 PM
Well I didn't know the cathodic protection was used as an ongoing protection method !! I do like the easy action method of rust removal, sometimes though I have to resort to the wire brush for speed. Just a shame I can't put the whole mini in a bath !
Hinge bolts drilled out today too by my friend with a workshop / engineering shop in his garage, so doors on soon for final front end fit.
Graham
#310 grahama
grahama
  • 2,442 posts
Posted 27 December 2011 - 05:17 PM
Hi all and a very merry Xmas to you all.
Not been doing much really but a little update. I have been off work for a few weeks recently due to leave blocks, but the weather has been awful, so no chance of work outside. I had my hinges sorted by a friend last time I was working and this was the result.
The nuts are fine but foul on the door skin, so once welded up I will grind that side down so the door opens properly.
I turned my attention to the engine while inside and stripped and checked the rocker from the head I got and all seem fine.
Also took this oil switch off for a check, not sure what it does but it looks fine.
So then the engine block was up for a little tlc and went from...
to...
Unfortunately Matt didn't like it and I am having to re do it in the blue the car will be eventually, enamel on order !! However I am sticking with these for a little colour on the outside.
I continued with the engine bits as I got a rebuild kit from South Lakes minis last week, bearings, seals, gaskets, core plugs, timing bits and thought I'd better clean up the rest of the engine stuff. Pistons were a little coked up so I stripped and cleaned them all up.
Also did the rest of the head bits, springs and collets, the valves and head are at the machine shop for a clean and new valve guides as two sets were too worn to carry on with. Getting all new guides, recut seats and lapping of valves for £70, not too bad.
Then as I was taking the last ring off the last piston I broke the oil ring spacer
A very nice man, Sledgehammer, is sending me some through, but I am still trying to decide if I am better changing the lot for a new set even though they looked fine to the macine shop. Will think about that one for a bit.
Carry on...
#311 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 27 December 2011 - 05:30 PM
Hi Graham
Glad to see you're moving on with this.
Can you drop me a PM please with the name etc of the machine shop you have used. The 1275 I have in the garage is getting a lonely and I feel the need for some TLC to be sent in its direction.
Steve
#312 grahama
grahama
  • 2,442 posts
Posted 27 December 2011 - 05:41 PM
Part two update, outside.
Put the hinges on doors and trial fitted, not too bad but the curve on the bottom still made them stick out too much for me. Thinking of re skinning them and fiddling about with the frame to get them tucked in at the bottom.
I have been emailing Neil, Project Erm, for advice and he has suggested things like slotting the hinge holes to pull the doors in at the bottom. Did that and worked fine but not totally and a door seal was very pinched .
Will have to let the hinge out a little so some fettling coming up next year. Same with the front end as today the weather was good enough to try and set the front end up with some self tappers and get it moving again.
OS side went ok, gaps not as good as I would have liked but will have to do as don't want to butcher the panels too much, already dented the wing !! There is a gap between the wing and the scuttle which I presume the sealer takes up, but will try to close up from underneath before that stage.
NS less favourable and some butchery required..
Can't get them to close up at the A panel join without pulling the wing 'in' and looking odd so will cut a piece in to help the join. Overall ok, but again scuttle join not brilliant, c'est la vie !!
Put the bonnet on and very tight at the front so will be messing about with that too !!
Not a big problem and tried the original bonnet too but that's tight too so things have moved slightly during repairs. However all will be right in the end and as long as it looks right then it will be fine id the bonnet is cut about a bit !!
Still enjoying it, but especially the engine bits at the mo,
Graham
#313 grahama
grahama
  • 2,442 posts
Posted 27 December 2011 - 05:44 PM
Hi Steve,
I used Dunright in warrington on an industrial estate near Bank Quay station. Old fella with all the gear, very genuire and seems to know his stuff. I have found him very reasonable and talks through what needs doing, not in a way that you feel you are getting ripped off.
Graham
#314 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 27 December 2011 - 05:52 PM
Hi Steve,
Graham
Thanks Graham
Much appreciated
Regards
Steve
#315 GrahamHill
GrahamHill
  • 91 posts
  • Local Club: GMOC (Glos)
Posted 27 December 2011 - 08:33 PM
Great project Graham.
I have read this thread a couple of times now and the work is great. Really inspiring. I used to live in Warrington and never knew of that place :/ still - live and learn i suppose.
