Project Checkmate....
561 replies to this topic
#436 rally515
rally515
  • 3,848 posts
Posted 14 August 2014 - 07:45 PM
Hi cliff..... is the thickness good or bad compared to others ?
Cheers j
Well to be honest it's average James,  i'd, in an ideal world get 1.2mm sheet steel from a supplier and then Fabricate my panels and repair pieces from that.
Being thicker it obviously will last longer against not rust because that's down to the paint protection, but thickness gives a safeguard against rot, which if in a postion of using as a daily drive gives you abit of leeway on timescale of work.
All of the body on a mini is around thick thickness, excluding parts like the Bulkhead Crossmember which is 2mm.
#437 Minidarren83
Minidarren83
  • 1,207 posts
Posted 14 August 2014 - 08:26 PM
Body is all 0.9 steel and the thicker stuff like bulkhead and heel board is 1.2
#438 rally515
rally515
  • 3,848 posts
Posted 14 August 2014 - 09:30 PM
Ahh thanks for that Darren, wasn't far off the thicknesses then was I ;)
Righty-O,  few more Pictures here!
Seems to fit ok.
I also made a cardboard Template to check the actualy pressing depth against the original, seems spot on!
New Step:
And the Old Step:
Cliff
#439 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 August 2014 - 09:35 PM
wow a magnum step that fits!
Guinness world records, here you come!
#440 rally515
rally515
  • 3,848 posts
Posted 14 August 2014 - 10:37 PM
Haha, yeah think I might buy in bulk next time I get into town Ben ;)
In my mind it was well worth the risk considering the Genuine one would work out at £70!!!, money I can't afford to throw into just two Doorsteps.
Also pretty happy with the outer sill, it required cutting down abit but other then that it's top notch!
#441 jpw1275
jpw1275
  • 2,803 posts
Posted 15 August 2014 - 06:22 AM
Is the new one fitted there in the pics mate ? When I looked at mine it didn't look like too much difference to the original
I got my a posts from there aswell which seemed a nice thickness too.... And passenger front and rear floor......and a god awful inner sill repair......
Cheers j
Edited by jpw1275, 15 August 2014 - 06:26 AM.
#442 jpw1275
jpw1275
  • 2,803 posts
Posted 15 August 2014 - 10:13 AM
Hi cliff...... when do you need the stainless bumpers im giving you ?
Cheers j
#443 rally515
rally515
  • 3,848 posts
Posted 15 August 2014 - 01:20 PM
Hi James,
No I'd just mocked it up in place over the original, still need to take measurements again before I cut the original doorstep out and then weld in, then it's a case of coating the sill cavity and sticking the outer sill on.
Have bought a few sheets of sand paper the Key up the panels today, should be in Zinc by 3 O'clock and ready to start fettling for fitting later on tonight hopefully.
#444 ToM 2012
ToM 2012
  • 4,066 posts
Posted 15 August 2014 - 04:59 PM
looks excellent mate  =]
#445 rally515
rally515
  • 3,848 posts
Posted 15 August 2014 - 08:16 PM
Thanks Tom :).
Well today I got the Sandpaper I needed from Halfords and keyed up the two panels, and then I cut out the old Doorstep which was a MESS!!! and welded in the new one.
Also had the do a little patch just above the panel on the A-post, still need to be ground down a lot yet but the fitment is good so that's all I was concerned about.
So thas it for today, I did the patch to blank off the jacking point hole in the outersill and then packed up my things and came in, Aaaaaannnd......I was greeted by the site of a chocolate cake known as a catapillar......bearing in mind im now 20! :rolleyes:
That's all for today folks, thanks for looking,
Cliff
Edited by rally515, 15 August 2014 - 08:18 PM.
#446 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 August 2014 - 08:20 PM
Happy Birthday Cliff!!
Hope you had a great day
Ben
#447 rally515
rally515
  • 3,848 posts
Posted 15 August 2014 - 08:25 PM
Ben
Thankyou Bne, much appreciated.
Yeah progress went quite ok to be honest, didn't spend too much time out but all in all happy with the result, also in other news I stripped an Old Laptop to components and cleared out the dust from the fan which wasn't working and overheating it were it would black screen, put it all back together expecting it to be broken because everything I strip usualy never lives to see another day :lol:  and yeah...it's works! and has been left on for the past 1hour or so, which makes it quite a successful repair :D .
I'm considering myself basically a Major Level 9 PC Genius now like....just have the Skillz! :shades:  Hahha
#448 ToM 2012
ToM 2012
  • 4,066 posts
Posted 15 August 2014 - 08:57 PM
well happy birthday i hope you have a good weekend. i cant believe your not going to share the cake out to us :rolleyes:
#449 Domneon
Domneon
  • 720 posts
Posted 15 August 2014 - 09:03 PM
Happy Birthday mate
#450 jpw1275
jpw1275
  • 2,803 posts
Posted 15 August 2014 - 09:24 PM
Happy birthday cliff...... What it must be like to be 16...... ;0)
Step looks well mate..... I'm getting itchy fingers now ready for the deseaming tomorrow....:0)
Cheers j
