Mini Virgin Rebuild Of 83 Mayfair.
#706
Posted 03 November 2012 - 09:55 PM
Hugh
#707
Posted 03 November 2012 - 10:46 PM
#708
Posted 04 November 2012 - 05:43 PM
out again to try and keep a little momentum up. First job was to get the last wheels on. Nearly all done yesterday but needed to put a couple of half nuts on the flexi brake lines at the rear before putting them on. Put them on and it was sitting near enough on the tyres. Wound up the hi lo's and ended up with this.
First time in over two years it has had all four wheels on, nearly brought a tear to my eye !!
Inside next to finish off the painting, yes I did say painting in 6 deg temps, outside !! I had some of the old sound deadening to take off, which was hard, cold and brittle. So got a heat gun on it and soon had it iff and the inside rear panels cleaned up.
All painted, only by brush, but it will be covered up with nes sound deadening and the cards so no need for perfection. Inside is completely done now, another small milestone. On to the sound deadening...
As with the door skin it is the bitumen roofing flashing that seems popular, just can't justify the proper stuff, sorry purists !! I heated the panels and the flashing to get the bitumen sticky and laid on. Awkward corners and dips has some extra heat to mould them.
The lower bulkhead certainly sounds less tinny than before so it is doing it's job. Lots more to go before I can put some carpets in lol.
First time in a few weeks I have had all the covers off and am noticing the dreaded rust
Primer is definately porous as it has absorbed this from the general atmosphere, not rain. It will be getting a full rub down before paint now !!
Regards,
Graham
#709
Posted 04 November 2012 - 05:59 PM
#710
Posted 04 November 2012 - 07:12 PM
#711
Posted 05 November 2012 - 08:47 AM
#712
Posted 05 November 2012 - 11:48 AM
progress is awesome. looking ace as usual. I went to my mini the other day and it had surface rust on the new repairs that I'd painted up. I was devastated so I know how you must have felt! haha.
keep up the great/inspirational work!
Joe
#713
Posted 05 November 2012 - 03:18 PM
Darren
#714
Posted 05 November 2012 - 05:33 PM
I dont know how you manged to get all your suspension bits on without scratching the paint. They look great
Andrew.
#715
Posted 05 November 2012 - 07:57 PM
#716
Posted 05 November 2012 - 08:05 PM
It is indeed the intention to get it all ready and hopefully working before next year's warmer weather so I can paint glass and hand over. He is a grumpy teenager so appreciation isn't in his vocabulary yet, but next year he will have a grateful smile on his face !!
I did expect some surface rust due to it only being in primer but not looking forward to rubbing it all down again to re prime and then paint. I have put more covers on to help keep the atmosphere dry in there but I will see soon as I do more work if it works. If things get too bad I will rub areas down and re prime patches just to keep on top of it.
Regards,
Graham
#717
Posted 05 November 2012 - 09:46 PM
Hugh
#718
Posted 05 November 2012 - 11:03 PM
screwfix has it at 10m x 225mm for £20. a couple of rolls should be plenty depending how much you want to cover. I have one 225mm and one 100mm which I found in the shed but will buy another 225 one I think. Not too bad for a car full I think.
It has an aluminium top layer so the bitumin is hidden underneath allowing carpet or underlay to be stuck to it !
Graham
Just seen Toolstation has it at £16.32 for the 225 x 10m !!
Edited by grahama, 05 November 2012 - 11:04 PM.
#719
Posted 06 November 2012 - 02:24 PM
#720
Posted 20 December 2012 - 09:24 AM
I have just spen 2 1/2 hours ( of work time ha ) reading every page of this. This has been an excellent build and the pics ect are bloody amazing. Keep up the truely amazing work and I look forward to more updates.
P.S..... subscribed !
Edited by Badboytunes, 20 December 2012 - 09:25 AM.
Bing (1)
