Project Mini
#286
Posted 16 March 2006 - 08:12 AM
[/quote]
Replicas of the Miglia Race arches used in the Miglia Race Series, got them from Custom Mini's
#287
Posted 16 March 2006 - 06:19 PM
#288
Posted 16 March 2006 - 08:37 PM
Ive got a gear indicator, that is what is pi**ing me off so much. It programmes fine and accepts all the gears, but anything above 2000rpm and it loses the gear, What chuffing use is that on a bike engine??
Your running an R1 engine, are you using the bike clocks?.
#289
Posted 16 March 2006 - 08:46 PM
#290
Posted 16 March 2006 - 08:56 PM
I'm going to do the same on the Mini, it's got something to do with the pulse generated to make the original speedo work which also is connected some how to the rev's generated.
Obviously i don't know how the spa system works but they must have a help line you could get intouch with to help you out.
Hope that helped, sounds a bit gobbledi to me too.
#291
Posted 16 March 2006 - 08:59 PM
#292
Posted 16 March 2006 - 09:58 PM
#293
Posted 16 March 2006 - 10:07 PM
Quote
Do you think it is the signal from the gearbox which is problematic??? I cant connect to the ecu for the revs bcos i have the exup error which wont go away!!
Yes i think thats probably whats causing the fault, can you not put the exup motor back on, i'm keeping mine.
#294
Posted 16 March 2006 - 10:13 PM
#295
Posted 16 March 2006 - 11:39 PM
For the time being you will have to count.
#296
Posted 20 March 2006 - 07:17 PM
I'm anxious to see more progress!
Took my mini for a quick spin down the road before, i miss driving the mini, and can't wait to be driving an R1 powered beast!
#297
Posted 23 March 2006 - 11:33 PM
How's things coming along Joe?
Took my mini for a quick spin down the road before, i miss driving the mini, and can't wait to be driving an R1 powered beast!![]()
Glad you went out in your Mini mate, could be your last as your selling it eh.
Started to strp down the entire engine and rear suspension assembly.
What a task, but will be worth it in the end, going to paint it with some zinc spray then silver which we have at work goes on quite thick.
Forgot how much work i've done on this as it's being stripped. Driveshafts, wishbones, hubs etc etc.
Couple of pic's of some bit's.
Posted 24 March 2006 - 12:16 PM
Sorry to hi-jack thread welderman.
I'm keeping an eye on the development of a gear indicator for the R1 that won't be a comparitor version. It's currently undergoing the final tooling run and should hopefully be available very soon. Will keep you posted when I know any more.
#299
Posted 24 March 2006 - 06:55 PM
Glad you went out in your Mini mate, could be your last as your selling it eh.![]()
Started to strp down the entire engine and rear suspension assembly.![]()
What a task, but will be worth it in the end, going to paint it with some zinc spray then silver which we have at work goes on quite thick.![]()
Yeah i know, went for another spin tonight... i'm going to miss it so much!
Can't wait to get another mini sorted
You have been busy haven't you! Looking good!
looking forward to seeing it again!
#300
Posted 24 March 2006 - 10:41 PM
