Project 850 X
277 replies to this topic
#241 ToM 2012
ToM 2012
  • 4,066 posts
Posted 20 October 2012 - 08:12 PM
the parts no good there mate?
#242 minimuk
minimuk
  • 1,947 posts
Posted 27 October 2012 - 08:48 PM
Hey Tom, hope you had a good time there, well you probably spend a few pennies in Malvern.
I got back last night from my Euro Trip, all went well but Muk used a lot of oil(2 litres over 1645miles). I gave Muk a deserved good wash behind his ears and started to check the engine, I noticed a lot of clean oil on the Block to Gearbox lip. Meaning both Tappet Covers at the rear of the engine had moved a little and that was the reason. OK on Short journeys but janking for hours on the Motorway at 75-80 Mph build up the oil pressure and when oil is hot and thin it started to leak.
So this afternoon half the engine out, cleaned the lot and replaced the cork seals with new ones, I hope that that was all it was, bit of gum-gum around the exhaust joint and give him a go.
#243 ToM 2012
ToM 2012
  • 4,066 posts
Posted 27 October 2012 - 09:05 PM
howdy mate did you have a good time? sorry to ear about the engine hopefully it turns out to be nothing worser then new gaskets?
#244 minimuk
minimuk
  • 1,947 posts
Posted 27 October 2012 - 09:14 PM
Tom, really, Muk preformed great, not his fault the gaskets where worn, he certainly passed the endurance test doing over 1600 miles in a few days, through all wheathers on flat roads (France-Holland), bumpy roads (belgium), hilly roads(Ardennes and Eifel), and speeding near the Nurmburg ring, most trips where anything from 2 hours to 12 hours.
#245 ToM 2012
ToM 2012
  • 4,066 posts
Posted 27 October 2012 - 09:22 PM
sounds like you had fun i bet its a killer driving constant? got any pics of your trip? thanks tom
#246 minimuk
minimuk
  • 1,947 posts
Posted 27 October 2012 - 09:24 PM
I did put about 40 on FB, search my name and see what comes up
Edited by minimuk, 27 October 2012 - 09:25 PM.
#247 minimuk
minimuk
  • 1,947 posts
Posted 29 October 2012 - 02:10 PM
OK sofar I have done the following after our Eurotrip return......
1.new cork seals on tappet covers (oil Leak)
2. re-sealed all the exhaust joints after taking apart to get to tappet plates
3. reset the dizzy points to dwell 54(was 68)
4. re-set timing, moved to correct position(was 6 degrees retarded?)
5. tuned the carb after as this was to high on CO2
All done now and sounds and looks good, taking him for a spin later ;D
#248 markje
markje
  • 183 posts
Posted 29 October 2012 - 07:02 PM
AAhhh after your holiday busy again
#249 jonny f
jonny f
  • 1,492 posts
  • Local Club: Boxhill Mini Club
Posted 29 October 2012 - 07:39 PM
Car looks lovely now!
Any plans to get it a little lower? Would look spot on with a little drop.
#250 ToM 2012
ToM 2012
  • 4,066 posts
Posted 29 October 2012 - 08:10 PM
put channel 5 on mate and anyone else on here.
#251 minimuk
minimuk
  • 1,947 posts
Posted 07 November 2012 - 09:37 PM
Have decided to finish MUK with a well deserved Stage 1 Kit, , ordered cooper freeflow, heated inlet manifold, and a few other bits,.... Sunday getting engine ready ready and a carb refurb, Monday new bits in....a bitta timing and tuning and blast him a few miles after,......can't wait ;D
#252 STREET TWEAKS
STREET TWEAKS
  • 662 posts
Posted 08 November 2012 - 09:30 PM
you goting to have road fast cams to at a later date mate or not ?
#253 minimuk
minimuk
  • 1,947 posts
Posted 08 November 2012 - 10:00 PM
that will be the next step, kit in first and see how he talks to me.....
#254 STREET TWEAKS
STREET TWEAKS
  • 662 posts
Posted 08 November 2012 - 10:20 PM
i like it :D
#255 minimuk
minimuk
  • 1,947 posts
Posted 10 November 2012 - 07:10 PM
Had 2 hours this afternoon on him,.. took SU Carb of, 2 in 1 Manifold, Pipe to down pipe and cleaned back of the engine, stopped leak of the sump plug by using a Nylon washer instead of a solid copper one, and worked on the Hif38 to offer to the new set-up soon.......
Back at work full restaurant from 7.30 on.......
