Mini Virgin Rebuild Of 83 Mayfair.
#601
Posted 07 August 2012 - 07:50 AM
i know most people just put it over bare metal .. but you really dont want to the moisture can get under the bog and stright on the steel and them it starts to come off
panel shops dont have time to prime them bog them prime again .. thats why its just stright over the top
#602
Posted 07 August 2012 - 08:03 AM
Kind wishes
Hugh
#603
Posted 07 August 2012 - 08:26 AM
Will leave the scuttle ends and go over etch in the other areas. At least it will give me a comparrison for the futurre to see what works best !!
Graham
#604
Posted 07 August 2012 - 01:23 PM
its the most horrible job no matter what though!! its getting there so enjoy the trip and hurry up and get back for an update on this!!
#605
Posted 07 August 2012 - 06:35 PM
By the way stunning work as per usual this car is going to be a beauty once finished :)
#606
Posted 08 August 2012 - 08:18 PM
also try do long smooth strokes, from end to end i found that always helped me apply filler relatively smoothly
looking forward to seeing this in paint :)
#607
Posted 13 August 2012 - 04:46 PM
#608
Posted 13 August 2012 - 09:53 PM
Photobook have messed my account up so not sure when the old pics will be back as all out of order now so could be a while getting the thread back on track. However todays pics may work !!
Back from hols in Brugges with wifey Jan in the sun, restaurants and most importantly beer emporiums !!
Anyway back on the mini, more dreaded sanding to the scuttle and a panels !
Driver side a panel didn't need much except over the welds but the passenger side I had to cut and weld to fit so it needed some more work to get right, but the sanding is getting easier lol !!
Pass a panel turned out ok and a second go at the scuttle ends gave me these
Passenger side looks pretty good but there is still a small step on the driver side. As I may have mentioned I hate sanding lol, so may well just work with it if it does not nag at me as it is smooth and looks presentable for a first go !!
Gave it all a good etch priming and put it to bed. Working front to back on the filler side of things, rear quarters next then strip the rear panel and do that, phew, getting there !!
Graham
Edited by grahama, 14 August 2012 - 09:32 AM.
#609
Posted 14 August 2012 - 09:26 PM
by the way that beer yr where drinking there in Brugges was that 'Mort Subite'?
#610
Posted 15 August 2012 - 04:52 PM
Muk, the beer in the picture was called 'Kwak'. It is always served in that glass and that is the small one but they are strong so just that for starters. Many beers later each day my eyes were not that focussed lol !!
Back to the buisness at hand, more sanding !! To the rear quarters this time my process on all the filler is this
start
first slop on
second pass
third if needed and it usually is lol
to etch
I am sanding with 80 grit to get the initial filler smooth and on the following layers I use the old paper which is significantly smoother but not sure the grit, probably should use the correct grit as everyone suggests and take the guess work out of it. The end product comes out ok though, and am still learning this stuff !!
Window surrounds also had some coats and the actual panels too as I marked the metal stripping the paint off.
Which left me with two rear quarters pretty much done, couple of pin holes in the window filler to sort but quite pleased apart from a little overspray of etch on the sill.
As with working outside on the day I get revved up to do loads it promptly rained just as I started to strip the boot panel, c'est la vie !!
Graham
Edited by grahama, 15 August 2012 - 04:54 PM.
#611
Posted 15 August 2012 - 05:01 PM
My tips...
- Use a good filler, upol Fantastic is the best I've ever used
- I have always only used the filler on bare metal, any paint underneath can promote sinkage.
- Don't use etch on top of the filler, that can cause reaction.
- For large areas use a steel ruler to help level off the filler.
- For curved surfaces, wrap the sand paper around a filler spreader.
- If you see a bit you are unhappy, don't think"It will look better with paint", it won't!! Any defects look a 1000x worse when painted.
I actually quite enjoy filler work, its quite satisfying!!
#612
Posted 15 August 2012 - 05:19 PM
#613
Posted 15 August 2012 - 05:44 PM
Graham
#614
Posted 16 August 2012 - 05:48 PM
getting there !!! A minor set back but nothing unsurmountable for my amateur skills lol.
sun was out but forecast was rain by early afternnon so out I went when the neighbours were up, grinder in hand and the noise started.
A couple of hours later the rear panel was stripped, the valance I was not so particular about as it is quite unseen, but it was smooth. I have to say I do like the chrome look of bare metal, but on a mini it is just about the most ridiculous thing you could do lol.
I did find some pitted metal on the roof gutter but it was strong and it got a good kurusting and etching. All this area will be thoroughly seam sealed when I paint the roof aswell for additional protection.
I stripped off the seam sealer off the welds on the valance so I re did this. Also I ground down the the layers of metal from the boot floor, rear panel and vallance join as I had forgotten it and it looked very untidy, so the sparks flew for the last time hopefully and I seam sealed the joint to help keep the water out !!!
I ran out of my bargain ebay etch, which covers very well and is half the shop price so got some upol stuff.
I got quite a surprise when it was dark grey !! I will be putting a couple of high build coats on the whole car so hopefully it will all look the same eventually. I also like the valance shot here, a deseamed valance is my prefered look but it's not my car. Minis look meaner with the seam gone imo.
The only filler required on the rear panel is here where I was too agressive with a strip disk, quick job, but the set back came when I had a look at the other day's filling on the passenger side.
This looked fine from the other direction, probably why I missed it but more time required here. Also looked into the boot and the tiger seal I put along the boot floor to rear panel seam has cracked where the stonechip was sprayed over.
This is pretty much along the whole joint, any ideas why it has cracked and what I can do?
Roof to do then bit of filler then spraying time woo hoo !!! The rain didn't come but need more etch first, however, Matt is very excited !!!
Graham
Edited by grahama, 16 August 2012 - 06:05 PM.
#615
Posted 16 August 2012 - 07:54 PM
Hugh
