Project 850 X
277 replies to this topic
#91 minimuk
minimuk
  • 1,947 posts
Posted 05 July 2011 - 10:58 PM
few more steps done this afternoon, floor carpet,....getting there!!
It is a slow process for me, as this is the first time I am puttting in a floor carpet in my first time mini resto, and all has to be 100%, no wrong decision cuts, only have one shot at it!!At least with the welding jobs you can start again,with this however,.......not!
Then again, my next mini will be easyer,..I hope
#92 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 07 July 2011 - 08:56 AM
You are getting there! But how can you face a next Mini??? I struggle to work on the one! It looks great.
Hugh
#93 minimuk
minimuk
  • 1,947 posts
Posted 07 July 2011 - 12:40 PM
Hugh
Hugh,
Putting the carpet in nicely is not easy the first time, so it will take a few more days in between shifts.
by the way,check this one out; Total Rebuild Of '71 Evy
I have started working on her beginning this year, had to stop because no space in garage to weld and grind with this one about, so will carry on with Evy very soon......
Michel
#94 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 07 July 2011 - 04:12 PM
Maybe you should seek medical help! All the best with Evy, then.
Hugh
#95 minimuk
minimuk
  • 1,947 posts
Posted 07 July 2011 - 05:07 PM
Hugh
lol,....to late for that now.... I am looking for a 1961 mini already, yep a bit mad, who cares. I have finished the floor this afternoon, had a good run, will put piccies up after work tonight. Seats tomorrow
Edited by minimuk, 07 July 2011 - 05:07 PM.
#96 minimuk
minimuk
  • 1,947 posts
Posted 07 July 2011 - 10:14 PM
I finished the floor carpet today, a bit more fettling tomorrow but it is in at last, Newton Commercial Carpet, excellent quality and worth the extra few bob.
started today with securing the crossmember piece, may I add that this is the only piece wich is glued on and only on the top, as the seat brackets will hold it in place at the front, and the rear carpet piece will hold it tight at the back of the cross panel. I must admit to put the seat brackets on was more work then I thought it would be, but the best result I got was to glue the carpet down on the top of the crossmember,then put a nail in any one of the bracket retaining nuts, push the carpet as tight as possible against the nail and use a sharp pointed dawl to press through the fabric after removing the nail, this is then your guide hole. use a seat bracket as template to locate the other retaining nut in the cross member keep the carpet tight against the panel and trial fit the bracket with the bolts. when doing the second bracket, on the same side,make sure your carpet is tight and there are no cross-wrinkles before you make the next holes. If you follow this, you are mad enough to do it.
As mentioned before, no glue was used not even in the inner sill panels, the sill carpet will be held in place with the door seal at the top and floor carpets on the bottem and secured with the seatbelt bolt.
Having finished both the sill pieces and the cross member piece, I felted up the tunnel, and the rear floors with glue spray, leaving an opening on both sides for the seat belt bungles and a gap behind the hand-brake lever to create enough access to the cable tightening nuts.
Attached File  DSC01926a.jpg   63.15K   17 downloads
Full carpet down, If in near future, my son want's to have speakers at the back I simply lift the carpets of the floor, run the wires and put carput back, further I did make 5mm holes every 10" allong side the inner-sill panels to be able to anually wax-oil the inner/outer sill area, so again simply remove the sill carpet, do the waxing... clean up the mess and refit the carpet. what can I say......
Attached File  DSC01927a.jpg   55.33K   20 downloads
finish this one tomorrow with attaching the seat-belt bungles to the tunnel and putting the seat's in.
Edited by minimuk, 07 July 2011 - 10:21 PM.
#97 minimuk
minimuk
  • 1,947 posts
Posted 10 July 2011 - 04:25 PM
a few mates came for a BBQ, in the back garden,....... I like the blue one best
Edited by minimuk, 10 July 2011 - 04:48 PM.
#98 minimuk
minimuk
  • 1,947 posts
Posted 10 July 2011 - 04:47 PM
Now my mates have gone,.......I did some final work on the MUK
Seatbelt bungles in,
rear wheel arch vinyl covers on both sides
trial fit driver seat and both seats in, did a short drive, noticed it would be better to change the seats on subframes as the driver-side seat was to low.
back in the garage with the seats swapped over after a little drive, much better and car easyer to handle.
Attached File  DSC01943a.jpg   51.53K   9 downloads
I gave the Carb an overhaul to as the fuel mixture was set to rich (to much carbon build up on the spark-plugs) and the engine backfired a bit. Also needed a new fan belt as I did not change the old one, just forgot, that got rid of the squeaking noise.
next few days order number plates and going to see my friend Micky Slater to give the mini a final inspection and verdict,.....and book him in for an MOT.
#99 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,154 posts
  • Name: Sean
Posted 10 July 2011 - 06:49 PM
I didn't realise you were also a serial project addict as well??
Some really nice work there as well, I'll be checking out and keeping an eye on your other stuff as well!!
#100 minimuk
minimuk
  • 1,947 posts
Posted 10 July 2011 - 08:25 PM
Shifty, Cheers,....I need to put that quote "SERIAL PROJECT ADDICT AT WORK!" on my Garage!!lol
I have learned a lot with this first one and looking with a critical eye myself,I know there are a few faults, and I suppose a trained eye will find those too. I will not repeat those on EVY that is for sure.
Thank you for keeping a watchfull eye on my projects, when Muk is on the road we can meet up one day at the Atcham-Wellington road, on those kinda monthly mini meetings.
Edited by minimuk, 10 July 2011 - 09:38 PM.
#101 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 12 July 2011 - 07:33 AM
It must be getting close to completion. I am longing till I reach that point!! It does look super.
Hugh
#102 minimuk
minimuk
  • 1,947 posts
Posted 12 July 2011 - 08:32 AM
Hugh
Hugh,
yep nearly there 99% , fettling here and there. Numberplates today give the brakes a once go over, check steering
(is a bit out) check the locks, align the head lights etc. MOT will be on the 25th 10 am. As this is my first project,...getting a bit nervous about it, then again if there is anything not right, it will be easy to solve,...I hope!
I will have a few cup's of tea when he passes the test though!!
#103 minimuk
minimuk
  • 1,947 posts
Posted 12 July 2011 - 04:02 PM
Number plates arrived today,...superfast service with-in 24 hr's
so I had an hour to kill, could not wait to put them on,...Rear first....looks good!
Attached File  DSC01947a.jpg   71.27K   12 downloads
Then the front........needed to make a steel back-plate and weld it onto the plate bracket's under the bumper, so sanded a few dot's on bracket's cut a bit of steel plate(slightly smaller then new number plate) marked and drilled holes for a bit of spot welding tomorrow, primed the lot and gave it a coat of black.
should finish that tomorrow,.....perhaps!
#104 minimuk
minimuk
  • 1,947 posts
Posted 13 July 2011 - 03:12 PM
1 hour brake this afternoon,.... front plate on. Muk has now an ID
plate welded on, sanded
and seam seal, and marked middle of car and numberplate
handy double side sticky tape, and voila.
I like it and he looks proud again.
Attached File  DSC01963a.jpg   82.53K   10 downloads
Edited by minimuk, 16 July 2011 - 02:34 PM.
#105 minimuk
minimuk
  • 1,947 posts
Posted 25 July 2011 - 12:18 PM
For those of you who have been watching this tread;
......................MUK HAS PAST HIS MOT...................... !!!!!!!!!!
Being my first mini, great feeling, hard work has payed of, and I am privileged to be another (miniholic) person who has been able to contribute to the upkeep and continuation of a British Classic.
Still a few things to do on it;
hifi
finish dash
change wheels to 12"
few arches if need be
Taxed tomorrow and on the road with it!!!
thank you all for your comments and chatter, good luck with your projects!!
Total Rebuild Of '71 Evy is next!!! she is something else!!
Edited by minimuk, 25 July 2011 - 12:20 PM.
