1098 Fast Road Help
#61
Posted 16 June 2012 - 09:09 AM
rods are either 12G123 or 12G126 (same as a 998 anyway)
the blocks on a 998 and 1098 are the same
this may help
http://www.somerford...age=page&id=112
#62
Posted 16 June 2012 - 10:20 AM
#63
Posted 16 June 2012 - 03:33 PM
so if i got a 1098 crank i could put it in my engine and make it 1098?
no, you need to use the 1098 crank and pistons.
you will also need the 1098/1275 crank damper otherwise the engine will destroy itself!!
Edited by oltonlad, 16 June 2012 - 03:34 PM.
#64
Posted 16 June 2012 - 03:48 PM
#65
Posted 16 June 2012 - 03:57 PM
whats the difference with the 1098 pistons?
the hole for the gudgeon pin is in a different place on the 1098 piston to counteract for the longer stroke of the 1098 crank....................you can not use 998 pistons with a 1098 crank.
#66
Posted 16 June 2012 - 04:08 PM
ah right,
that would be cool tho :L
#67
Posted 16 June 2012 - 07:54 PM
The timing cover i have has a bit on it that looks like a crank sensor housing would this be right?
Managed to roughly assemble a full engine now minus the gearbox and clutch partsso il just run through it again and then strip the rest of the donor and build it up again.
#68
Posted 16 June 2012 - 08:17 PM
Posted 16 June 2012 - 08:41 PM
Il take my camera to work tomorrow and take pics why i wait for paint to dry.Just want to get one engine assembled then i can start getting parts and getting work done!
#70
Posted 14 July 2012 - 09:10 PM
#71
Posted 15 July 2012 - 08:17 AM
Edited by oltonlad, 15 July 2012 - 08:17 AM.
#72
Posted 15 July 2012 - 02:27 PM
I will try and get some pics up later on when i can find a lead to suit my phone. At least the block number checks out to be a 1098 so a good chance the rest is! Found out the other day my engine builder used to build a lot of grass track engines and he knows a fair bit on how to get them to go.
#73
Posted 15 July 2012 - 02:31 PM
Can wait to start seeing it in a nice clean state unlike it is now!
#74
Posted 15 July 2012 - 05:03 PM
#75
Posted 15 July 2012 - 06:23 PM
Crank should see some balancing
Cam, still looking trying to make my cash stretch as far as poss, Minisport do a cam that runs 1000-6000 powerband so may ask them for advice.
New followers
New shells, rings and seals
New oil pump
New push rods
Duplex vernier timing gear
And new everything i can buy
Next question is one of the bolts for the timing gear housing hits the block and has nowhere to screw into, anyone had this problem? think its mid way up at the front of the engine!
