Enthusiasm.... its always in the last place you look ![]()
My Engagement Ring
#961
Posted 29 May 2015 - 12:06 PM
#962
Posted 29 May 2015 - 12:09 PM
Is it with the screws for the door latch?
#963
Posted 29 May 2015 - 07:24 PM
#964
Posted 29 May 2015 - 07:25 PM
Pm me your address and I'll send you some stainless ones for free that should sort your enthusiasm out. I bought two lots
Cheers mate, I've got some somewhere as I've got new ones in the other side
#965
Posted 13 June 2015 - 07:13 PM
A quick update, I've nearly got the bonnet to fit properly, I've put the bonnet pin and seals on, and I think I need to modify the brackets on the bonnet so that it sits a tiny bit lower at the back.
Then I'm going to weld the brackets to give the whole thing a bit of strength. I also think the part the pin mounts to is a bit weak, I had to run a thread tap through it to clean the threads up and it was flexing.
#966
Posted 13 June 2015 - 08:48 PM
#967
Posted 13 June 2015 - 08:59 PM
Sounds good Carlos. Did you ever get the articulated joined?
If that's meant to be hinges, then yes
#969
Posted 14 June 2015 - 09:02 AM
Make sure you fit the locking pin etc before you adjust the back
#970
It's on mate, as is the seal on the back, if you look carefully you can see the lever to release
#971
Posted 14 June 2015 - 09:41 AM
oops. My bad
#972
Posted 14 June 2015 - 05:43 PM
If that's meant to be hinges, then yesSounds good Carlos. Did you ever get the articulated joined?
Yes, stupid swype keyboard
You missed out on a belting TT week Carlos
#973
Posted 14 June 2015 - 05:54 PM
Yes, stupid swype keyboardMinivation or Minispares?
You missed out on a belting TT week Carlos![]()
They're the same thing, although they're not the latest minivation ones.
The latest ones mount the same place as the original ones so may be a bit better.
#974
Posted 21 June 2015 - 02:34 PM
Ok, I've slotted the mounts where the hinges bolts to the bonnet and it's not getting any better.
But, if I take the seal off the back it fits fine, it may even be a bit low.
I'm going to replace it an make sure it's on as far as it'll go. If that doesn't sort it, am I just going to have to hope it gives over time?
#975
Posted 21 June 2015 - 02:37 PM
I think i know why
