Mini Virgin Rebuild Of 83 Mayfair.
#556
Posted 01 July 2012 - 07:56 AM
#557
Posted 01 July 2012 - 09:38 AM
#558
Posted 03 July 2012 - 07:24 PM
Hugh
#559
Posted 09 July 2012 - 09:10 PM
Edited by Shep76S, 09 July 2012 - 09:11 PM.
#560
Posted 12 July 2012 - 08:30 PM
momentus day here today, some paint got sloshed on !! But first I stripped and etched the boot lid.
Put this aside and mixed some rustoleum with white spirit at about 5-10%. Think I need to be more exact to be honest for coverage.
Came out ok, bit thin and patchy but another coat will sort it. Rollering was hard going over the stonechip, but can't get the mini inside the tent to spray so roller it was.
Not too bad for my first attempt, no reactions so far but it was taking it's time to dry, probably my mixing !!
Turned it upside down to bake in the sun.
doing it this way meant that I missed small bits but they will be caught up on the second coat.
and this bit under the vallance I just can't reach at the moment...
Very pleased !!
Graham
#561
Posted 12 July 2012 - 08:32 PM
#562
Posted 12 July 2012 - 09:02 PM
#563
Posted 13 July 2012 - 05:36 PM
#564
Posted 13 July 2012 - 09:33 PM
yes Brams it is good old combi colour, and thick it is just too long drying, thinned in the sun it was much better but not quick enough. A fellow tmf member says thin to 20% thinners and it will dry quicker, but with cellulose thinners. I dutifully went and got some and, as I said, rain so will report hopefully tomoz or Sunday !!
Brams, have you posted pics of ur underside, or have I missed them, and how long did it take to dry ??
Graham
#565
Posted 13 July 2012 - 10:50 PM
#566
Posted 14 July 2012 - 12:11 AM
#567
Posted 14 July 2012 - 11:58 AM
First coat was dry yesterday so this morning I was up early, got dogs walked and set about the second coat in the sun. An hour later I had this.
Not sure if it shows but the second coat is far better coverage wise and I used cellulose thinners at 20% this time which seems to be drying quicker. Not without the problems though.
Mainly paint runs onto the top side but will sand them off before I go any further
Also realised after the first coat I had not sealed this join from wing to inner wing so will have to smear some tiger seal in there and paint over later. Also will have to do under the spit bolts, but no big problem. This was the bigger problem
The joys of working outside. I left as long as I dared before covering it all up and am hoping the rain willl hold off till dry. Proper hardness will probably take a while longer but tomorrow the subframes go back on along with battery cable and fuel and brake lines !!!
Graham
Edit -
got away with it, all dry now and got some paint onto the patch under the rear vallanve too. Think the non sealed gap is actually sealed but not too thickly. Stonechip and paint will see it ok I think.
Edited by grahama, 14 July 2012 - 05:20 PM.
#568
Posted 14 July 2012 - 05:25 PM
#569
Posted 14 July 2012 - 07:07 PM
#570
Posted 14 July 2012 - 10:19 PM
I have learnt so much through this build, ups and downs, but his forum does bring you back up. Glad you like my thread, more of a diary of my progress than a 'how to', but glad it helps people. Welding, fabrication filler and spraying are just some of the skills you learn!!
Graham
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
