Mini Virgin Rebuild Of 83 Mayfair.
#331
Posted 08 January 2012 - 09:56 PM
#332
Posted 08 January 2012 - 09:57 PM
#333
Posted 08 January 2012 - 10:21 PM
Too late for the double roller bearing though, just my luck it has to be the most expensive bearing !! Better find it now than later though !
Graham
#334
Posted 09 January 2012 - 07:58 AM
Hugh
#335
Posted 09 January 2012 - 11:56 AM
Had a good inspect of all the bearings and cleaned them all with a degreaser. Then generously sprayed them with WD40 just to protect them till I rebuild it. Everything put in sealed bags to keep the moisture out, oil in and dirt out !!
Graham
90% it will be the double roller which is going wrong, your's will be the origional one, and yep £45 is a large chunk, but can't do without one,....
#336
Posted 09 January 2012 - 08:32 PM
Thanks for all the encouragement fellas, much appreciated.
Last stripping for a while, gearbox, back bedroom or for the wife !! I attacked the mainshaft today and the rest of the box internals, cleaned them and spent a frustrating couple of hours pushing plungers in!!
First the main shaft
First and third gears came off easily enough, thinnk they passed the inspection but am asking in technical just in case I missed something. Synchros for 3/4 and 1/2 were next, and I put a lovely sheet I had on my bed as a nipper over them to stop the ball bearings and springs flying everywhere. None lost so stripped them down, cleaned and reassembled.
Both looked fine as did the 2nd and 4th synchro sides but the 2nd gear had a chipped dog tooth.
I rang John at Guessworks up to have a chat about it as I didn't want to rebuild and have a crappy 2nd gear in the mix. He said it was ok to have one tooth chipped but all the rest are fine so should be fine. I also rang him up because I couldn',t for two hours, get the thrust washer out that holds the 2nd gear in place.
All the splines lined up but it wouldn't come out. John said clean it up and it will be fine if the tooth is ok, so that's what I did, degreased in situ and liberal WD40 to protect till I rebuild.
The thrust washer fot third gear came off much easier as there isn't as much play in the washer. Will have to have another go if the 2nd gear doesn't pass muster.
The balk rings looked fine but will replace them just to be thorough, but how do they look to you, worn or fine???
On to the box selector internal stuff and a crappy roll pin that I had to drift out. Carlos, another hour on this easy job !! Out it came and the shaft was next.
All cleaned up, marked as to which washers go with which bit and put away.
Just got to check the play on the selector forks and the case to clean up and paint and will order some parts for the rebuild if I can get some cash out of Jan !!
Hope you enjoyed,
Graham
Edited by grahama, 09 January 2012 - 08:35 PM.
#337
Posted 09 January 2012 - 09:19 PM
Impressive marking those selector forks, I got it wrong the first time on mine, checking before and after pictures, I noticed it after engine was completely rebuild, I was very happy then,.........not
#338
Posted 09 January 2012 - 09:23 PM
#339
#340
Posted 09 January 2012 - 09:28 PM
dou you mean inside the sleve as here ??
If so it is mint inside there, no nicks at all.
or inside the case where the assembly runs through??
Edited by grahama, 09 January 2012 - 09:30 PM.
#341
Posted 09 January 2012 - 10:14 PM
Hugh
#342
Posted 09 January 2012 - 10:37 PM
Hugh, you are too kind, but I've not got it back together yet !!!
Scott, there are no grooves left by the ball bearing, if that is what you mean. Yes looks like I have been lucky, all the gears and synchros are in a thread in the technical section for a once over, but Guessworks has not looked at them yet!!
Graham
Edited by grahama, 09 January 2012 - 10:38 PM.
#343
Posted 09 January 2012 - 11:23 PM
Minimuk,
Yep that is the bit with the yellow arow pointing towards it, they can be worn if mint one less thing to worry about
#344
Posted 09 January 2012 - 11:28 PM
That's my theory anyway.
#345
Posted 10 January 2012 - 06:38 PM
looked at my balk rings and they have sharp grooves none worn down, what do you think??
And looked at the selector pin, thought I was looking at the sleeve it runs through which has no grooves.
The pin has marks on where the ball bearing ran but they are not discernable as anything other than a shiny mark.
Tested the selector forks with thier synchro and the play in 1/2 selector is 0.45mm and 3/4 selector 0.2mm. Acording to Guessworks anything up to 1mm is ok so will be sticking with these. Cleaned the residue out of the case too today but forgot a pic. Am going to have a go at polishing it up and not painting just to have a go and if I'm not happy will paint it later.
Graham
Edited by grahama, 10 January 2012 - 06:41 PM.
