Project Checkmate....
561 replies to this topic
#406 rally515
rally515
  • 3,848 posts
Posted 29 July 2014 - 07:23 PM
Hi folks, nothing much progressed today due to the weather, just some electrical jobs....
I have got the whole nearside lighting and wiring finished, just need to finish the bodywork on that side and the side repeater can be fitted, along with the Indicator and Headlamp.
Also another little thing done today, I plugged the rear loom and front loom together and taped them up
Also I made this a few days ago but havn't had chance to plug weld in position, so i've just drilled the plug holes today and hoping for some good weather so I can fit it, it's for the windscreen washer bottle to mount onto the innerwing, the old one was thrown away with the old inner wing.
Thats all for now, i'l leave with a little inside photo of the inner sill, still pleased with how it's turned out :)
Cliff
#407 ToM 2012
ToM 2012
  • 4,066 posts
Posted 30 July 2014 - 05:20 PM
looking lovely mate  ;D
#408 rally515
rally515
  • 3,848 posts
Posted 30 July 2014 - 07:19 PM
Thannk Tom, much appreciated :).
#409 minbin 69
minbin 69
  • 465 posts
Posted 30 July 2014 - 07:38 PM
looking good mate,you'll be done in no time :thumbsup:
#410 rally515
rally515
  • 3,848 posts
Posted 30 July 2014 - 07:48 PM
Hopefully so!, need the Checkmate finished and the space asap really, hence the rush to do this mni and none of the others recently.
Thanks,
Cliff
#411 ToM 2012
ToM 2012
  • 4,066 posts
Posted 30 July 2014 - 08:25 PM
are you keeping this when its finished or selling it? i would love to keep mine but i cant see me using it as i have my own mini on the road its a hard decision to make dont no what to do..
#412 rally515
rally515
  • 3,848 posts
Posted 30 July 2014 - 08:41 PM
Yeah going to be selling it and giving the money to my Mum to spend or something.
I'm in a similar position, already have the Metro which is up and running ready to be improved and cleaned up abit after this :)
#413 rally515
rally515
  • 3,848 posts
Posted 31 July 2014 - 09:43 PM
Update!,
I've plug welded in the Washer Bottle clamp I made before and then pulse welded along the top edge for abit of extra shear force as the washer bottle being removed and replaced puts more load on it than usual.
Also I didn't grind down the plug welds because the were acting as a good wedge and kept the bottle solid in it's new home :)
Another little wiring job I metioned needing to do previously, the terminal in the lid of the servo had completly corroded away, there was no other way I could see of repairing it as the terminal went all the way down the lid and was melted into the plastic so best just to solder a piece of Thikish cable to the upright stem (about 20mm of solder holding it on) and shrink wrap the exposed end, came out quite neat after crimping the spade termminal on the end.
And finaly heres a plate i'm currently making for the servo and clutch master cylinder to mount on, it's about 1.5 to 2mm thick so isn't bending quite as easy as what i'm usualy fabricating with, also SS bends funny around the edges of the bend, quite different to mild steel in many ways.
Anyway, CAD Template:
And half bent:
Thats all for today folks, will probably spend abit of time grinding down welds on the other innerwing next in preperation for fitting the N/S Wing, and also i've still got to fabricate and under scuttle fillet pice for that side also.
Thanks for looking,
Cliff
#414 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 July 2014 - 09:50 PM
Blimy cliff, that washer bottle aint going nowhere!
#415 rally515
rally515
  • 3,848 posts
Posted 31 July 2014 - 10:37 PM
Hopefully not!, better to have too much than too little ;),  To be honest even if there wasn't a bracket the gap the bottle goes in is so small it wouldnt move around much anyway! >_<.
Next job is the N/S Innerwing, should make some good progress the next update and have the front Bar the A-panels done!!, still having major issues with those unfortunatly, looks like i'l be re-doing the whole lip that spot welds to the Wing just because they come up sort about 15mm, repo poo!
Cliff
#416 jpw1275
jpw1275
  • 2,803 posts
Posted 01 August 2014 - 06:21 AM
Top job as always cliffward
Cheers j
#417 rally515
rally515
  • 3,848 posts
Posted 01 August 2014 - 12:21 PM
Cheers j
Cheers James,
Weathers turned bad today so looks like im going to have to stcik with cleaning bits and bats up :(
#418 rally515
rally515
  • 3,848 posts
Posted 01 August 2014 - 04:26 PM
Got abit done earlier before the heavens really opened!, the N/S wing is now ground down and Zinc Primed, I've then sprayed a layer of StoneChip and next time I get a free break in the weather i'l be brush painting it in Chassis black and fitting the wing.
Cliff
#419 rally515
rally515
  • 3,848 posts
Posted 03 August 2014 - 07:37 PM
Just a little Fabrication today, i'm home alone and looking after our 24 year old cat alone which is quite a time consuming thing really, he's getting on is our Mickey but still trying his best to do everything he used to do, apart from go outside.
Anyway, made a little under scuttle fillet piece as per the other side, fits ok:
And i've just given the Innerwing a coat of Chassis Black but heres a picture of the Stonechip, looks like an aged OEW paint job:
Cheers,
Cliff
#420 rally515
rally515
  • 3,848 posts
Posted 06 August 2014 - 10:12 PM
Weeeellllllllll, the mini now has a pair of Wings!!!!!!!!!!!!!!!!!!!!
No....no!...........not those types of Wings, but nice idea there ;)
It infact has the steel type welded into place and secured.
Not too happy atall with the first wing I did, so going to re-do the back edge so it sits further up at the scuttle corner, must be my innerwing wection sitting too low when I made it :( damn and blast!!.
Also welded in the under scuttle fillet piece I recently made, just before dooing so guess what I found in the garage ?
YARP, i'd already Fabricated the piece before and completely for gotton about it, genuinly can't remember making it!, atleast theres a spare now :P Haha.
Also had abit of help from my old man, he brought the hole cutting kit home from his works and got to cutting my stainless bulkhead plate, its pretty think stuff being 1.5-2mm, nevermind the fact its stainless aswell!, so got a nice photo of it going lets say....quite warm ? :o
I think that's all the photos i've taken, apart from these last random ones below:
Thanks muchly for being an eyeball witness to my day,
Cliff
