Project 850 X
277 replies to this topic
#76 minimuk
minimuk
  • 1,947 posts
Posted 09 June 2011 - 11:42 PM
A few things done today between shifts, the alternator arrived today, and the bootlid seal(the earlyer on to put on the lid)When I got back after work tonight I fettled with the seal, what a job, although it is easy it is kinda precision job to line-up the clamps with the holes in the lid, after about ten done I got the hang of it.
the beginning, the trick is to hear the clicking noise whemn pushing the clamp in the little holes so the clamp is locken and the seal is tight against the metal rim.
nearly there
done, clever design though, where the seal end meats the other end there is a 1" gap between the clamp holes, in the middle of that is the hole to push the numberplate wire through,so the wire through first and then re-position the seal ends toghether again and wont show the cut.
now I can put all the silver-ware on the lid and put it in it's final position. fingers crossed no surprises!!
Might put in the 70Amp alternator first and let him talk to the new battery,
#77 minimuk
minimuk
  • 1,947 posts
Posted 10 June 2011 - 05:54 PM
As I finished last night I realised it was this morning, anyhow time flies when havin fun,...............
Today I managed to change over the old 45Amp alternator, with the new Simon's shop 70Amp one, battery getting fed nicely.
The old Lucas looks sad compared to the new one.
45amp
70amp
then I carried on with the boot-lid and the shiny thingies
boot lid lock well grease up,especially in the rubber cup/sleeve
lock and light on
complete,ready for tryal fit maybe tonight,cooking tea first :)
#78 minimuk
minimuk
  • 1,947 posts
Posted 12 June 2011 - 08:46 PM
lovely rainy day today, had to wait till rain had passed to put the boot lid on, 7PM......
never easy on you own putting a lid on for sure
nearside
offside
full back
new seal sits ok, but 2mm out on bootpanel offside bottum corner this could be well the 1.5mm hinge gasket which pulls the whole lid out, bit tweeking tomorrow appart from that it looks fab.
#79 grahama
grahama
  • 2,442 posts
Posted 13 June 2011 - 06:56 AM
Looking great you must be pretty chuffed. That is the paint set up I am thinking of for mine, a good choice I can see from yours!
Graham
#80 minimuk
minimuk
  • 1,947 posts
Posted 13 June 2011 - 01:37 PM
Graham
Cheers Graham,
well getting there, final bits need tweeking, exhaust off again today, was touching the gear stick colum when ticking over, put doorcards in today,little stuff like window washer hose T-piece with valve is gone so needs replacing. Electrics nearly ok, and clutch and breaks need bleeding again.
Bucket seat subframes need sorting,......................2 weeks
Waiting for floor felt and still haven't made up my mind what carpet!
Day off today, but busy the rest of the week so not much will be done,...... unless I find some time here and there
#81 Mini-Mad-Craig
Posted 13 June 2011 - 02:16 PM
Awesome, she's a beast!!
#82 STREET TWEAKS
STREET TWEAKS
  • 662 posts
Posted 13 June 2011 - 08:25 PM
looking good matey :thumbsup:
#83 minimuk
minimuk
  • 1,947 posts
Posted 14 June 2011 - 07:28 AM
Cheers, but it is a definate HE, a beast he is,.....not far of now!
Edited by minimuk, 14 June 2011 - 07:31 AM.
#84 minimuk
minimuk
  • 1,947 posts
Posted 20 June 2011 - 07:02 PM
the last few days I have been tinkering with the "power-leak", new alternator and battery, Speaking to Dan Dan the Caravan Man he gave me some advise how to trace the fault, in the end it was two things what was draining the power. 1) the head light flasher, poor contacts and 2)the old fuse box. the flasher switch needed a clean and adjusting the contacts, and the fuse box,all points bad enough coroded to replace the lot. Nice job......not. Patience required here and a clear head for sure, an ammeter and a volt meter, and chasing wires, while doing this cam accross a dodgy Line fuse for the interior light and the hazerd warning light, needed new cable and fuse. All done though but not worth a picture.
Here he is with some old wheel hubs on the 10", the refurbed 12" will finish those in July waiting for Simon's tyres.
after that I finished the door cards and today I put flashing tape (nicked Idea from Stevede) at the inside of the bulk-head between the top and bottum dash panel, flashing tape will not absorbe moisture, as the old felt-foam used to do, and stops it from rust build up-inside the car, where you can't see it.
note the old chair, will be gone soon bucket seat subframes mounting tomorrow
Attached File  DSC01885a.jpg   45.15K   20 downloads
one more layer of tape, then hard rubber foam for backing.
Edited by minimuk, 20 June 2011 - 10:22 PM.
#85 DaveJH
DaveJH
  • 393 posts
Posted 20 June 2011 - 07:39 PM
Really nice project, great attention to detail. Looking forward to seeing the final result!
#86 minimuk
minimuk
  • 1,947 posts
Posted 21 June 2011 - 04:53 PM
Cheers Dave
today a few things done. first the subframes on the mini bucket seat's, easy enough to do, there are 4 holes under the fabric, need to locate those and make a pilot hole with a small sharp tool, put subframe on and line up with the marks you made and screw in the T50 torx screws. before tightening all 4 screws make sure the gliders are centered so the lock-brackets are both locking at the same time, amazin what 1mm can do.
Both done, now waiting for the cross-member mounting brackets to dry from the final coat of paint
And then the UPS van came with the new Grill Kit from M-Spares. I could not leave it in the box it had to go on,......
Checking the size first.....
Happy chappy, he has a smile at last
Attached File  DSC01898a.jpg   84.03K   21 downloads
That is it for this week, will be busy at work till Thursday next week!! Buggar
#87 minimuk
minimuk
  • 1,947 posts
Posted 28 June 2011 - 06:23 PM
just had a few minutes this afternoon, thought might aswell put the bonnet on, now the engine bay is sorted.Not sure whether I fix the bonnet badge, I will in the end for sure
so not far to go now,last job's;
attach Vinplate
floor carpets
fit bucket seats
number plates
finish dash
test drive(again)
Insure,Mot Tax
What can I say...... nearly there
#88 minimuk
minimuk
  • 1,947 posts
Posted 01 July 2011 - 04:31 PM
after a nice morning in the garden (lawn mowing) I thought I should do a few jobs from the to-do list,
attach Vinplate; this one supposed to be where the water bottle is mounted, so I put it next to it and is visible enough.
finish dash; well I started a few weeks ago putting layers of flashing tape inside the car between the upper and lower dash, Stevede gave me that idea, so today I cut to fit and glued foam rubber mat to the flashing this gives you an excellent sound proofing as the Carb is rather noisy on the other side of the bulk-head, it looks easy but patience is required. great result, when I find a nice piece of black matt vinil sheet I will attach that one to the rubber mat to give it a nice finish.
floor carpets; Black Newton, this one is ordered from M-spares and should have that on Monday, next week fitting.
so the list is getting smaller!!
fit bucket seats
number plates
test drive(again)
Insure,Mot Tax
Edited by minimuk, 02 July 2011 - 07:46 PM.
#89 minimuk
minimuk
  • 1,947 posts
Posted 02 July 2011 - 07:45 PM
well today I got the floor ready for the carpet and flash-lined the inner bulk-head and foot boards, inner flitch
Attached File  DSC01911a.jpg   56.21K   15 downloads
ohh yes and a seatbelt
#90 minimuk
minimuk
  • 1,947 posts
Posted 04 July 2011 - 07:11 PM
The Newton Commercial carpet came today,
great quality stuff and good instructions to go with it, however, as Stevede has mentioned in the past the bulkhead liner and carpet in a pain in the b..side to fit, after that all should be easy, managed to do the bulkhead bits today as I run out of evo stick spray glue, Screwfix run tmrra.
under felt liner
carpet on bulk-head
Mind you it was a bit waarm today to fettle inside the car!!!
