Project 850 X
277 replies to this topic
#166 minimuk
minimuk
  • 1,947 posts
Posted 08 January 2012 - 06:20 PM
I go and look for them tmr, in toolshop, nice little nuggets.
#167 Risky
Risky
  • 213 posts
Posted 08 January 2012 - 07:55 PM
Good luck ;)
#168 minimuk
minimuk
  • 1,947 posts
Posted 11 January 2012 - 08:52 PM
Good luck ;)
well, did all and tried all, no luck and not willing to wait on them nuggets (although I will get a set), so went to see the "mini professor" near were I live, He spend 2 hours on it and eventually he had to drill it out carefully, and told me off. I won't do that again,..... all good now, ordered parts again from minispares to have a second attempt. I will change oil to as that is needed now I feel.
#169 Risky
Risky
  • 213 posts
Posted 11 January 2012 - 08:59 PM
Good news that it finally came out, good luck with fitting the new one ;)
#170 minimuk
minimuk
  • 1,947 posts
Posted 13 January 2012 - 10:10 PM
yesterday I started changing the oil,emptied it and turned the engine over twice..............3000 miles and oil was like black treacle, left it overnight to drupe out, oil filter well,......not much oil in there but a lot of gunk... I suppose that is the reason for having one. nicely filled up again tonight and a new filter. Minisport had front drum backplates on a sale so for that price I went for it, and changed those tonight to, no more messing with adjusting front brakes for a while now!
Now waiting for minispares to drop of some parts for the oil pressure gauge,and we are nearly ready for Bingley. Don't know what to expect there as this is my first time there. Might see a few mini's.....
Edited by minimuk, 13 January 2012 - 10:10 PM.
#171 minimuk
minimuk
  • 1,947 posts
Posted 16 January 2012 - 09:25 PM
managed to get the t-piece and fitted in the block without braking this time, connected braided hose, and oil pressure sensor, and all good, reads 55 on idle, give him a run tomorrow and see what other figures it trows at me, and checking for the famous oil leaks.
I need to adjust the points to tomorrow and that should be it,.....ready for Bingley
#172 billok
billok
  • 228 posts
Posted 17 January 2012 - 07:08 PM
that connectors are you using for the brakes??
#173 minimuk
minimuk
  • 1,947 posts
Posted 17 January 2012 - 09:57 PM
hi, sorry I might have not been clear enough, the t-piece connection elbow is for the oil pressure gauge,....I did brake the last one by over-tightening into the block.
#174 minimuk
minimuk
  • 1,947 posts
Posted 17 January 2012 - 10:04 PM
A few test drives today, oil pressure when engine is warm, on idle it reads 28psi and on 50miles+ 70psi. I am happy with that, only the t-piece needs one more full turn into the block, showing a little wet oil but nout to serious.
Points checked and all good, bit colourtuning at some point this week and fettle with carb.
#175 STREET TWEAKS
STREET TWEAKS
  • 662 posts
Posted 17 January 2012 - 10:12 PM
lookin forward to seeing the mini at the show and you in your wet suit lmfaf
#176 minimuk
minimuk
  • 1,947 posts
Posted 17 January 2012 - 10:32 PM
goggles and flip flops, beachballs and all that ;D
#177 minimuk
minimuk
  • 1,947 posts
Posted 23 January 2012 - 05:38 PM
Today Muk's dizzy, points not good, set on 0.012 revving yes but no push and not enough fuel to justify the noise, went silly,.. can't have that before Bingley, took it of, and gave it the once over,
its a 59D4 from 1981, so battered a bit I guess;
needs a good clean
stuck it back in again and gave it a run, all good but don't get high enough revs, will have to set points to 0.014 or 0.013.thats tmr
Edited by minimuk, 15 February 2013 - 12:53 AM.
#178 minimuk
minimuk
  • 1,947 posts
Posted 30 January 2012 - 03:03 PM
have a bit of a problem with higher rpm, engine starting to judder lightly and still can't get passed the 53mph, timing set again, fuel CO2 sorted out again, no blockages either,..condensor,points all good, coil checked is 3ish Ohm resistance power to coil is 11.74V when set key on run (settin 2 on switch), alternator charges 14.5V when engine running,It is quit a drop from 13.75V to 11.74, could be the clock or even could be a power leak somewhere, maybe at the just fitted gauges,...and still at ift for the last 4 days eliminating all possibilities
will take fuses out one by one and see if engine runs better,without that circuit then I should be able to pinpoint it further ,...I hope >_<
#179 STREET TWEAKS
STREET TWEAKS
  • 662 posts
Posted 30 January 2012 - 10:26 PM
good look mate, hope you get it sorted
#180 2-alex-2
2-alex-2
  • 480 posts
  • Local Club: SouthWalesMini club
Posted 30 January 2012 - 10:41 PM
looking good. and hope you get the engine problem sorted
