Edited by Lord Lucan, 07 December 2011 - 07:01 PM.
Unable To Pump Brake Fluid Through To Rear Cylinders
#46
Posted 07 December 2011 - 06:55 PM
#47
Posted 07 December 2011 - 06:56 PM
Edited by firefox, 07 December 2011 - 06:56 PM.
#48
Posted 07 December 2011 - 06:58 PM
Happy days then, have you tried to drive the car since then??
Needs some metal melting first... But one job out of the way....
by the way - My head lights (non standard) have only hi & lo beams... no side lights. Is that acceptable for MoT?
Thanks....
#49
Posted 07 December 2011 - 06:59 PM
I bet you can teach the boys on here a thing or two
Muliti-Tasking.... my middle name................
#50
Posted 07 December 2011 - 07:01 PM
mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
#51
Posted 07 December 2011 - 08:32 PM
I believe you need sidelights for the MOT. Is there provision for sidelights in the non standard lenses? If so you might be able to sort it.
What welding needs doing?
#52
Posted 07 December 2011 - 08:55 PM
First well done on the brakes and I'll be nicking that idea should I need to
The 1978 standard lenses had a small bulb that sat behind the glass sealed unit (built into the plastic push-on connector)... somebody has put units in with only hi and lo beam and no opening for a side light.
Light switch is Off/Side/Headlight - dipped on stalk...
Welding is 50mm patch just in front of rear subframe mount
#53
Posted 07 December 2011 - 09:02 PM
Not a lot of welding then. Don't tell me you weld as well as lateral think?
#54
Posted 07 December 2011 - 09:15 PM
No glass window where a sidelight would shine through? Some don't have a place the light would plug into but just have a window the light shines through.
I'll try anything once.....
Edited by Lord Lucan, 07 December 2011 - 09:17 PM.
#55
Posted 07 December 2011 - 09:18 PM
you never fail to amaze,
#56
Posted 07 December 2011 - 09:25 PM
You'd better wear better ppe than that pic though....welding splatter burns to buggery.
Edited by zef, 07 December 2011 - 09:26 PM.
#57
Posted 07 December 2011 - 09:30 PM
Good for you lol. Give us a shout if you need a hand. I've a load of welding to do on the Midget so i'll have got my hand back in soon.
PPE....!!! You've got to work with what you can....
Edited by Lord Lucan, 07 December 2011 - 09:31 PM.
#58
Posted 07 December 2011 - 09:33 PM
#59
#60
Posted 07 December 2011 - 09:36 PM
or this........ ingenious though, necessity is the mother of invention
Edited by Lord Lucan, 07 December 2011 - 09:39 PM.
