Project 850 X
#151
Posted 11 December 2011 - 07:36 PM
#152
Posted 11 December 2011 - 09:05 PM
#153
Posted 13 December 2011 - 10:43 PM
#154
Posted 15 December 2011 - 05:36 PM
#155
Posted 03 January 2012 - 10:44 PM
they look good, had to cut bits of the binnacle to make the fit flash with wood at rear of the dash
all clocks.jpg 69.35K
13 downloadsall wires in right place and connection wires labled for the fitting
rear dash.jpg 69.3K
10 downloadsorganised wiring mess behind steering wheel, will all be hidden after, but will tie them toghether where possible in groups
Fresh air vents next, then trial fitting of the Dash,...it will be a different car me thinks.....
Edited by minimuk, 03 January 2012 - 10:46 PM.
#156
Posted 05 January 2012 - 04:27 PM
fettling with the air vents was the tricky part and trying to fasten bracket with my 'small hands' was a pain, but it is in.........all lights in bineacle are working and gauges to phew........connecting clock and V-gauge to fusebox tmr.
need to get used to this
dash in nearside.jpg 56.9K
14 downloadsand this
dash in offside.jpg 57.28K
10 downloadsMatty will be well happy with that......
#157
Posted 05 January 2012 - 07:00 PM
Hugh
#158
Posted 05 January 2012 - 07:21 PM
#159
Posted 05 January 2012 - 10:36 PM
#160
Posted 06 January 2012 - 07:01 PM
and today finally the dash got its place in the car,
need to get used to thisdash in nearside.jpg 56.9K 14 downloads
and thisdash in offside.jpg 57.28K 10 downloads
so today I connected the clock and Volt-gauge, all good and nice with the lights... then disaster struck, I over- tighten the T-piece for the oil pressure gauge and that one snapped off,..... not good, anyone got any Idea how to get that copper bit out, cant drill it out as metal dust might go into engine,.......
Edited by minimuk, 06 January 2012 - 07:02 PM.
#161
Posted 08 January 2012 - 02:14 PM
#162
Posted 08 January 2012 - 04:15 PM
Looks very nice, it's different from the more common dashboards!
Hey Rick, Happy new yr to you, well it looks better in the flesh, with daylight,and a propper camera not a moby. still I have a problem to solve first.
#163
Posted 08 January 2012 - 05:11 PM
In the aviation business we use a bit that tightens in the metal when turning anti-clockwise, so when it 'bites' enough in the metal you can continue with turning the bit anti-clockwise and the remaining bolt/screw will come out as well. I hope this description makes some sense, don't know how the describe it otherwise...
It is called an extractor set (found it via google): http://buy1.snapon.c...8&group_ID=1254
and we use this onehttp://buy1.snapon.c...9&group_ID=1254
I know the set is expensive, especially if you use it only once, but maybe you know someone who has got something like that :)
Edited by Risky, 08 January 2012 - 05:12 PM.
#164
Posted 08 January 2012 - 05:19 PM
Thanks happy new year to you too, do you by chance have a picture of the broken T-piece? (or whats left of it...)
thanks for that, i do have something like that but aint shifting it, but I am intreged with the second set you mentioned, I see if I can get something simular over here, in single units. no piccie to embarrasing
#165
Posted 08 January 2012 - 05:50 PM
Found a better pic, so you can get an idea of how they look like
