My Engagement Ring
1514 replies to this topic
#946 Carlos W
Carlos W
  • 10,115 posts
Posted 23 March 2015 - 12:20 PM
You should be able to use the palm of your hand to gently persuade the front corners of the bonnet in slightly to match the wings.
Normally in doing that, you raise the sides of the bonnet slightly too high but in your case with it sitting low, I think it would work well.
Just remember slowly slowly catchy monkey.Move it only very slightly and then check and then repeat until it fits better. also, keep a close eye on the side edges of the bonnet where it folds at 90 degrees as these can and will crease easily if you bend the corners in too much.
I'm not saying it will work but it should do and it's easy so worth a go first.
Ben
I need to make a relief cut in the side lip of the bonnet as it's bulged.
I'm very pleased though, I was in a foul mood about it all yesterday
#947 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 March 2015 - 02:09 PM
Glad it went to plan mate! Looks great now.
Ben
#948 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 23 March 2015 - 08:33 PM
Which hinges did you go for in the end Carlos?  Minivation or Minispares?
#949 Carlos W
Carlos W
  • 10,115 posts
Posted 23 March 2015 - 09:27 PM
Minispares supply minivation hinges
#950 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 23 March 2015 - 10:20 PM
Well that's something I didn't know, I thought they were Minispares own design.
#951 Carlos W
Carlos W
  • 10,115 posts
Posted 23 March 2015 - 10:35 PM
They've got the M on them, come with the same instructions as those on the minivation website
#952 Carlos W
Carlos W
  • 10,115 posts
Posted 09 April 2015 - 10:17 AM
Really quick update, LOADS going on, however not much of it has involved the mini.
I've built a shed and put half the stuff from the garage into it
And then this morning I've strengthened the bracket on the bonnet where I've had to slot it to make it fit, unfortunately I can't clamp it anywhere to dress the weld so I'll have to wait until my mate comes round next weekend and we'll crack on then. It should be a lot easier with more space.
#953 Carlos W
Carlos W
  • 10,115 posts
Posted 23 May 2015 - 06:43 PM
I went into the garage today and found a mini.
I cleaned some of the sticky sealant off the lock striker plate then ended up cleaning the drain that runs in front of the garage door.
I'm really struggling with enthusiasm at the moment
#954 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 May 2015 - 07:28 PM
we can soon sort that out in July mate.
Having someone to come along and say 'right, lets do this' is just what you need
#955 Carlos W
Carlos W
  • 10,115 posts
Posted 23 May 2015 - 07:34 PM
I told the bloke next door I'd be painting it on the drive
#956 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 May 2015 - 09:17 PM
Then i guess it's on!
#957 Carlos W
Carlos W
  • 10,115 posts
Posted 23 May 2015 - 09:21 PM
Just hope the gazebo goes up
#958 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 May 2015 - 09:22 PM
and stays up  O_O
Is it the same one we used for priming or did you get another in the end?
#959 Carlos W
Carlos W
  • 10,115 posts
Posted 23 May 2015 - 09:25 PM
and stays up  O_O
I got another frame
#960 Carlos W
Carlos W
  • 10,115 posts
Posted 29 May 2015 - 11:32 AM
Today I've fitted the drivers door catch striker plate.
I don't know where the screws are to fit the latching mechanism.
Hopefully I'll find some time towards the end of next week. If anyone know's where I'll find some enthusiasm that'd be great.
