Baghdad To Bolton ( A Full Rebuild To Aid Recovery )
roundnose
181 replies to this topic
#61 Davethepioneer
Davethepioneer
  • 944 posts
  • Local Club: S.U.N.M.C
Posted 04 July 2013 - 02:55 PM
Please let me know if it works as I've never done a video from photobucket
#62 rally515
rally515
  • 3,848 posts
Posted 04 July 2013 - 03:00 PM
Its working D,
Looks the dog's dog parts that dave, really is a smart job there, the noise of metal is quite good too as fibre int very appealing in my opinion haha
So how does it lock down ? i see you're doing something at the a panel seam but im buggered as to how or what it is haha either way thats a complement as there are no visual differences as to were its locking point is or that it even flips in the firt place!
Congrats buddy ;)
Cliff
#63 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 04 July 2013 - 03:02 PM
Excellent work, Pretty much the same repairs I've had to do on mine. Are you going to have a mk1 boot lid? you can get panels that can be welded in to make your mk3 to mk1. The flip front looks like it works a treat. Well done :highfive:
#64 Davethepioneer
Davethepioneer
  • 944 posts
Posted 04 July 2013 - 03:21 PM
Cheers fellas, yes mate I'm going with the mk1 panel that you weld into place. Rally515 I will get a picture of what I've used, I'm also going to mount some sort of boot latch catch at the front so I'm making sure if one comes undone then there is a safety margin built in
#65 Minidarren83
Minidarren83
  • 1,207 posts
Posted 04 July 2013 - 05:19 PM
That is exactly how I have done mine looks good
#66 Davethepioneer
Davethepioneer
  • 944 posts
Posted 04 July 2013 - 05:27 PM
Cheers fella, did you have any problems at all?
#67 Minidarren83
Minidarren83
  • 1,207 posts
Posted 04 July 2013 - 05:31 PM
Nothing major the wings pinch in a little at the top near the scuttle but that's because I pulled the bonnet to wing gaps right in and I e not got any catches under the wing just tabs and am going to put a thin rubber strip in the wing a panel join to stop paint damage. I will be using two stage internal release catches at the front so it will have a bonnet pull and latch from a Volvo truck side locker
#68 Davethepioneer
Davethepioneer
  • 944 posts
Posted 04 July 2013 - 06:29 PM
That's similar to my idea, I've seen a few latches on eBay that may suit me for the job. Sounds like we both had the same problems.
#69 Davethepioneer
Davethepioneer
  • 944 posts
Posted 04 July 2013 - 06:30 PM
Ok just a few pictures from today. Needed and managed to get the front in etch primer so it protects the metal from getting surface rust.
Having a good clear up in the garage tomorrow before the big fill and sand, fill and sand begins!
Still plenty of work to do on the gaps!
Any thoughts, criticism etc?
#70 rally515
rally515
  • 3,848 posts
Posted 04 July 2013 - 06:36 PM
Come and restore mine................please ?
Haha no criticism atall from me dave, love the fiinish already to be honest >_<
So are you spray painting underbody too ? or dropping it on all four with brush paint underneith for a thicker coat of protection ?
#71 Davethepioneer
Davethepioneer
  • 944 posts
Here's a quick picture of the latches I've used to lock into the A panels.
These are just used to hold it in place, the main lock will be at the front and cable operated (hopefully)
#72 Davethepioneer
Davethepioneer
  • 944 posts
Posted 04 July 2013 - 06:38 PM
Always happy to help with anything fella. The hammerite has been in there now well over 6 month so should be cured nicely, so it will get a good keying then on with the stone chip then base coat and lacquer
#73 rally515
rally515
  • 3,848 posts
Posted 04 July 2013 - 06:43 PM
Ah should be plenty protection there then ;) , when you get up and running id appreciate a opinion on the protection stonechi gives as i,ve got a can but have my doubts unless i buy a ton of the stuff haha
#74 Minidarren83
Minidarren83
  • 1,207 posts
Posted 04 July 2013 - 07:05 PM
Looks good where did you get the etch primer from?
#75 Davethepioneer
Davethepioneer
  • 944 posts
Posted 04 July 2013 - 07:09 PM
It's good stuff fella I've used it before. If you were building a car that would only be driven in sunny weather and your willing to wash, dry and polish the underneath every time you take it out then I wouldn't use it but it gives great protection and if its the same as what I will be using you can paint over it with any colour. I will get a pic of it tomorrow mate
