euro street racer
1154 replies to this topic
#301 andywaller
andywaller
  • 1,636 posts
Posted 18 October 2006 - 08:11 PM
avonbar HIF44 carb fitting kit £24.95
avonbar
#302 Tomm
Tomm
  • 2,462 posts
Posted 18 October 2006 - 08:34 PM
see that car the othernight and i almost weed myself! it looks even nicer at night!!
I think i am going to have a custom rear valance that lets me put my plate there and it still get through a mot!
Keep us posted how you do MOWOG (so i can steal the ideas for my project) ;D
#303 andywaller
andywaller
  • 1,636 posts
Posted 18 October 2006 - 08:46 PM
will do, im going to be doing loads over the next week, so there should be plenty to see.
hopefully i will be sending it away in a couple of weeks.
#304 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 18 October 2006 - 08:47 PM
:'( I'll keep telling myself... one day! one day I can say mine gone off for paint"
#305 andywaller
andywaller
  • 1,636 posts
Posted 18 October 2006 - 08:57 PM
paint :dozing: thats the thing of dreams, im only talking about getting it shot blasted. then and only then can i say that my car is 100 percent rust free! ;D
it going to be good after i have had that done. because i will then be welding on my new sills and rear valence.
then i will trial fit my front subframe, and put my doors back on so i can line up the scuttle and a- panels. then i can start makeing the removeable front.
then i need to trial fit the roll cage and make all the additions to that, mount my seat, extend the steering column and various other things.
all that has to be taken out then the inside will be sprayed. then the roll cage re- fitted after i have had it powder coated.
then i have to cut the roof off.
then i need to get my carbon doors made up.
and then deep breath. its time for paint.
still gotta decide on colour :-
#306 Jammy
Jammy
  • 25,397 posts
Posted 19 October 2006 - 11:10 AM
Mowog, if you haven't already bought them, and your sure you want to go with Carbon doors, I may have some brand new Curley ones for sale soon...
#307 andywaller
andywaller
  • 1,636 posts
Posted 19 October 2006 - 06:16 PM
cheers but i am getting a set custom made for me.
why do you ask if im sure? are they not the best of ideas then?
the boot is now done i grinded back the rest of the welds, and primed them. so that can go in the garage loft till im ready for paint now!
i took my passenger side hub and drive shaft into work and cleaned them in the parts washer. they have now been wire brushed all over and painted black, along with the disc centers and edge.
i have also given the drive flanges a second coat. and i have now dug out from my parts store new:
ball joint kit
wheel bearings
C.v joint
ive clean the treads on all the bolts so tomorrow when all the paint has dried i will assemble them. and again store them for when i build the subframes up.
pictures tommorow.
#308 andywaller
andywaller
  • 1,636 posts
Posted 20 October 2006 - 12:08 PM
just got bored and started weighing bits of my car!
my MB splits weigh in at 2.8Kg each! i was surprised to see that the Kad mag wheels dont weigh a huge amount less as they are 2.52Kg
and i weighed my old ERA turbo alloys and they weigh 6.2Kg each, so just by changing the wheels i will save 11.2 Kg ;D. impessive me thinks.
i just bolted my drive flanges to my discs as well they look really good.
#309 andywaller
andywaller
  • 1,636 posts
Posted 20 October 2006 - 12:39 PM
OMG i am a bad bad peson, just took out another loan so i can get my car done!!!!
roll on expensive paintwork!!!!
#310 mini bunnykin
mini bunnykin
  • 1,166 posts
Posted 20 October 2006 - 01:08 PM
i dread to think how many loans you have then huni!
what colours are you going for this time?
#311 Jammy
Jammy
  • 25,397 posts
Posted 20 October 2006 - 01:25 PM
Carbon doors, almost every thing I've read about them has been pretty negative. They are pretty much just a race item only, since the carbon window frame isn't amazingly strong, so at high speed they bow out, and apparently they can leak alot.
#312 andywaller
andywaller
  • 1,636 posts
Posted 20 October 2006 - 04:54 PM
ah thanks jammy that doesnt sounds so good, dont want wet carpets.
maybe i am going have to look into this a bit more.
i haevnt got too many loans wendy, i thnk the car has cost me twice what i thought so far!
and for colour its definately going to be black, with gun metal grey subframes and roll cage.
i got some stickers made up with my surname for my rear windows, and also one saying tow for my tow eye.
been to minispares and got stuck in traffic but i got:
hub puller
cam bearings
bronze valve guides
bootlid seal
rear brake springs
rear hub bearings
ball joint kit (to replace the ones i used on my others car)
bonnet pins
new eyelet bush for my gaz damper
upper arm repair kits
i was going to get a rear subframe but they are £165 and im sure i have seen them cheaper than that!
#313 minivanman
minivanman
  • 3,454 posts
Posted 20 October 2006 - 05:27 PM
Mowog, for the carbon doors couldnt you use the steel frame and bond/rivet a carbon skin to it? and add steel braces to the inside for strength?
Awesome sounding colour scheme!
#314 andywaller
andywaller
  • 1,636 posts
Posted 20 October 2006 - 05:30 PM
i had thought about something like this for the doors, its a good compromise i supose.
its taken a long while to come up with the scheme, just need to stick to it. the bits should be being powder coated next week or so so i wont be able to change my mind then!
#315 Jammy
Jammy
  • 25,397 posts
Posted 20 October 2006 - 09:18 PM
Aye, this is probably what I'm going to do with my doors, cut out the bottom half of the outer doorskin (below the window), and bond in a carbon fibre one.
