My Engagement Ring
1514 replies to this topic
#901 Carlos W
Carlos W
  • 10,115 posts
Posted 17 December 2014 - 05:58 PM
The gaps look spot on Carlos ;)
Thanks mate, when I fitted the front end I used a different bonnet to make sure all the gaps were correct. I need to fit it properly when I find the hinges
#902 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 December 2014 - 08:10 PM
Much better
#903 Carlos W
Carlos W
  • 10,115 posts
Posted 17 December 2014 - 08:49 PM
Much better
Cheers mate, I'm glad it was the bonnet and not the car that was wrong.
I bought the fibreglass bonnet from a member on here, I wonder if they knew it was a VERY poor fit?
#904 Carlos W
Carlos W
  • 10,115 posts
Posted 18 December 2014 - 11:49 AM
Just waiting for the paint to go hard before I work out how to fit it.
And also cleaned and painted these
Slowly slowly making progress
#905 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 December 2014 - 11:55 AM
That engine enamel really does give a nice finish!
Did you just weld ordinary bolts to the pedal box? I might have to do this with mine.
Good progress though! Even i got out to the garage this morning and did a little bit!
#906 Carlos W
Carlos W
  • 10,115 posts
Posted 18 December 2014 - 12:07 PM
I considered cutting the heads off, but didn't bother in the end.
My issue now, is that I have no idea how the pedal box mounts at the dash rail end.
I've got the right bolts that go into the bulkhead, and I've cleaned the threads but I'm a bit snookered.
The PDF haynes manual seems to skip chapter 6
#907 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 December 2014 - 12:10 PM
Easy peasey mate.
You should have a thick metal plate with threaded holes that site inside the dash rail. That goes in and then the steering column bolts to the thick plate sandwiching the pedal box between.
If needs be, ill find mine and show you
#908 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 December 2014 - 12:12 PM
Item 58 on this Fische
http://www.somerford...page=page&id=50
#909 Carlos W
Carlos W
  • 10,115 posts
Posted 18 December 2014 - 12:13 PM
Easy peasey mate.
So for now, I can just bolt the front end in?
Is it sort of wedge shaped?
#910 Carlos W
Carlos W
  • 10,115 posts
Posted 18 December 2014 - 12:15 PM
Ah nice one, I need to find 57 and 58.
So the pedal box sits under the dash rail, it can sit there for now until I find those bits. They're in a box........
#911 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 December 2014 - 12:20 PM
Sounds like we sorted that then!
#912 Carlos W
Carlos W
  • 10,115 posts
Posted 18 December 2014 - 12:21 PM
It's be more sorted if I knew which box they were in...........
#913 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 December 2014 - 12:23 PM
You must have about 10 of them so it shouldn't be too hard to find one.
have a look in the Wok  :lol:
#914 Carlos W
Carlos W
  • 10,115 posts
Posted 18 December 2014 - 01:08 PM
It might be in the Quality street tin
#915 jpw1275
jpw1275
  • 2,803 posts
Posted 18 December 2014 - 02:58 PM
Looking good carlo.... :0).... just cant wait to start mine again...
cheers james
